Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
82 registered members (2010Civic, 2015_PSD, alarmguy, aquariuscsm, Astro_Guy, 6 invisible), 1,241 guests, and 48 spiders.
Topics286,107
Posts4,902,720
Members67,563
Most Online2,967
Mar 10th, 2019
Shelf life of ATF? #4457706
07/12/17 09:13 PM
07/12/17 09:13 PM
New Orleans
podan Offline OP
podan  Offline OP
New Orleans
I picked up 5 quarts of Honda ATF DW1 from an individual for next to nothing. Looking at the bottles (which have never been opened), the silver has a faint reddish color showing through, almost like the ATF bleeding through the plastic? It's hard to describe. Now I've made myself paranoid - could this stuff be so old that it's not good anymore? I opened one, and the fluid looks and smells just like any other I have purchased for the dealer (at triple the price).
Any ideas? Thanks!
Re: Shelf life of ATF? [Re: podan] #4457725
07/12/17 09:30 PM
07/12/17 09:30 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
It's fine.
Re: Shelf life of ATF? [Re: podan] #4457730
07/12/17 09:33 PM
07/12/17 09:33 PM
in the shop
sw99 Offline
sw99  Offline
in the shop
Dont use it, it's contaminated. I take it off your hands...
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2019 Ford F250 6.7L CCSB
Re: Shelf life of ATF? [Re: podan] #4457763
07/12/17 10:39 PM
07/12/17 10:39 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Reminds me to use my Dex 6....
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: Shelf life of ATF? [Re: podan] #4457784
07/12/17 11:21 PM
07/12/17 11:21 PM
Dallas, Texas
SuperDave456 Offline
Dallas, Texas
Quart bottles of oils (atf included) don't seem to seal well.
I bought something like 20 quarts of Maxlife ATF when a local Pep Boys was going out of business.
Most of them were pretty dusty, but that was 10 years ago.
I used up the last of the Maxlife ATF a few weeks ago, it is Dex III approved, and the 2004 Nissan Xterra is running like a champ.
I still have 5 quarts of Pennzoil Mercon V that I need to use up.
Will probably take me a few years as I am down to 1 Ford that uses Mercon V.
BTW, this fluid was stored in an attached garage in north Texas.
If it's in a bottle with a lid, and kept in an ok environment, it will last almost forever.
Re: Shelf life of ATF? [Re: podan] #4457831
07/13/17 02:00 AM
07/13/17 02:00 AM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
My bottles of DW-1 I ordered from a Honda dealership online Bernardi Honda (that presumably sees high volume of sales of the fluid) has the same thing. Every single quart I received has the same thing.
I chalked it up to a thin and flexible bottle design. After the quart is empty, try squeezing the bottle. Actually you can just squeeze the bottle while it's unopened, it's way more flexible and the walls are much thinner than other quarts I've used for things like engine oil that are far more rigid.
2015 Civic LX Coupe
Re: Shelf life of ATF? [Re: podan] #4457853
07/13/17 04:19 AM
07/13/17 04:19 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
The end result of the "oil stash".
The "thinking" man's friend.
Re: Shelf life of ATF? [Re: podan] #4457897
07/13/17 06:25 AM
07/13/17 06:25 AM
Glendale, Arizona
billt460 Online content
billt460  Online Content
Glendale, Arizona
The red color in ATF is dye. It's an industry standard to distinguish it from regular motor oil. Dye will color anything that is the slightest bit porous, that it comes into contact with over time...... Like the plastic bottles ATF is packaged in. It's the reason why Laundromats have signs everywhere saying, "No Dye!" Over time it will color the plastic agitators and rubber parts in the machines. This can then transfer into your clothes. Especially during long duration hot wash cycles. If you use dye in your home washing machine, you should run the machine empty through several COLD rinse cycles afterward, in order to prevent this kind of color contamination of the plastic parts.
Re: Shelf life of ATF? [Re: podan] #4457900
07/13/17 06:38 AM
07/13/17 06:38 AM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
Any ideas? Thanks!
your paranoid...go see a shrink.
Re: Shelf life of ATF? [Re: podan] #4458112
07/13/17 10:41 AM
07/13/17 10:41 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
It's garbage, mail it to me! grin
Originally Posted By: billt460
The red color in ATF is dye. Dye will color anything that is the slightest bit porous,
100% correct
Re: Shelf life of ATF? [Re: podan] #4458152
07/13/17 11:17 AM
07/13/17 11:17 AM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I'll use it for you and let you know! I'd bet that if it can handle being in the transmission for 60,000 miles or 5 years, it'll be fine sitting on a shelf for much longer.
Re: Shelf life of ATF? [Re: podan] #4458317
07/13/17 02:15 PM
07/13/17 02:15 PM
Ohio
hallstevenson Offline
Ohio
Shelf life ? What does the expiration date on the bottle say ? Oh wait, there's isn't one....
Re: Shelf life of ATF? [Re: podan] #4458752
07/13/17 09:17 PM
07/13/17 09:17 PM
Vancouver, Canada
dubber09 Offline
dubber09  Offline
Vancouver, Canada
IMHO, ATF and engine oils are good for at least 2 years of shelf life with no major degradation.
I got 2 years worth of oil and up to 2 years worth of ATF on hand. I don't feel there is need to have more that 2 years worth of those on hand.
The reasons I stock - I buy then price is low and to bring stock up to 2 years supply.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: Shelf life of ATF? [Re: dubber09] #4458762
07/13/17 09:30 PM
07/13/17 09:30 PM
ohio
xtell Offline
xtell  Offline
ohio
If a lubricant is in a sealed container from the factory and if it is kept in a moderate temperature environment, say 70 degrees, is it safe to assume that it has an indefinite shelf life?
