I've search the internet but I can't seem to find a good answer so I've turned to the wisdom of the Forum.
A stud has broken off on the flange between the muffler and the exhaust pipe. I plan to simply drill out the stud and replace with a nut and bolt. What I'm not clear on is if a special grade or alloy of fastener is preferred or required. This is on the stock exhaust of a 2012 Mazda 6. Thanks for your help.
