Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
135 registered members (4WD, AndyB, 64bawagon, 2009Edge, 240_Ed, 2015_PSD, 11 invisible), 2,178 guests, and 68 spiders.
Topics286,399
Posts4,907,622
Members67,614
Most Online2,967
Mar 10th, 2019
Just passed smog test. Hydrocarbons a bit high #4458877
07/14/17 12:33 AM
07/14/17 12:33 AM
california
wrcsixeight Offline OP
california
Here are 3 smog test results 12 years apart on same vehicle/engine, most recent 2017 on bottom:
In a previous thread showing macro pics of my previous bosch +2 sparkplugs, Trav said the coil could be on its way out.
All the other ignition components are new, Taylor 8mm wires, NGK Gpower platinum plugs, new airtex/wells distributor cap and rotor.
It is a 12 or 13 year old Echlin.
Thinking the replacement will be an Airtex/Wells.
http://www.rockauto.com/en/moreinfo.php?pk=2060580&cc=1073506&jsn=438
I was impressed with their distributor cap
LA 318 Roller Cam
Pennzoil Platinum 10w-30 SN Plus
Fram ultra XG8A
Fram Ultra XG16 on remote transmission filter mount
Re: Just passed smog test. Hydrocarbons a bit high [Re: wrcsixeight] #4458886
07/14/17 12:50 AM
07/14/17 12:50 AM
Seattle
Superflop Offline
Superflop  Offline
Seattle
You have good wires plugs and cap n rotor throw in a nice coil like an accel, flame thrhrower or screamin demon and open the gap a bit to something like 60 thousandths. On my old 1994 grand cherokee with 318 i had taylor wires, summit racing cap and rotor and a screamin demon coil with plugs gapped at 65 and it ran like a swiss watch.
2002 saab 9-5 2.3t wagon
2014 dodge grand caravan
Re: Just passed smog test. Hydrocarbons a bit high [Re: wrcsixeight] #4458926
07/14/17 03:39 AM
07/14/17 03:39 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I would not worry over it. The readings are not drastically different from 2005 and would pass with flying colors in my state.. You passed and do not need to worry till next test time.Why look for problems that may not exist. Your probably dealing with a converter which is slowly losing its effectiveness or a small vacuum leak.
The "thinking" man's friend.
Re: Just passed smog test. Hydrocarbons a bit high [Re: wrcsixeight] #4458933
07/14/17 04:04 AM
07/14/17 04:04 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
A beefier coil and a bottle of HEET and you'll pass with flying colours smile
Cable ties should hold it
Re: Just passed smog test. Hydrocarbons a bit high [Re: wrcsixeight] #4458959
07/14/17 06:00 AM
07/14/17 06:00 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I'd find something else to worry about, you passed. The engine and emissions system are older with more time, miles, and wear on it than the last test. That in and of itself can make slight changes in emissions.
God Bless Our Troops
Re: Just passed smog test. Hydrocarbons a bit high [Re: wrcsixeight] #4459001
07/14/17 06:52 AM
07/14/17 06:52 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Instead of changing the coil, you could try closing the gap between the rotor and the individual poles in the distributor cap. I usually modify the rotor to accomplish this.
Re: Just passed smog test. Hydrocarbons a bit high [Re: wrcsixeight] #4459025
07/14/17 07:20 AM
07/14/17 07:20 AM
USA
mk378 Offline
mk378  Offline
USA
CO has also always been a bit high, and NO kind of low (at least it was back in the first test when the converter was new). This suggests a rich run not misfiring.
Re: Just passed smog test. Hydrocarbons a bit high [Re: wrcsixeight] #4459059
07/14/17 08:09 AM
07/14/17 08:09 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
HC high at low speed, I would be replacing the PCV valve first.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Just passed smog test. Hydrocarbons a bit high [Re: wrcsixeight] #4459112
07/14/17 09:29 AM
07/14/17 09:29 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
+1
And, run a new dedicated ground lead from the battery Neg ( - ) pinch bolt to the intake and then on to the firewall. #8 wire or bigger with crimped and soldered lugs the size to fit the bolts chosen. It will help the ECU see all the engine sensor circuits with a clean "O" baseline, so the injection will be better and more stable.
Coils don't fade away. They either work, or are shorted internally and don't. They can be intermittent with heat. But they do not slowly die.
Re: Just passed smog test. Hydrocarbons a bit high [Re: mk378] #4459149
07/14/17 10:30 AM
07/14/17 10:30 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
The CO isn't high. He's atleast half of the limit.
Re: Just passed smog test. Hydrocarbons a bit high [Re: wrcsixeight] #4459216
07/14/17 12:10 PM
07/14/17 12:10 PM
Central Coast California
RedOakRanch Offline
RedOakRanch  Offline
I just got a handed down 1994 Crown Vic with 200k, it only blew 5ppm on nasty plugs. I only knew because I have since changed them. I'd think one of the sensors or cat is starting to go on your vehicle. My friends 99 dodge 360 passed with a broom sticked cat a few years ago and it blew higher numbers similar to yours.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: Just passed smog test. Hydrocarbons a bit high [Re: BrocLuno] #4459220
07/14/17 12:13 PM
07/14/17 12:13 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Originally Posted By: BrocLuno
+1
I used to think that too. Until I had one that would run poorly and raw gas collected in the exhaust and touched off. One of my BMW buddies reported a similar situation. These were the typical can type coils. On the whole reliable. easy to replace.
Thick oil is better grin2
Re: Just passed smog test. Hydrocarbons a bit high [Re: wrcsixeight] #4459225
07/14/17 12:17 PM
07/14/17 12:17 PM
California
brave sir robin Offline
California
I drive my truck less than 500 miles a year so between smog checks I'm not exactly wearing out parts. Every time I get it tested it shows different totals sometimes vastly different numbers with no hardware changes. Before I start spending money I would just go on nice freeway trip with a few WOT pulls and then pull into the smog station with it nice and hot.
With dreams to be a king, first one should be a man
95 Nissan Pathfinder 5w-30 M1-HM
68 Buick Electra 10w-30 QS Defy
02 Aprilia Falco 15w-40 Rotella
Re: Just passed smog test. Hydrocarbons a bit high [Re: wrcsixeight] #4459231
07/14/17 12:30 PM
07/14/17 12:30 PM
california
california
It will be two years before I get another smog test, as I don't have a friend with a sniffer just to run that portion of the test, and will not be paying just to see the results of any changes I might make.
I replaced the last coil as oil was weeping out of the tower. These are mounted on their sides.
I had pulled into station with several WOT pulls and with it as hot as the engine gets. They pulled in onto the rollers almost immediately.
With all new ignition components, but the coil, I was hoping for better HC readings
A new coil is about 25$
LA 318 Roller Cam
Fram ultra XG8A
Re: Just passed smog test. Hydrocarbons a bit high [Re: wrcsixeight] #4459306
07/14/17 01:43 PM
07/14/17 01:43 PM
Maryland
walterjay Offline
walterjay  Offline
Maryland
You passed. You're good. Sleep well tonight.
