Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
114 registered members (53' Stude, 38Chevy454, 77GrandPrix, 14Accent, 1WildPig, 240_Ed, 9 invisible), 2,061 guests, and 62 spiders.
Topics286,203
Posts4,904,118
Members67,576
Most Online2,967
Mar 10th, 2019
Ford power steering o-rings #4457518
07/12/17 06:15 PM
07/12/17 06:15 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
So in the middle of a power steering pump replacement on a Ford 4.2L. Just about done, actually. Put the new teflon o-ring on the high pressure fitting, threaded everything together. Well, the metal hard line coming out the bottom of the pump through the teflon o-ring fitting was rather loose and could be rotated easily after torquing the fitting. I have to assume this is not normal. does anybody have experience with this application? My reman Napa pump came with a new teflon ring which I used as well as a new nitrile rubber o-ring, of smaller diameter, which I did not use since none like that were present on the original assembly. Should this go on the tip of the high pressure line fitting>?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Ford power steering o-rings [Re: buck91] #4457524
07/12/17 06:20 PM
07/12/17 06:20 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
There are 2 common teflon o-ring numbers N808898-S is about the size of a dime. N808897-S is a bit smaller. It is one of those 2.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Ford power steering o-rings [Re: buck91] #4457528
07/12/17 06:22 PM
07/12/17 06:22 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Yes, the teflon o-ring isn't the issue. The metal line seems loose in the fitting after torquing. Is there a seconardy o-ring needed? Is it normal to have the line loose with the fitting tight?
2011 F150 4x4 5.0L
Re: Ford power steering o-rings [Re: buck91] #4457529
07/12/17 06:23 PM
07/12/17 06:23 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Did the pump come with instructions? The new master cylinder to the Rat contained directions on how to bleed it. Good thing, because I never would have figured it out. grin2
Thick oil is better grin2
Re: Ford power steering o-rings [Re: buck91] #4457530
07/12/17 06:24 PM
07/12/17 06:24 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Just generic instructions. The baggy with the teflon o-ring and second, smaller o-ring only contain instructions on the teflon o-ring install.
2011 F150 4x4 5.0L
Re: Ford power steering o-rings [Re: buck91] #4457573
07/12/17 07:11 PM
07/12/17 07:11 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
I know on my truck which is older, the metal line can rotate in the fitting after torquing. If it doesn't leak, you're good.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Ford power steering o-rings [Re: buck91] #4457583
07/12/17 07:23 PM
07/12/17 07:23 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
^ X2. Pretty sure the line is supposed to be able to turn since one end is bolted to your steering/frame and the other to an engine mounted part. It moves on my trucks. The rubber o-ring is the primary seal and the teflon stops seepage from that.
If there are no leaks, you are good.
*Edit...re-read...so you didn't see any rubber o-ring when you took the high pressure line off the pump? There should be one on the line and the teflon goes on the fitting.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 227K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 201K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 247K miles
Re: Ford power steering o-rings [Re: buck91] #4458209
07/13/17 12:11 PM
07/13/17 12:11 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Well after pulling it apart and futzing with a junky Dorman replacement o ring, seems to be all set.
FWIW, the Harbor freight pulley remover and installer works ok. Except for installing. Thrust bearing seized and threaded adaptor snapped off inside the pump shaft before the pulley was fully seated. Still about 1/8in too far out ... But belt runs smooth and silent...?? Probably going to leave it for now.
Not sure how to imbued, but here's a short vid.
https://youtu.be/HHDNqx4nwd4
Edit: wow just watch the clip. Terrible Mic pick up. Only noise I was hearingn was the fan and a throttle body with the rest of the intake off.
2011 F150 4x4 5.0L
