New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
30 registered members (Ablebody, Bjornviken, BlakeB, Ag76, 5 invisible), 852 guests, and 38 spiders.
Topics290,744
Posts4,849,442
Members66,033
Most Online3,590
Jan 24th, 2017
2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 #4458888
07/14/17 12:57 AM
07/14/17 12:57 AM
Deutschland
Napi Offline OP
Napi  Offline OP
Deutschland
Saturn Sky Redline
2.0l 4-cylinder turbo engine (GM LNF)
Mobil 1 5w50 Peak Life
In the engine for 10.000km and nearly thirteen months.
Changed when the car reached 140.000km on the odometer.
Iron and Silicone are high, I am a bit concerned about that.
Around 120.000km(Summer 2015) I had both timing chains plus all tensioner etc. changed.
Since then, nothing was done to engines internal parts.
The valve cover gasket was changed last year (130.000km), when the oil was filled in. That may be the reason for the Silicone... I guess.
Any ideas on the iron? (I had the compression checked:👍, all 4 cylinders between 12.5 and 11.5)
Best regards,
Napi.
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: Napi] #4458921
07/14/17 03:15 AM
07/14/17 03:15 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Welcome Napi !!
A 2008 Opel Turbo, I have a 2006 Opel NA.
Yes the iron and silicon look high.
The Si could be the new gasket sealing material, or you need a new air filter. What can I say, check your air filter and if that is OK, see if Si does down over the next OCI.
As for Fe, maybe it's the new timing chains bedding in. Again it should go down with with the next OCI.
BTW do you have chains ? I have have a timing belt.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: Napi] #4458995
07/14/17 06:48 AM
07/14/17 06:48 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
I wouldn't be concerned with air filtration system with low Al #.
Yep, new timing chain contributes to rather high Fe ......
could frequent cold-starts, short-trippings and ambients (Is it cold ,there ?) contributes Fe wear too ?
welcome
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: Napi] #4459130
07/14/17 10:02 AM
07/14/17 10:02 AM
Chicago, IL
dparm Offline
dparm  Offline
Chicago, IL
Hi, is 5w50 the manufacturer requirement for that engine?
2017 Chevrolet Corvette Grand Sport
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: Napi] #4459188
07/14/17 11:30 AM
07/14/17 11:30 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I would run another interval and see if its trending up or down.
could be normal and trending down from your repairs.
Also that oil seems overly thick unless its seeing track use.
What was the manufacturer recommendation
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: Napi] #4459325
07/14/17 01:58 PM
07/14/17 01:58 PM
Deutschland
Napi Offline OP
Napi  Offline OP
Deutschland
Well it is not exactly cold here, but for eight to ten weeks we went below zero this winter. Short starts happen occasionally, I have to admit.
Manufacturer recommends 5w30, 5w40, 5w50 or 10w60. I decided to go with 5w50 because I don't drive on tracks, but the car is driven on the Autobahn for more than 50% of the time.
The chains (the LNF and its successors use chains, which is a shame...) were installed for nearly 10.000km when the oil was filled in. Could the high Iron really still be the chains?
Would you recommend any further action besides driving another 9k and having the "new" oil tested?
The air filter was renewed around two years (20.000km) ago and I am going to change it at 150.000km again. The manufacturer recommends a change every 50.000km but I decided to reduce that to "every 30.000km". As the new gasket is made from silicon, while the old one was made of some kind of rubber, I am not really about the Silicone, I have to admit. But the Iron still bugs me.
(Thank you for your answers so far!)
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: Napi] #4459805
07/15/17 04:05 AM
07/15/17 04:05 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
That sounds about right, my Opel owners manual says to use a 15w40 or 10W30 in either A3/B3 or A3/B4.
To be honest any quality synthetic A3/B4 oil should work for you.
I still think the iron is from the new cam chain and the silicon from the new gasket material. If there is something else, you can't really gauge that from a simple oil analysis, it's more an oil interval length test assuming the engine is working well.
You could try a different weight and brand if that makes you happy, maybe a 40 grade in Castrol Edge or Magnatec. Or Shell Helix Ultra 5W40 which is a Porsche A40 rated oil.
Mind you if you change oil and the Fe decreases, is it the new oil or did you just wait it out ?
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: SR5] #4459889
07/15/17 07:53 AM
07/15/17 07:53 AM
Deutschland
Napi Offline OP
Napi  Offline OP
Deutschland
I have to admit, that sentence exceeds my knowledge of the English language. blush
If I understand it correctly my answer is:
I changed the oil at 140.000 because I change it every 10.000km. The new Oil is Mobil 1 5w50 again, but they changed the oil lightly, it is no longer called "peak life".
At the moment I plan to do the next change at 150.000 with either 5w50 or maybe a 5w40. And then (of course) have the oil checked again.
I take it the Fe is not that extremely high that it would stop me from driving another 9.000km without further tests on the engine?!
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: Napi] #4461383
07/17/17 04:09 AM
07/17/17 04:09 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Sorry, as an Australian, I don't speak very good English either.
What I'm saying is, you have two choices, try again with the same oil M1 5W50 or to try with a different oil (e.g. Shell Helix Ultra 5W40, Castrol Edge 0W40, 5W40, etc).
Now I predict that your iron (Fe) levels will drop anyway, as it is probably due to the new cam chain. If it is just the new cam chains bedding in, then this drop in iron should happen regardless of what oil you use. It's just a function of time.
So if you keep to the same oil, I hope you should be able to see this happen.
But if you change to a different oil and the iron drops, is it the new oil (chemistry) ? or the cam chains bedding in (time) ?
It's up to you, do you want to try a new oil ? Or do you want to see if it is the new cam chains and the levels should drop naturally (requires same oil for positive proof).
BTW I was in Ulm Swabia about this time last year, great city.
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: Napi] #4461385
07/17/17 04:18 AM
07/17/17 04:18 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
I had dinner in the Rathaus (Old Town Hall), built in 1370
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: SR5] #4461500
07/17/17 08:21 AM
07/17/17 08:21 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
That's the biggest cuckoo clock I've ever seen. wink
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: Napi] #4462938
07/18/17 02:29 PM
07/18/17 02:29 PM
Deutschland
Napi Offline OP
Napi  Offline OP
Deutschland
Little OT:
Did you take the stairs to the Ulmer Münster?
Worth the effort. It is he'll of an effort though...
BTT: As there is another Load of M1 in the engine, I will give it another 8500km and then have another look.
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: Napi] #4462989
07/18/17 03:02 PM
07/18/17 03:02 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Why was the chain replaced already? Do you make sure the oil level is always at full?
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: Napi] #4463094
07/18/17 05:04 PM
07/18/17 05:04 PM
Deutschland
Napi Offline OP
Napi  Offline OP
Deutschland
One of the chain slides had broken and the primary chain had stretched.
So I had both chains plus slides/tensioners etc. renewed.
To be honest, that is quite common for the GTs. I'd say 1 out of 2 GTs has the chains renewed prior to 100.000km. When my engine started the typical vibration I was a little bit relieved, just because I started to fear that my chain may just rip off if I would not replace it soon. grin
But seriously, the chains are THE common issue with the GTs. Opel even created a Replacement-kit made of an Insignia Chain and different slides (different color at least).
And yes, the oil is always full. I check every time I refuel. Even though I have to admit that in the 141.500km and nine years that I'm driving the car I never had to fill in a single drop of oil besides from the normal oil change every 10.000km.
Re: 2008 Opel GT (Saturn Sky Redline), Mobil1 5w50 [Re: Napi] #4463100
07/18/17 05:14 PM
07/18/17 05:14 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Yes !! All 768 steps, for a great view 162 m up the church tower.
I was there for work, but I wish my family was with me, it is such a beautiful town but without the mass of tourists you get in some other places.
