2018 chevy express passenger van
by Fitter30 - 04/04/20 04:01 PM
Twilight Zone
by 2015_PSD - 04/04/20 03:57 PM
Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
93 registered members (ammolab, 2015_PSD, another Todd, 41Pack, 55hambone, 7 invisible), 2,232 guests, and 17 spiders.
Topics303,591
Posts5,237,895
Members71,094
Page 1 of 4 1 2 3 4
New 2017 silverado 5.3 v8 oil #4457874 07/13/17 05:36 AM
M
miteclipse Offline OP
M
Hi
Truck call for 0w20 dexos. Thinking about using 10w30 QS synthetic for more protection. Should I go with that or use 0w20/5w30 QS synthetic? What about qsb/pyb 10w30?
Thanks
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4457880 07/13/17 05:51 AM
Slick17601 Offline
Why? The engine is designed for 0W-20.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4457888 07/13/17 06:07 AM
M
M
My reason being was posted in my thread
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4457893 07/13/17 06:17 AM
J
JoelB Offline
J
A heavier weight won't give you better protection. I'd stick with the 0w20 unless i was doing a lot of towing.
Mine: 2020 Corolla SE
Factory fill
OE Filter
Wife's: 2018 Chevy spark 1.4 Non-turbo
Mobil 1 0w20 AFE
ACDelco UPF64R
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4457895 07/13/17 06:19 AM
SilverFusion2010 Offline
I like 10w-30, I've not had to deal with the cylinder deactivation stuff though. Try it, if it throws a MIL then go to the 5w-30
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4457902 07/13/17 06:47 AM
B
barkingspider Offline
B
I would also stick w OEM spec oil at least until after warranty is reached. Perhaps try 0w30.
04 Avalanche Z71 4x4
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4457903 07/13/17 06:48 AM
F
FordCapriDriver Offline
F
A 30 grade probably won't give you any better wear protection, but it wouldn't hurt the engine either.
I would stay with a Dexos 0W-20 so you don't void the warranty, if something were to go wrong with the engine and they noticed that you didn't use a the oil they wanted you to use.
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Whatever keeps the lifters quiet...
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4457907 07/13/17 06:53 AM
F
F
Mobil 1 0W-30 AFE is a thin 30 grade and works fine in engines sepc'd for 0W-20, really most manufacturers now spec 0W-20, because it improves their Corporte Average Fuel Economy ( CAFE ), Althouh others spec it because of fancy complicated variable valve timing systems that function based on oil pressure.
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4457954 07/13/17 08:05 AM
Rat407 Offline
Sure, run the 10w-30, it will not protect any better than the 0w-20. MPG might take a hit but other than that go for it.
2002 Silverado 5.3 5w-20 AMSOIL
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4457999 07/13/17 08:43 AM
A
AirgunSavant Offline
A
I'd stay in the 0 or 5w20 range- not much difference between the two
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4458015 07/13/17 08:54 AM
A
ARCOgraphite Offline
A
If this engine uses hydraulic VVT, then you will loose low end torque - something these engines in this application cannot afford to loose. See how it breaks in and runs after 2K miles. If it gets "clanky" when hot, substitute in a qt or 2 of of 10w30. No one will know if its the same line of product. Dealer Warranty concerns expressed here are silly. They just want to see oil between the lines on the dipstick and proof of a decent OCI.
ON my rogue with VVT you have to tailor the oil vis to get the VVT in the sweet spot for your driving style. I had to dump at qt and sub in a qt of 5w20 to thin the oil a bit. Other wize the car was mired in mud. at low rpm due to the VVT being under advanced due higher oil pressure.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: New 2017 silverado 5.3 v8 oil [Re: JoelB] #4458027 07/13/17 09:12 AM
B
bigt61 Offline
B
+1 I agree - towing causes extra stress. Also - where does the OP live - 5W or 10W-30 might be more acceptable in Florida as opposed to North Dakota. But either way, unless towing a lot, I'd stick with the 0W-20 - lots of people have used it in trucks with no issues.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4458040 07/13/17 09:26 AM
sopususer Offline
Former 2014 Silverado 5.3 owner and now 2017 GMC Sierra 5.3 owner..... nothing but 0W-20 for both of my DI 5.3's and no drama, no usage, no noise. I'd vote to stay with the GM engineers on this one.
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4458041 07/13/17 09:26 AM
Rat407 Offline
I ran 0w-40 in a VVT 3.6 when we had our Acadia. Didn't notice any difference. Ran fine and the UOA came back the same as when I ran 5w-30. Changed oil at 5k miles every time. That is when the OLM was down to 0%.
Re: New 2017 silverado 5.3 v8 oil [Re: miteclipse] #4458059 07/13/17 09:56 AM
U
userfriendly Offline
U
The 4.3L V6 truck and 6.2L Corvette has the same AFM system and both are 5W30 engines.
What would happen if you put 5W30 Dexos in a 5.3L, would it blow up?
Page 1 of 4 1 2 3 4
