Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
35 registered (bbhero, BusyLittleShop, carviewsonic, clinebarger, Charlie2015, 2 invisible), 994 Guests and 37 Spiders online.
65282 Members
67 Forums
285682 Topics
#4457096 - 07/12/17 09:56 AM Old Stock Fram Tough Guard TG8316 (Circa 2003)
mooferz Offline
Loc: TX
This is my first time cutting open a filter. Used an angle grinder on the crimp seam, which recently saw suggested.
Used this clearance $1.50 Walmart Toughguard TG8316 circa 2003 as a transmission filter for a few thousand miles on my ES300.
This is an engine oil filter and isn't meant for transmission or hydraulic applications. Using it was probably a bad idea in multiple ways (it's old, the anti siphon valve might create backpressure or be too restrictive etc... oh and it was DENTED mad), but at least still looks pretty good for something that spent 13 years on a Walmart shelf.
2003 date code.
Bypass valve looks good, and Toughguards of the time featured a screen over it- like you still see in the Fram Racing filters.
Anti siphon valve works well
ADBV really pliable (a tad thin?)
Didn't notice that dent till taking this picture. Though I don't think it interfered with the function of the filter.
Definitely wouldn't have run it had I noticed the dent.
Edited by mooferz (07/12/17 10:11 AM)
Edit Reason: missing pics
2001 Lexus ES300, 235k mi, German Castrol 0w-40, Fram TG8316
1985 BMW R80RT (1L)- M1 15w-50
1993 Volvo 945 Turbo- Rotella T5 10W-30 (CJ-4)
#4457128 - 07/12/17 10:38 AM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: mooferz]
AirgunSavant Offline
Loc: MD
Looks great for that old. Thanks for the c&p
#4457130 - 07/12/17 10:40 AM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: mooferz]
Kuato Offline
Loc: Colorado
Yes, thanks! Filter looks great. thumbsup
Thick vs Thin test: 15k / 43k miles complete
#4457136 - 07/12/17 10:46 AM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: mooferz]
CT8 Offline
Loc: Idaho
I find it interesting how Fram quit using the bypass screen.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4457138 - 07/12/17 10:47 AM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: mooferz]
i_hate_autofraud Offline
Loc: Canada
I'm surprised there was enough room under the hood on a ES300 for a filter head and filter for your tranny!!
Do you have install Pics how you had it put in?
#4457152 - 07/12/17 11:07 AM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: CT8]
Linctex Offline
Loc: Waco, TX
It's an added cost.... and doesn't really do anything - EXCEPT in engines that are really, really, really sludged bad, it might MAYBE keep some extremely large debris from getting back into the clean oil side.
#4457158 - 07/12/17 11:13 AM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: i_hate_autofraud]
mooferz Offline
Loc: TX
I mounted the filter in front of the radiator, rigged up a mount using metal from an old external 5.25" floppy drive case, and fixed it in place through existing holes in the hood latch mount(?) with some nuts, washers, and threaded rods. It fits perfectly between the two sections of the bash bar, though I'm sure to get transmission fluid everywhere in the event of a front collision.
Edit: Now that I think about it, there's nothing preventing the filter being dented by road hazards in its current position. I might check the junk yard soon- I think it's missing an under panel.
The coolant loop comes out from the transmission, through the filter, then through a B&M 70264 cooler mounted to the radiator on the drivers side, then back to the return. The radiator's built in transmission cooler has been bypassed and capped off.
(Those aren't boogers, it's Fluid Film. wink )
#4457185 - 07/12/17 11:41 AM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: mooferz]
car51 Offline
Loc: Southwest PA
Thanks for the write up and pics smile
2009 Toyota Camry LE
#4457288 - 07/12/17 01:35 PM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: mooferz]
JoelB Offline
Loc: Minnesota
Why do this? The built in filters do the job just fine.
2018 Nissan Sentra 1.8
Factory fill
2014 Chevy sonic 1.8
Mobil 1 5w30
AcDelco filter
#4457303 - 07/12/17 01:51 PM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: JoelB]
CT8 Offline
Loc: Idaho
This filters finer !
Geoff Metcalf
#4457328 - 07/12/17 02:35 PM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: mooferz]
Linctex Offline
Loc: Waco, TX
There was no need to change this filter now, nor will there ever be at any point in the future. That filter will last longer than the life of the car/transmission in this application.
Most transmission filters are approx 100 microns, or so I've read.
Yes, they generally do just fine. However, I do a LOT of towing.
I run a Wix 51551 (about the size of an FL-1a or PH8A)
I wanted the extra insurance. The huge Wix should last the life of the truck, easily.
#4457564 - 07/12/17 07:04 PM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: mooferz]
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
That old filter appears to have more pleats than what Fram Tough Guard uses today. Plus the top and bottom look more like plastic, than fiber.
#4457647 - 07/12/17 08:23 PM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: mooferz]
Loc: Canada
Nice!
#4457971 - 07/13/17 08:18 AM Re: Old Stock Fram Tough Guard TG8316 (Circa 2003) [Re: Linctex]
mooferz Offline
Loc: TX
You're absolutely right.
I just opened up the first filter I used in this application (will make a thread later, Hiflofiltro HF163 ca. 2010) and did find a little discoloration of the filter media, but it looked about as pristine as this Toughguard. The XG16 I've got on it now will definitely stay there till at least the next ATF flush.
When I first installed the spin on filter, I decided to change between different filters and work up the "ladder" of filtering efficiency. as it were. Yes, this is wasteful and I now know to be ill conceived considering how filtering beta ratios actually work. This kind of thing happens when one needlessly overthinks things, and has a bunch of cheap clearance oil filters in one's stash that will otherwise last till 2022. crazy
