Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
25 registered members (danez_yoda, D0nat, ctechbob, 53' Stude, bbhero, ChristianReske, 3 invisible), 921 guests, and 49 spiders.
Topics295,172
Posts4,929,126
Members66,700
Most Online2,553
Oct 27th, 2018
Total Quartz Ineo 5w30 - '13 VW Golf TDI #4458519
07/13/17 04:11 PM
07/13/17 04:11 PM
Oklahoma
DerekG Offline OP
DerekG  Offline OP
Oklahoma
Most recent UOA for my Golf. Things continue to look great!
I told them I added a Frost Heater and used it on every cold start below 40F. I did not expect it to make a difference really.....iron did go down, but no way of really knowing if the Frost Heater is the reason. It did SIGNIFICANTLY reduce idle/warm-up time on my commute and the engine was ~160F on every "cold" start below 40F.
I re-filled the car with the newest formulation of Liquimoly Long Life III 5w30 507 spec and will run about the same OCI as I did this time.
oil july 2017 pic by DerekG710, on Flickr
2013 VW Golf TDI 6MT (DPF/EGR delete w/ tune)
2018 VW Tiguan SE 4MO
1991 BMW 535i (project)
Re: Total Quartz Ineo 5w30 - '13 VW Golf TDI [Re: DerekG] #4458656
07/13/17 06:38 PM
07/13/17 06:38 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Looks good smile
Re: Total Quartz Ineo 5w30 - '13 VW Golf TDI [Re: DerekG] #4458785
07/13/17 09:08 PM
07/13/17 09:08 PM
Stewartstown PA
spiderbypass Offline
Stewartstown PA
Even though I have given up gambling for 2 months three days six hours and two minutes: I would bet most of stellar diesel reports have engine tuned with emissions stuff deleted. It is amazing to see the difference in wear metals and the condition of the oil. I almost think there should be a separate section for full emission diesel reports and deleted ones because I think you can almost run any oil when the emissions stuff is gone-case in point the one guy running Neo 0w5 in his older tdi which has a solid engine to begin with but is gravy without egr.
Insecurity with overcompensation are the root of evil deeds.
Re: Total Quartz Ineo 5w30 - '13 VW Golf TDI [Re: spiderbypass] #4458858
07/13/17 10:35 PM
07/13/17 10:35 PM
Oklahoma
DerekG Offline OP
DerekG  Offline OP
Oklahoma
Could be. It would be an interesting test. I would have to think it would be less stressful on the engine/turbo to not have to push the exhaust through the super restrictive DPF plus the 2 other cats.
I never ran a UOA when the car was stock. I'm sure I could run the non-spec oils now, but my reports have been so good that I don't see a reason other than cost to change anything at the moment. My local parts stores don't have the correct oil filter (in a decent brand) so I have to order that from IDParts anyway which is why I order the oil as well.
They have super convenient service kits that you can customize by oil brand, filter brand, or add air filter or fuel filter depending on the interval. They also include a new drain bolt and some nitrile gloves. It's nice to just have to add one thing to your cart and be done.
