Cleanliness
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
93 registered members (69GTX, 4WD, 99Eclipse, 2009Edge, -SyN-, 10 invisible), 1,818 guests, and 46 spiders.
Topics295,176
Posts4,929,248
Members66,700
Most Online2,553
Oct 27th, 2018
Permatex Rust Treatment... #4457713
07/12/17 08:15 PM
07/12/17 08:15 PM
WI.
dblshock Offline OP
dblshock  Offline OP
WI.
Started doing the T4R frame...impressive stuff
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Permatex Rust Treatment... [Re: dblshock] #4457772
07/12/17 09:58 PM
07/12/17 09:58 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
I haven't had success, even with mildly rusty hand tools that were put back in a drawer. OTOH I haven't tried topcoating it.
Re: Permatex Rust Treatment... [Re: dblshock] #4457917
07/13/17 06:18 AM
07/13/17 06:18 AM
MA.
Camprunner Offline
Camprunner  Offline
MA.
I did something similar just the other day to my 2012 Nissan Pathfinder I had very little rust but wanted to keep it that way. The whole key is in the prep if the coating will stick or not did you prep the serfice at all? With my frame I washed it with a rag and CRC brake clean to remove any oil or dirt before spraying with a high grade Ruberized undercoating.
Some say not to use Ruberized undercoating and others say that is what you should use? So we will see how it holds up I really think it's all in the prep. What is the Permatex coating? Is it a paint or Ruberized undercoating?
Re: Permatex Rust Treatment... [Re: dblshock] #4457923
07/13/17 06:26 AM
07/13/17 06:26 AM
MA.
Camprunner Offline
Camprunner  Offline
MA.
The key to it in the rust belt is to keep up with it you should check it every year hear in Massachusetts the brine they use on the roads is 12 times more corrosive then rock salt cars and trucks show rust so quickly after purchase it's crazy!
Re: Permatex Rust Treatment... [Re: dblshock] #4457944
07/13/17 06:53 AM
07/13/17 06:53 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
What Permatex product? Pictures in a year would be good.
2015 Ford F250 w/Powerstroke
Re: Permatex Rust Treatment... [Re: dblshock] #4457972
07/13/17 07:20 AM
07/13/17 07:20 AM
MN
ZebRuaj Offline
ZebRuaj  Offline
MN
But did/can you get the stuff inside the frame? That's the key.
I need to redo mines too. Been using Fluid Film because I can get it sprayed inside the little holes of the frame.
~Shade tree mechanic for friends and family.
Re: Permatex Rust Treatment... [Re: ZebRuaj] #4457975
07/13/17 07:26 AM
07/13/17 07:26 AM
MA.
Camprunner Offline
Camprunner  Offline
MA.
Yes getting it inside the frame is the key! One of the best products to use inside and outside the frame is Cosmoline you can buy it in cans or larger quantities and you don't have to reapply it every year just touch up some areas. My next new car or truck I will give it a complete Cosmoline treatment.
Re: Permatex Rust Treatment... [Re: ZebRuaj] #4457976
07/13/17 07:26 AM
07/13/17 07:26 AM
Onondaga County
Miller88 Offline
Miller88  Offline
Onondaga County
Yep! They rust from the inside out
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
Re: Permatex Rust Treatment... [Re: dblshock] #4458118
07/13/17 09:46 AM
07/13/17 09:46 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The CarWell shop has a 30" (approximately) wand to get the product into the frame box and body cavaties.
Re: Permatex Rust Treatment... [Re: dblshock] #4458147
07/13/17 10:12 AM
07/13/17 10:12 AM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Guys. This is a rust converter, not an undercoat...
Re: Permatex Rust Treatment... [Re: dblshock] #4458200
07/13/17 10:58 AM
07/13/17 10:58 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
That brake doesn't like a Girling or ATE.
Re: Permatex Rust Treatment... [Re: Ethan1] #4458205
07/13/17 11:08 AM
07/13/17 11:08 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Correct and a good primer and top coat over it is a very good idea. A top coat alone is OK, a primer and top coat is even better.
God Bless Our Troops
Re: Permatex Rust Treatment... [Re: dblshock] #4458243
07/13/17 11:50 AM
07/13/17 11:50 AM
NorthEast
Vikas Offline
Vikas  Offline
NorthEast
can somebody explain what am I supposed to learn from the 4 pictures posted? is there some previous context such as one side got rust treatment 2 years ago etc?
Re: Permatex Rust Treatment... [Re: dblshock] #4458698
07/13/17 07:17 PM
07/13/17 07:17 PM
WI.
dblshock Offline OP
dblshock  Offline OP
WI.
it's some sort of acid that coverts rust to a protective blob of whatever..looks like black burnt plastic..the most important parts to protect are in the wheel wells especially suspension mounts..here's a linky
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Re: Permatex Rust Treatment... [Re: dblshock] #4458703
07/13/17 07:22 PM
07/13/17 07:22 PM
WI.
dblshock Offline OP
dblshock  Offline OP
WI.
I just knocked the loose flakes off with a small chisel the compressed air to clean it up..it converts the rust so probably requires some to activate.
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
