2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
65 registered members (Bailes1992, advocate, 1JCB, askani79705, 94astro, Blueskies123, 4 invisible), 1,186 guests, and 38 spiders.
Topics290,627
Posts4,847,659
Members66,011
Most Online3,590
Jan 24th, 2017
Mixed Use Tire for SUV #4458765
07/13/17 09:36 PM
07/13/17 09:36 PM
New Mexico USA
CCI Offline OP
CCI  Offline OP
New Mexico USA
I've got the Michelin LTX M/S2 on there now, I like them real well on the highway, OK but not great in the snow on paved areas, not worth much at all off road, especially in the mud.
If 80% of my miles are highway, then about 19% are around town, and 1% are off road, but for the off road part it is absolutely essential that everything works the way it is supposed to.
I realize I'm asking a lot out of a tire -- safe, stable, quiet, and reasonable wear at 80 mph in temperatures over 90 degrees, and then occasionally leave the paved surface for any amount of rock and mud.
Thinking real seriously about the Michelin A/T.
Anyone have any experience either way (good or bad) with them?
Re: Mixed Use Tire for SUV [Re: CCI] #4458805
07/13/17 10:30 PM
07/13/17 10:30 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
The Michelin AT/2 is less of an off-road tire than the MS/2 was, with overall poor reviews all around. I was unimpressed by the reviews and when I asked my trusted local tire guy, without any prompting one way or another, he warned me off the AT/2's.
An Arizona member just settled on a similar question here: https://bobistheoilguy.com/forums/ubbthr...tin#Post4456543
Various musings: http://hangfire.net
Re: Mixed Use Tire for SUV [Re: CCI] #4458819
07/13/17 10:38 PM
07/13/17 10:38 PM
WI.
dblshock Offline
dblshock  Offline
WI.
BFG A/T KO2 is top rated but bet they won't beat a LTX at 80. I'm headed toward the former with 90% below 60mph, little logging trail and snow.
16 Civic Coupe Touring 33k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 141k
640:1 TCW-3
M1 0/40 XG3614
Falken Wildpeak AT3W
Re: Mixed Use Tire for SUV [Re: CCI] #4458832
07/13/17 10:55 PM
07/13/17 10:55 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
You cant have everything.
and michelin AT tires are mediocre.
Nothing is good in thick mud except a mud tire.. sometimes not even a mud tire..
you need giant tread voids and little to no siping to work correctly.
You might try a high rated AT tire:
Cooper Discoverer A/T3 Best value esp with DTD/DT sales
Yokohama Geolandar G015 (best road manners)
BFG k02
General Grabber AT2
Cooper S/T (most aggressive)
Goodyear Adventure AT
Bridgestone Revo2
toyo opencountry AT2
Kumho AT 51
Hankook Dynapro ATM
Etc, I'm sure I missed a few
There are plenty of off-road reviews of most of these tires.
Re: Mixed Use Tire for SUV [Re: CCI] #4458837
07/13/17 11:01 PM
07/13/17 11:01 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Not the best of luck with Michelins off road. Or Goodyear Wranglers. Have taken out too many sidewalls on sharp rocks. Big dilemma for you. 3-ply sidewalls like BF Goodrich are sturdy off road, but suck at smooth ride going down the highway ...
And the Goodrich blocky tread works great off road, but the develop "brake slope" on the blocks and start to run noisy as they get older ... Lots of tire rotations help some ...
I have Bridgestones on my Bronco and they are a decent compromise. But mud will absolutely slime out on any even passably comfy highway tire ...
Plus aspect ration is working against you. Mud needs TALL skinny tires with aggressive tread to get down through the mud to the real footing. Sand and dust want fat tires that will blow off if they even see mud in the distance ...
Re: Mixed Use Tire for SUV [Re: CCI] #4458863
07/13/17 11:56 PM
07/13/17 11:56 PM
BC, Canada
userfriendly Offline
BC, Canada
My summer set, almost worn out are 275/65/20 Michelin AT/2 11X34.4", weigh 60 lbs. 3 steel plies under the tread, hard to balance, no flats.
My winter set, studded Hankook RW-11s, same size except 3 ply sidewall, weigh 70 lbs.
I think a good compromise and likely my next set will be the Hankook RF-10, also a 3 ply in my size.
Some Hankooks are made in China now, so avoid those sizes, as the quality is suspect.
Re: Mixed Use Tire for SUV [Re: CCI] #4458897
07/14/17 01:43 AM
07/14/17 01:43 AM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
Duratracs and BFG at2 are both the best all around all terrain oriented tires. BFG leaning more toward street manners and the duratracs to off roading. Currently have duratracs on my yota truck and go snow wheeling pretty often in the winter. No not a stock rig. I have had a set of the KO2s as well and they were great in everything but the rain.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: Mixed Use Tire for SUV [Re: CCI] #4458920
07/14/17 03:10 AM
07/14/17 03:10 AM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
I do know one tire that can do this. It is not cheap, but it works.
Toyo Open Country A/T.
I have had these on multiple vehicles and with all, they delivered very good highway miles and behavior, excellent wear, and great off road performance for a tire that did the other two well.
The caveat with these is two-fold.
1) they do not age well; if you drive the vehicle 5k miles a year, they will be done in 20k/4 years as they will harden. After that the snow and off-road performance really suffers.
2) They aren't cheap!
But they will do exactly what you ask when new and for several years. I am not in your climate now, but I have 4-wheeled in AZ and NM before and understand your environment.
Another thing to check out is the General Grabber A/T. A trusted tire guy I know says they are the cheaper alternative to the Toyo A/T, and good bang for the buck. Look into that, also. Frankly, I will on my next set as successive price increases and exchange rates make the Toyo A/T less attractive.
Re: Mixed Use Tire for SUV [Re: Oro_O] #4459088
07/14/17 08:57 AM
07/14/17 08:57 AM
New Mexico USA
CCI Offline OP
CCI  Offline OP
New Mexico USA
Thanks -- I will look at the Toyos. Glad you mentioned this, maybe a few years ago someone suggested them in a similar way and I forgot about it. Their opinion was identical to yours.
I will happily spend more for something that works the way it is supposed to.
Re: Mixed Use Tire for SUV [Re: CCI] #4459174
07/14/17 11:15 AM
07/14/17 11:15 AM
Outer Banks, NC
NormanBuntz Offline
NormanBuntz  Offline
Outer Banks, NC
I also vote for the Toyo Open Country A/T.
2017 Honda Odyssey SE, 15K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 87K
2007 Infiniti M35, 106K
Re: Mixed Use Tire for SUV [Re: CCI] #4459219
07/14/17 12:13 PM
07/14/17 12:13 PM
new jersey
jrvn Offline
jrvn  Offline
new jersey
Michelin LTX AT2, look no farther grin
Re: Mixed Use Tire for SUV [Re: jrvn] #4459293
07/14/17 01:32 PM
07/14/17 01:32 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Michelin AT tires are average or below.. one of the few market segments they arent near class leading
And their premium price.. can get tires for half the price that are as good or better.
I am not anti michelin or a fanboy.. my last 2 cars had michelin or michelin winter tires
For AT tires I would look elsewhere.
Re: Mixed Use Tire for SUV [Re: CCI] #4459966
07/15/17 09:27 AM
07/15/17 09:27 AM
Iowa
The_Eric Offline
The_Eric  Offline
Iowa
Firestone Destination AT. Have them on my truck and they do everything I want well enough. Seem to handle moderate mud and snow well.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Mixed Use Tire for SUV [Re: CCI] #4461417
07/17/17 06:21 AM
07/17/17 06:21 AM
Michigan, USA
Bighorn2500 Offline
Bighorn2500  Offline
Michigan, USA
Have Michelin LTX AT2 on Ram 2500 Diesel now, good highway manners and able to get down two tracks to my hunting property. Seem to clean out well with a little pedal when it gets sloppy & wet. I had two other good AT brands prior to to these and the highway ride on these made the difference for me.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2015 Jeep Cherokee 3.2L Latitude 4x4
Re: Mixed Use Tire for SUV [Re: CCI] #4461581
07/17/17 09:57 AM
07/17/17 09:57 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
I had a pair of Toyo AT2s on a previous vehicle and they handled well both on an off road. Little louder but what AT tire isn't. Another tire to consider is the Firestone Destination AT.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
