Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
24 registered members (Bama, 1345, ChristianReske, ctechbob, Donald1953, Char Baby, 2 invisible), 807 guests, and 45 spiders.
Topics295,172
Posts4,929,122
Members66,700
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
Rear brake job, now hot wheels and smell!! #4458787
07/13/17 09:09 PM
07/13/17 09:09 PM
FL, USA
gregk24 Offline OP
gregk24  Offline OP
FL, USA
I got home after having the rears pads replaced and rotors resurfaced and one wheel was very warm/hot and had a smell to it. It was more hot than the other and also had a steel to it. Keep in mind this is the wheel that DID NOT have the hub bearing "problem" that I posted on earlier today. Is it normal for new pads to give off more heat and have a smell t them?
2012 Honda Accord EX-L K24z3
54,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
40,xxx miles
Castrol OEM dealer fill / OEM filter
Re: Rear brake job, now hot wheels and smell!! [Re: gregk24] #4458793
07/13/17 09:16 PM
07/13/17 09:16 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
Yes
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Rear brake job, now hot wheels and smell!! [Re: gregk24] #4458794
07/13/17 09:17 PM
07/13/17 09:17 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
The caliper sliders are probably seized up preventing the caliper from centering itself over the rotor.
Dealer tech probably forget to lube the slide pins.
Re: Rear brake job, now hot wheels and smell!! [Re: gregk24] #4458807
07/13/17 09:31 PM
07/13/17 09:31 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Smell, MAYBE, heat no. What Merk said. Also a lesser chance of parking brake issues.
Various musings: http://hangfire.net
Re: Rear brake job, now hot wheels and smell!! [Re: gregk24] #4458830
07/13/17 09:50 PM
07/13/17 09:50 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
They should act the same.. both hot, both cold.. etc
if just one is hot.. either it is the only one working.. or its malfunctioning..
since you said it had a brake smell I'd say its sticking.
Re: Rear brake job, now hot wheels and smell!! [Re: gregk24] #4458848
07/13/17 10:09 PM
07/13/17 10:09 PM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
Did you completely remove dust boots and slide pins?
Also did you spin the calipers back in?
08 Honda Accord EX-L 2.4L M1 EP 0w20 145k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 193k
95 Yamaha Jog
Re: Rear brake job, now hot wheels and smell!! [Re: gregk24] #4458865
07/13/17 10:58 PM
07/13/17 10:58 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Smell is usually normal from new pads.
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Rear brake job, now hot wheels and smell!! [Re: gregk24] #4458900
07/14/17 12:55 AM
07/14/17 12:55 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
If one is a lot hotter than the other one, than the caliper on that side is sticking, which is fairly common. The caliper piston has corrosion on it that doesn't work well when the piston is pushed back into the caliper.
Depending on how hot it gets, I would either continue running it until it break itself in, or take it back to the shop the did the repairs. The fix is a new rebuilt caliper.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 Maxlife Syn 5W30
06 GMC Sierra Nextgen 10W30
Re: Rear brake job, now hot wheels and smell!! [Re: gregk24] #4458903
07/14/17 01:09 AM
07/14/17 01:09 AM
Slovenia EU
Kamele0N Online sick
Kamele0N  Online Sick
Slovenia EU
Do you have pistons with special notch on their surface....if YES...then pay attention that you aligne that notch with corresponding "bump" on breaking pad...
As mentioned...sometimes (depends on wich handbrake system you have) rear pistons had to be spinned all the way back in (in case of new pads)
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Rear brake job, now hot wheels and smell!! [Re: gregk24] #4458904
07/14/17 01:11 AM
07/14/17 01:11 AM
Slovenia EU
Slovenia EU
Btw...been there....done that...the wrong way grin
Re: Rear brake job, now hot wheels and smell!! [Re: Kamele0N] #4458905
07/14/17 01:15 AM
07/14/17 01:15 AM
CA
The Critic Offline
The Critic  Offline
CA
That is probably the problem. If the slot on the piston was not lined up with the pads, the pads will drag.
2011 Toyota Prius - 178k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 133K - Mobil 1 EP HM 5W-30
Re: Rear brake job, now hot wheels and smell!! [Re: gregk24] #4458939
07/14/17 03:46 AM
07/14/17 03:46 AM
USA
NHGUY Offline
NHGUY  Offline
USA
When you run thin pads for a long time,you expose the caliper piston to travel lengths its not normally used to.This also allows the inner end of the bore to be exposed to pitting for an extended time.Once you push the piston back into territory it hasn't been in for a long while it gets on those "pits" and will be hard to release.
Re: Rear brake job, now hot wheels and smell!! [Re: gregk24] #4458943
07/14/17 04:00 AM
07/14/17 04:00 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
I put new front pads and rotors in about a year and a half ago. Strong smell and lack of feel until they bedded themselves in. For me it was a few days before I was happy with the feel of the new pads.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Rear brake job, now hot wheels and smell!! [Re: gregk24] #4458944
07/14/17 04:02 AM
07/14/17 04:02 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
With the worn pads, the caliper piston was extended outward. The pistons are now way in the caliper bore and likely is hanging up. You maybe be replacing a caliper(s) soon. If everything is working good, you should not be smelling anything from the brakes.
The "thinking" man's friend.
Re: Rear brake job, now hot wheels and smell!! [Re: Brybo86] #4458950
07/14/17 04:19 AM
07/14/17 04:19 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
He took it to the dealer. Greg don't turn wrenches. tongue2
Page 1 of 3 1 2 3
