Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
57 registered members (bigal51, Astro_Guy, caprice_2nv, bfleeman, 7 invisible), 1,068 guests, and 45 spiders.
Topics295,173
Posts4,929,148
Members66,700
Most Online2,553
Oct 27th, 2018
10 Mercedes E550 M1 0W40 FS 105,000 mi Fram Ultra #4457887
07/13/17 05:06 AM
07/13/17 05:06 AM
Northern VA
homeyclaus Offline OP
Northern VA
Looks like the Fram Ultra (needed it now, had nothing else available) worked just fine. It didn't collapse, and the orange nitrile gaskets were a nice touch. Bummer they misidentified the engine, but overall the wear metals are low enough that I doubt it matters.
Just did a B service - Purolator air, Mann oil filters, this time PP 0W40 Euro - we'll see how that works out. I for one am not sweating the M1 0W40 FS thing any more.
2013 Toyota Tundra CM 5.7L TRD (M1 0w20/PUP0w40euro, WIX/CQ filter)
2010 Mercedes E550 4Matic (PP 0W40 Euro, Mann)
Re: 10 Mercedes E550 M1 0W40 FS 105,000 mi Fram Ultra [Re: homeyclaus] #4457905
07/13/17 05:50 AM
07/13/17 05:50 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
The engine condition appears superb.
Any proper MB spec'ed oil would easily do 10k with flying colors , I suppose.
Re: 10 Mercedes E550 M1 0W40 FS 105,000 mi Fram Ultra [Re: homeyclaus] #4458005
07/13/17 07:47 AM
07/13/17 07:47 AM
Great White North.. eh
webfors Offline
webfors  Offline
Great report. Thanks for posting.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w20, Fram DL11665
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
Re: 10 Mercedes E550 M1 0W40 FS 105,000 mi Fram Ultra [Re: homeyclaus] #4458044
07/13/17 08:33 AM
07/13/17 08:33 AM
MN
oil_film_movies Offline
MN
Blackstone blew the Universal Averages cuz it should have been the 5.5L V8. It does look like wear is fully in check.
The Fram Ultra worked well, yet I do like the Mann white-fleece oil filter for this application best, as you have switched to.
Mobil, Castrol, or Pennzoil 0w40 are all good choices. Thats a 9-quart sump, meaning you have to buy 2 of the Walmart jugs if you change it yourself.
Re: 10 Mercedes E550 M1 0W40 FS 105,000 mi Fram Ultra [Re: homeyclaus] #4458050
07/13/17 08:44 AM
07/13/17 08:44 AM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
Nice - some of the best #'s I've seen for a 7500 mile run. Good post. I've got M1 0W-40 in my Suburban now and it's going to be in there for at least another 4 years, if not longer - the mileage won't be much though.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: 10 Mercedes E550 M1 0W40 FS 105,000 mi Fram Ultra [Re: homeyclaus] #4458122
07/13/17 09:48 AM
07/13/17 09:48 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Nearly no wear at all!
Re: 10 Mercedes E550 M1 0W40 FS 105,000 mi Fram Ultra [Re: oil_film_movies] #4458347
07/13/17 01:45 PM
07/13/17 01:45 PM
Northern VA
Northern VA
Blackstone sent me the updated report with the 5.5L averages - they look nearly the same to me, which makes sense, since the engines are very similar in terms of material composition. The M273 had a 4-something liter version, and aside from the pre-2008 M27x engines with the dissolving timing chain idler you'd expect the numbers to have a lot in common.
Yeah, 9 quarts, it's a total pain to pull the drain pan out from the car with that much in it, and the oil initially comes out with enough force that it splashes on a crossmember. I put a Fumoto valve on it this time.
Re: 10 Mercedes E550 M1 0W40 FS 105,000 mi Fram Ultra [Re: homeyclaus] #4459262
07/14/17 12:03 PM
07/14/17 12:03 PM
Ontario, Canada
OVERKILL Online content
OVERKILL  Online Content
Ontario, Canada
Great report, nothing abnormal, I'd keep doing what you are doing. Flash point also stayed nice and high indicating very minimal fuel in the oil thumbsup
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: 10 Mercedes E550 M1 0W40 FS 105,000 mi Fram Ultra [Re: OVERKILL] #4459278
07/14/17 12:19 PM
07/14/17 12:19 PM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
I'm wondering if you noticed that for the same reason I did. I would expect the V8 to be a bit thirsty and have the typical high performance tune that uses fuel as coolant. May indicate enthusiastic driving or just typical ridiculous teutonic accuracy in fuel injection metering...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: 10 Mercedes E550 M1 0W40 FS 105,000 mi Fram Ultra [Re: homeyclaus] #4459281
07/14/17 12:21 PM
07/14/17 12:21 PM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
It gets a bit hysterical around here now and then. Still a fine oil...
Re: 10 Mercedes E550 M1 0W40 FS 105,000 mi Fram Ultra [Re: SteveSRT8] #4459283
07/14/17 12:22 PM
07/14/17 12:22 PM
Ontario, Canada
Ontario, Canada
Sure did, LOL! wink cheers
