Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
113 registered members (ad244, Aichiguy, 1978elcamino, addyguy, 69Torino, 2012AccentSE, 10 invisible), 1,931 guests, and 59 spiders.
Topics286,185
Posts4,903,775
Members67,574
Most Online2,967
Mar 10th, 2019
'13 Tundra with 6K lb trailer -what oil weight? #4458294
07/13/17 01:55 PM
07/13/17 01:55 PM
U.S.
Hal3134 Offline OP
Hal3134  Offline OP
U.S.
My Toyota manual recommends 0W-20 oil for my '13 Tundra. I saw someone here mention that if towing, I should consider a different weight oil. I haven't found anything in my manual yet that says anything like this.
I pull a 6,000 lb travel trailer a few weekends a year. My Tundra has a tow capacity of 9,000 lbs, so I don't think I'm particularly straining the engine's max capability. Based on this, what weight oil should I put putting in?
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Hal3134] #4458299
07/13/17 02:00 PM
07/13/17 02:00 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
I'd put in 0W-20 and just shorten the intervals, but that's just me.
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Hal3134] #4458305
07/13/17 02:04 PM
07/13/17 02:04 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
I wouldn't change the weight unless I were trying to do long oil change intervals while towing. For slightly added peace of mind you could go with a slightly heavier 0w20 such as amsoil or others.
If I were to go up in weight I would jump straight up to a euro spec 0w40 like what I run in my truck. I dont really bother with 5w30s as they often shear to the point that Id rather just have a good 0 or 5w20
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Hal3134] #4458308
07/13/17 02:07 PM
07/13/17 02:07 PM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
I'd stick with 0w-20
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Hal3134] #4458320
07/13/17 02:18 PM
07/13/17 02:18 PM
Texas
Tdog02 Offline
Tdog02  Offline
Texas
Toyota is on to something with the 0W-20 oils in their engines. That said, IMO, you should look at a 0W-30 under heavy towing. 5W-20 or 5W-30 are also a good choices as well. The Toyotas don't shear as badly as some engines but there are some on here that are way more knowledgeable than me. I lean toward heavier weight oils but try to stay in the ballpark of the manufacturer. Toyota fanboy here.
09 Venza 2.7 104k 5w-30 Magnatec
16 F150 2.7TT 52k 5w-30 Magnatec
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Hal3134] #4458328
07/13/17 02:21 PM
07/13/17 02:21 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I'd stick to 0W20 as well. If it were me and I was at all concerned, I'd possibly do a blend of maybe one quart of 0W30 with the rest 0W20. That way it's probably still technically a 0W20, but on the thicker end.
In general for towing, I'd be more concerned that the cooling system, transmission fluid and brake fluid is topped off and up to date. Plus highway miles are typically easier on engine oil.
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Hal3134] #4458374
07/13/17 03:12 PM
07/13/17 03:12 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
0W-30 would be a good choice.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Hal3134] #4458381
07/13/17 03:17 PM
07/13/17 03:17 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Is there a "severe service" recommendation in the owners manual?
0W-20 should be fine as long as oil temps stay reasonable. Does the engine have an oil cooler? If not, I'd go for 5W-30.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Hal3134] #4458490
07/13/17 04:45 PM
07/13/17 04:45 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Where exactly does it say that?
Is there a little bar graph with temperatures and arrows for different oils?
If there is, choose the heaviest oil on that chart.
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Linctex] #4458507
07/13/17 05:01 PM
07/13/17 05:01 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
He said in the toyota manual. Toyota did spec the 13 tundra for 0w20
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Hal3134] #4458539
07/13/17 05:38 PM
07/13/17 05:38 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Several owner's manuals posted on here show that Toyota say that a heavier oil is required for adequate protection under heavy load, high speed or mountainous regions.
If you check your OM, you've likely got the same and I'd go with a 30 weight.
Thick vs Thin test: 15k / 43k miles complete
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Hal3134] #4458574
07/13/17 06:19 PM
07/13/17 06:19 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
If you see consumption when towing I'd go up a grade. 10w-30 is my favorite grade. Any of SN 10w-30 will do a fine job
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Hal3134] #4458592
07/13/17 06:33 PM
07/13/17 06:33 PM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
As was noted already, what does your owner's manual say? What you "saw someone here mention" is not really relevant compared to what the manufacturer says.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Hal3134] #4458660
07/13/17 07:42 PM
07/13/17 07:42 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
My manual for the RX mentions a heavier grade for towing and/or sustained high speed. As vague as that statement was, I figure the sky is the limit. I personally would go with a 10w30, HDEO most likely, or 0/5w30/40 A3/B4 for low temps.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: '13 Tundra with 6K lb trailer -what oil weight? [Re: Miller88] #4458775
07/13/17 09:50 PM
07/13/17 09:50 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Of course. +1
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
