Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
104 registered members (69Torino, 2012AccentSE, 2010Civic, 69GTX, 1978elcamino, 8 invisible), 1,805 guests, and 51 spiders.
Topics286,112
Posts4,902,848
Members67,565
Most Online2,967
Mar 10th, 2019
Turbine oil in internal combustian engines? #4457921
07/13/17 07:22 AM
07/13/17 07:22 AM
ST Augustine, FL
exShuttlemech Offline OP
ST Augustine, FL
Has anyone ever used turbine oil (such as Exxon 2380) in their gas or diesel engine?
2010 Rav4 4cyl 131K QSUD 0W20 Baldwin bypass filter
2003 4Runner 4.0L 219K 0W40 M1 Frantz bypass
2007 F150 4.2L 169K 5W30 QSUD
2016 NV2500
2017 RAV4
Re: Turbine oil in internal combustian engines? [Re: exShuttlemech] #4457928
07/13/17 07:35 AM
07/13/17 07:35 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
I have used Mobil Jet Oil in my lawn mower just to see how it would do. Other than leaking from the center case gasket it seemed to have done it's job of lubricating the engine.
It certainly didn't hurt anything.
Re: Turbine oil in internal combustian engines? [Re: exShuttlemech] #4457982
07/13/17 08:30 AM
07/13/17 08:30 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Does your IC engine have many ball bearings or high TOT?
SHP @ 100% N2?
We need more info.
"Zed's dead baby, Zed's dead."
Re: Turbine oil in internal combustian engines? [Re: rooflessVW] #4458055
07/13/17 09:50 AM
07/13/17 09:50 AM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
SHP @ 100% N2?
We need more info.
Lots of bleed air though.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Turbine oil in internal combustian engines? [Re: rooflessVW] #4458069
07/13/17 10:05 AM
07/13/17 10:05 AM
Up State NY
SEMI_287 Offline
SEMI_287  Offline
Up State NY
SHP @ 100% N2?
crackmeup
2013 Hyundai Elantra- Bulk, unknown filter
2005 BMW 325xi- M1 0w40, K&N
2007 Chrysler 300C- M1 0w20, Wix
Re: Turbine oil in internal combustian engines? [Re: exShuttlemech] #4458089
07/13/17 10:21 AM
07/13/17 10:21 AM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
I remember reading the history of the Amsoil company. As I recall the founder initially experimented with synthetic turbine oil in his car with disastrous results. That's what sent him on the mission to develop an appropriate internal combustion additive package.
Re: Turbine oil in internal combustian engines? [Re: exShuttlemech] #4458126
07/13/17 10:50 AM
07/13/17 10:50 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The turbine oil I deal with is very thin - as thin as ATF or even thinner!
It is also a non-detergent oil since the oil never sees any combustion by-products.
It can handle a lot of heat, though.... but other than that, it's entire unsuitable for use in piston engines.
Re: Turbine oil in internal combustian engines? [Re: Linctex] #4458174
07/13/17 11:37 AM
07/13/17 11:37 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
There's no crankcase, either. It's a total loss (though very slow) system.
Re: Turbine oil in internal combustian engines? [Re: exShuttlemech] #4458178
07/13/17 11:41 AM
07/13/17 11:41 AM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Some turbine oils are basic group I/II R&O lubes
Re: Turbine oil in internal combustian engines? [Re: Linctex] #4458197
07/13/17 11:55 AM
07/13/17 11:55 AM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
thumbsup
This has been discussed before at least twice, but Jet Engine Turbine oil has a viscosity of about 5.0 cSt or approximately a 0W10. They are primarily composed of Polyol Esters with specialized anti-oxidants and an anti-wear component.
https://bobistheoilguy.com/esters-in-synthetic-lubricants.
The answer is you shouldn't because they DO NOT have the additive composition necessary for IC engine oils, so are definitely unsuitable for your engine.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Turbine oil in internal combustian engines? [Re: MolaKule] #4458213
07/13/17 12:16 PM
07/13/17 12:16 PM
Alabama, United States
Red91 Offline
Red91  Offline
Surely one quart among 4 or 5 quarts of PCMO wouldn't hurt anything. whistle
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Turbine oil in internal combustian engines? [Re: CT8] #4458368
07/13/17 03:07 PM
07/13/17 03:07 PM
North Carolina
North Carolina
Tons of that on this board.
Re: Turbine oil in internal combustian engines? [Re: exShuttlemech] #4458386
07/13/17 03:31 PM
07/13/17 03:31 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Most "turbine" oils are simple R&O oils (rust and oxidation inhibited) and are not suitable for your application.Having spent three decades in power generation, I have seen R&O oils used in all types of applications but never for internal combustion engines. If I recall correctly, R&O turbine oils come in ISO viscosity grades from 32 up to 460. Steam turbines use highly refined R&O oils which are sold as "turbine' oils. I have purchased Mobil DTE 797 turbine oil delivered by semi truck.
Re: Turbine oil in internal combustian engines? [Re: Yah-Tah-Hey] #4458438
07/13/17 04:16 PM
07/13/17 04:16 PM
Virginia
Tom NJ Offline
Tom NJ  Offline
Virginia
True, but the specific oil mentioned by the OP was Exxon 2380, which is an ISO 22 (5 cSt @ 100C) aviation jet turbine oil based on polyol esters (TMP and DiPE).
Molakule's answer was spot on. Too thin and completely wrong additive system.
Tom NJ/VA
Re: Turbine oil in internal combustian engines? [Re: Red91] #4458439
07/13/17 04:18 PM
07/13/17 04:18 PM
Virginia
Tom NJ Offline
Tom NJ  Offline
Virginia
Also wouldn't help anything. Not worth the risk.
