Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
111 registered members (1978elcamino, Alfred_B, ABerns, Agnosto, 2015_PSD, 17 invisible), 2,431 guests, and 63 spiders.
Topics286,019
Posts4,900,954
Members67,548
Most Online2,967
Mar 10th, 2019
Fasteners on exhaust systems #4458129
07/13/17 10:57 AM
07/13/17 10:57 AM
NY
greasegunn Offline OP
NY
I've search the internet but I can't seem to find a good answer so I've turned to the wisdom of the Forum.
A stud has broken off on the flange between the muffler and the exhaust pipe. I plan to simply drill out the stud and replace with a nut and bolt. What I'm not clear on is if a special grade or alloy of fastener is preferred or required. This is on the stock exhaust of a 2012 Mazda 6. Thanks for your help.
Re: Fasteners on exhaust systems [Re: greasegunn] #4458145
07/13/17 11:09 AM
07/13/17 11:09 AM
ohio
jjw6455 Offline
jjw6455  Offline
ohio
Something non rusting (stainless ?).
ENGINE AND ENGINE COOLING : EXHAUST SYSTEM
Number 10097841
NHTSA Item Number 01-025-12-2699
Date 2017-04-25
Summary Some vehicles may exhibit an exhaust leaking noise from the rear of the vehicle. The noise may be caused by a gap between the exhaust hanger bracket and flange, which allows moisture to enter and cause the exhaust studs to rust and possibly
Re: Fasteners on exhaust systems [Re: greasegunn] #4458168
07/13/17 11:34 AM
07/13/17 11:34 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
The shops often blow the stud out with a torch. Makes an ugly hole but it works.
Re: Fasteners on exhaust systems [Re: greasegunn] #4458189
07/13/17 11:50 AM
07/13/17 11:50 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
If you drill right through use a high grade bolt, stainless doesn't have as much shear strength but you can use a stainless or copper nut and stainless washer. Next time just blow the nut off with a torch if you cant get it off.
Re: Fasteners on exhaust systems [Re: greasegunn] #4458193
07/13/17 11:53 AM
07/13/17 11:53 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Because the muffler is reasonably far from the highest heat areas, you have some options. Distance from the catalytic converter is key ... it's the last high heat component of the exhaust. Three or more feet and you should be OK with a wider choice of fastener.
You can try a regular steel bolt and nut, use anti-sieze on it but don't expect that to last long with the temps experienced. Grade 5 should be good and many systems use plain grade 3 at the back of the exhaust.
If appearance is important use stainless but they are not as strong as a high grade steel fastener. Brass is an option but be careful, they fail at a relatively low torque. However brass is least affected by corrosion.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Fasteners on exhaust systems [Re: greasegunn] #4458230
07/13/17 12:35 PM
07/13/17 12:35 PM
Utah, USA
28oz Offline
28oz  Offline
Utah, USA
Right or wrong, I've always used grade 8 hardware when replacing anything exhaust-wise. Never had an issue with it.
1990 Nissan 300zx VG30DE - PP Euro 0W-40
2004 Nissan Quest VQ35DE - PP Euro 0W-40
2003 Ford Excursion 7.3 PSD - Rotella T6 5W-40
2005 Ford Taurus 3.0 Vulcan - Havoline HM 5W-20
Re: Fasteners on exhaust systems [Re: 28oz] #4458242
07/13/17 12:49 PM
07/13/17 12:49 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Most shops use grade 2. I never heard anyone having issues with exhaust fasteners breaking on their own.Maybe after many years.
The "thinking" man's friend.
Re: Fasteners on exhaust systems [Re: greasegunn] #4458248
07/13/17 12:58 PM
07/13/17 12:58 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Any steel bolt will work, and should last nearly 10 years. You must have a LOT of salt!
No need to go exotic.
Re: Fasteners on exhaust systems [Re: greasegunn] #4458293
07/13/17 01:55 PM
07/13/17 01:55 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I use grade 2 hardware. I replace the U Clamps and hope they shear after a few yanks
Thick oil is better grin2
Re: Fasteners on exhaust systems [Re: Lubener] #4458296
07/13/17 01:59 PM
07/13/17 01:59 PM
Utah, USA
28oz Offline
28oz  Offline
Utah, USA
Grade 2? Might as well use zip ties! Joking..... I use grade 8 'cause if it's worth doing, it's worth over-doing. laugh
Re: Fasteners on exhaust systems [Re: greasegunn] #4458312
07/13/17 02:12 PM
07/13/17 02:12 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I wouldn't use anything over Grade 2. Strength is not the issue. Getting it apart when it's rusted solid is the main concern. It's easier to cut or drill soft fasteners.
What is the benefit of using Grade 8?
Re: Fasteners on exhaust systems [Re: Kestas] #4458327
07/13/17 02:21 PM
07/13/17 02:21 PM
Utah, USA
28oz Offline
28oz  Offline
Utah, USA
Talked to a muffler shop about it once and that is what they used and recommended. I'm no metallurgist, but there might be more corrosion resistance perhaps? Lower grades would definitely be easier to cut or drill, but if a stronger bolt/nut doesn't break, you wouldn't need to cut or drill to begin with. I could be completely wrong, but it's worked for me.
Re: Fasteners on exhaust systems [Re: 28oz] #4458337
07/13/17 02:32 PM
07/13/17 02:32 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I am a metallurgist. Grade 8 offers no more corrosion resistance than a Grade 2. In fact it may even be worse.
You don't cut and drill because an exhaust system bolt breaks, you do it because it is rusted solid.
Re: Fasteners on exhaust systems [Re: Kestas] #4458352
07/13/17 02:51 PM
07/13/17 02:51 PM
Utah, USA
28oz Offline
28oz  Offline
Utah, USA
I've drilled out plenty of broken studs. Anyways, fair enough. You're a metallurgist, so I will defer to your opinion. I'm completely open to being told I'm wrong, lol. That's how you learn, right? The grade 8 hardware I've replaced still looks brand new after a couple years whereas others have rust very shortly. shrug
Re: Fasteners on exhaust systems [Re: greasegunn] #4458364
07/13/17 03:03 PM
07/13/17 03:03 PM
USA
E365 Online content
E365  Online Content
USA
What's the take on nickel based anti-seize compounds on exhaust hardware? The super high temp stuff. I've used it lately, but not long enough to know if it really helps long-term.
Whatever’s on sale...
