Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
wsalopek, jcr1293, maxwellk, BlueFog, Frank_G35
66682 Registered Users
86 registered members (bdcardinal, 53' Stude, AZjeff, bbhero, Anduril, 13 invisible), 1,839 guests, and 40 spiders.
Topics295,064
Posts4,927,140
Members66,681
Most Online2,553
Oct 27th, 2018
CK-4 HDEO vs CJ-4 HDEO #4457082
07/12/17 08:44 AM
07/12/17 08:44 AM
wv
krismoriah72 Offline OP
wv
I have seen a few posts in other forums etc. where people are hoarding up the CJ-4 oils in fear that that CK-4 is not going to be as good for powersport/motorcycles etc..by looking at the numbers it appears that CK-4 has a higher TBN and more add pack? This is referencing the rotella 15w40 in this case. What is the fear of the CK-4??
http://www.pqiamerica.com/May%202013/rotella.htm
http://pqiadata.org/Shell_Rotella_T4_15W40_4192017.html
CJ-4 TBN- 9.4 Calcium 2321 Phosphorus 965 Zinc 1098 Boron 37
CK-4 TBN- 10.27 Calcium 2295 Phosphorus 1080 Zinc 1203 Boron 207
Re: CK-4 HDEO vs CJ-4 HDEO [Re: krismoriah72] #4457094
07/12/17 08:55 AM
07/12/17 08:55 AM
FL
CharlieJ Offline
CharlieJ  Offline
FL
Some of these new CK-4 oils are also rated API SN for gasoline engines which means the have lower Zinc and Phosphorus levels, around 800ppm. That's why some people are saying these newer oils provide less protection.
I just bought a gallon of Mobil Delvac 15w-40 for my generator, it is rated SN.
http://pqiadata.org/Mobil_Delvac_15W40_4192017.html
'07 Mazda3 2.3 Mobil 1 HM 5w-30
'84 Mazda Rx-7 Valvoline Maxlife 10w-30
Re: CK-4 HDEO vs CJ-4 HDEO [Re: krismoriah72] #4457109
07/12/17 09:14 AM
07/12/17 09:14 AM
MD
AirgunSavant Offline
MD
I'm no HDEO expert-not even close
I see my Delo 400 SDE bottle here and I question how it will reduce wear by up to 50%
as it is noted on the front label- CK-4
Of course my new Delvac Super 1300 CK-4 makes no such claims.
Interesting.
Re: CK-4 HDEO vs CJ-4 HDEO [Re: krismoriah72] #4457113
07/12/17 09:17 AM
07/12/17 09:17 AM
USA
ArcticDriver Offline
USA
Here is a Shell document which indicates a TBN of 10 (no tenths provided) for CJ-4 rather than 9.4 that you found.
file:///Users/danielclark/Downloads/GPCDOC_GTDS_Shell_Rotella_T5_15W-40_(CJ-4)_(en)_TDS.pdf
This would put it more in line with the CK-4.
I am really happy to see you have introduced this topic. Hopefully some good facts will be presented.
Multiple Diesel and Gasoline vehicles
Re: CK-4 HDEO vs CJ-4 HDEO [Re: CharlieJ] #4457118
07/12/17 09:23 AM
07/12/17 09:23 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
I agree with this.
If the oil you are buying is not dual rated for gas engine use, then CK4 is good news and nothing to worry about.
What isn't clear to me is if the mfrs are now trying to make their HDEOs dual rated when in the past they weren't. The API SN rating is what lowers those zddp levels.
On a related note, I need to research it more but the oils I see that are JASO MA2 rated also have lower zddp so that would be another thing to watch out for.
Re: CK-4 HDEO vs CJ-4 HDEO [Re: AirgunSavant] #4457168
07/12/17 10:23 AM
07/12/17 10:23 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I see my Delo 400 SDE bottle here and I question how it will reduce wear by up to 50%.
easy. They compare it to city star oil.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: CK-4 HDEO vs CJ-4 HDEO [Re: Chris142] #4457171
07/12/17 10:26 AM
07/12/17 10:26 AM
MD
MD
Yeah that works smile
Re: CK-4 HDEO vs CJ-4 HDEO [Re: CharlieJ] #4457241
07/12/17 11:57 AM
07/12/17 11:57 AM
New York
jeff78 Offline
jeff78  Offline
New York
The API SN 800ppm limit on phosphorous only applies to oils of viscosity grade 30 and lower. The limit does not apply to xxW-40 oils.
This is a good example, because it's one in which the API SN limit for phosphorous does not apply due to the viscosity grade, but the oil formulator chose to limit it anyway. They could have used up to 1200ppm of phosphorous as the 'Standard' column indicates. That's the limit for CK-4.
Re: CK-4 HDEO vs CJ-4 HDEO [Re: jeff78] #4457297
07/12/17 12:46 PM
07/12/17 12:46 PM
USA
USA
I am not attempting to argue BUT this article quotes an industry representative saying something different about "Universal" oils (defined as being both C & S rated):
"“In order for a diesel engine oil to claim an ‘S’ category, it must now meet all of the gasoline category’s criteria, including the limit on phosphorous levels,” Negri continues. “Phosphorous has long demonstrated proven protective qualities versus ashless chemistries in diesel engines, but has also been known to shorten the life of automotive catalyst systems in gasoline engines. This means that diesel engine oil must be below 0.08% phosphorous to claim an ‘S’ category approval [the CJ-4 specification allows up to 0.12% phosphorous].”
The loophole that allows higher phosphorous levels from diesel engine oils when used in gasoline engines will be effectively closed. In practical terms, this will create a clear line in the sand between diesel-only formulations (“high phosphorous”) and universal oils (“low phosphorous”)."
Link:
http://www.fleetequipmentmag.com/demistifying-new-engine-oil-categories-compatibility-ck4-fa4/
Re: CK-4 HDEO vs CJ-4 HDEO [Re: ArcticDriver] #4457329
07/12/17 01:37 PM
07/12/17 01:37 PM
New York
jeff78 Offline
jeff78  Offline
New York
I would say that maybe this representative wasn't fully aware that certain limits in API SN only applied to certain viscosity grades, or maybe got misquoted, or something got lost in translation during article publication.....who knows.
The API SN specification is here, you can see the differences in limits between viscosity grades yourself:
http://www.oilspecifications.org/articles/api-sn.php
If they were to force dual rated diesel oils to have a phosphorous limit of 800ppm even for xxW-40 oils, then they would be going beyond simply meeting all of the gasoline category's criteria.
At any rate, it might be best at this point to wait for VOA's of various CK-4 oils to show up before committing to them. Even if phosphorous limits aren't mandated to the lower 800ppm level, some CK-4 formulas may end up at that level voluntarily like the Delvac above.
Re: CK-4 HDEO vs CJ-4 HDEO [Re: jeff78] #4457380
07/12/17 02:21 PM
07/12/17 02:21 PM
USA
USA
Excellent post and my suspicion as well.
I appreciate the link and do you have one for CK-4 formulations? Like yourself, I am also waiting for VOAs but even more for UOAs !
Thanks
Re: CK-4 HDEO vs CJ-4 HDEO [Re: CharlieJ] #4457985
07/13/17 07:31 AM
07/13/17 07:31 AM
USA
USA
Do you recall what the Phosphorus level was in this same Delvac 1300 in CJ-4 ?
800 is surprisingly low to me.
