Cleanliness
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
100 registered members (69GTX, 4WD, 1foxracing, 2K2AcuraTL, 64bawagon, 2009Edge, 8 invisible), 1,705 guests, and 52 spiders.
Topics295,175
Posts4,929,223
Members66,700
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
'13 Tundra - TRD or Amsoil filter vs. OEM #4457339
07/12/17 01:48 PM
07/12/17 01:48 PM
U.S.
Hal3134 Offline OP
Hal3134  Offline OP
U.S.
I just stumbled across this forum and have been doing some research. I've always been a fan of using the best oil, and even, more importantly, the best oil filter for my vehicles. Current vehicle is a '13 Tundra with the 5.7 flex engine. I tow a 6,000 lb. travel trailer a few weekends a year.
I just learned that the TRD filters fit my Tundra engine. I also read a lot of good things about the Amsoil filters. From secondhand information, it seems like both filters claim a 98% reduction in particulates at a 20 micron size. I haven't been able to find any data on my OEM paper filter, but going to the full synthetic filter (both TRD and Amsoil) I expect an improvement in filtering.
If it matters I'm likely going to use Penzoil Platinum oil. Mobil 1 is also a smaller possibility.
Are the TRD and Amsoil pretty equivalent? Do you recommend a different filter?
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Hal3134] #4457377
07/12/17 02:20 PM
07/12/17 02:20 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Why not just run factory filters. Unless your truly extending intervals stock fliters are cheap and are pretty good.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Hal3134] #4457389
07/12/17 02:36 PM
07/12/17 02:36 PM
U.S.
Hal3134 Offline OP
Hal3134  Offline OP
U.S.
I guess that depends on how well the basic OEM filters perform. My research suggests that they are offer significantly less performance, although I've had to crib that together from anecdotal evidence. For the extra $10 per oil change I'm happy to use a higher quality filter. I tend to keep my vehicles until they are almost unfixable (e.g. engine rebuild needed).
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Hal3134] #4457393
07/12/17 02:38 PM
07/12/17 02:38 PM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
If you are concerned that the OEM filter is detrimental in the long run. then that sounds like what you should do.
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Hal3134] #4457431
07/12/17 03:34 PM
07/12/17 03:34 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Are you going to double stint the TRD filter since it's so high end?
I did a UOA on the Camry at the 60k mark and filtration and wear results were excellent using the oem filter.
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Hal3134] #4457432
07/12/17 03:36 PM
07/12/17 03:36 PM
Waco, Tx.
Syntheticuser Offline
Waco, Tx.
If you are wanting particle removal, look into a Microgreen oil filter. There were tests on this site comparing it to a K&N oil filter. The MG had over 50% less particles tested in the oil. That's why I run them. Great filters but a bit pricey. Worth it. Use a good quality oil, PP is good. You will be set.
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: SatinSilver] #4457435
07/12/17 03:42 PM
07/12/17 03:42 PM
U.S.
Hal3134 Offline OP
Hal3134  Offline OP
U.S.
If by double stint you mean swap it out every other oil change, then the answer is no, probably not. The cost of the oil filter is a small investment in the life of my Tundra.
I'm happy to change my mind and save a few bucks, however, when I see some data that says that would be ok to do.
What is "UOA"?
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Syntheticuser] #4457437
07/12/17 03:44 PM
07/12/17 03:44 PM
U.S.
Hal3134 Offline OP
Hal3134  Offline OP
U.S.
Thanks, any data/opinions on how it compares to the TRD and Amsoil filters?
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Hal3134] #4457442
07/12/17 03:49 PM
07/12/17 03:49 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
The Fram Ultra is approaching 99.9% @ 20 microns and 80% @ 5 microns.
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Hal3134] #4457451
07/12/17 03:55 PM
07/12/17 03:55 PM
Waco, Tx.
Waco, Tx.
Hal,
No sir. I was told by a rep that it is 80% @25-40 micron and 96% @5 micron. It is a bypass type oil filter with a regular element. Two filters in one.
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Syntheticuser] #4457452
07/12/17 03:58 PM
07/12/17 03:58 PM
U.S.
Hal3134 Offline OP
Hal3134  Offline OP
U.S.
Hal,
Shouldn't the smaller particle size have the lower percentage?
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Hal3134] #4457457
07/12/17 04:03 PM
07/12/17 04:03 PM
Waco, Tx.
Waco, Tx.
The main filter is basically a rock catcher...the bypass part is a round super dense disk. Look it up, it's really cool how they did it.
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Syntheticuser] #4457460
07/12/17 04:08 PM
07/12/17 04:08 PM
Upper Midwest
Upper Midwest
It may be really cool but there is no ISO 4548-12 data published by microGreen to show it is any better or worse than any other filter. Multiple people here have requested such data from them but to no avail.
Please provide a link to the test you reference against the K&N filter.
1994 BMW 530i, 238K
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Hal3134] #4457461
07/12/17 04:10 PM
07/12/17 04:10 PM
Upper Midwest
Upper Midwest
No data. microGreen does not publish the results of any ISO 4548-12 tests they may have performed.
1994 BMW 530i, 238K
Re: '13 Tundra - TRD or Amsoil filter vs. OEM [Re: Hal3134] #4457467
07/12/17 04:20 PM
07/12/17 04:20 PM
U.S.
Hal3134 Offline OP
Hal3134  Offline OP
U.S.
Any takers on this?
Page 1 of 3 1 2 3
