Hi again all! I had put a post up a day or 2 ago, regarding thinking my calipers seemed locked up. Thier was a loud siren noise coming from front of car wheel area, grinding noise, and once in a while, the car would run but lock up but try too move. I just installed a new rebuilt NAPA denso starter. Older (1.5 years ago i installed an autozone starter [censored] out), and since the napa starter, is when these things started happen, mentioned above. Well, last night, the car reved and wanted too drive, but would go some feet, then not move,thoughthe negine did want too go/run. Lots of smoke started coming out the tailpipe.....i musta had it at 2-3rpm and the car would just come too a grinding halt. I had tooshut off car, wait like 7 minutes, restart and it would drive a few hundred feet till it would slow down too not moving,yet engine ran fine. Floored the gas pedal many times asthe engine ran, lots of smoke came out, yet it didntbudge or move, tilli turned car off, let it rest some minutes, restart. I did notince the shifting...it seemed too stick when putting it in drive. it eventualy freed up. The car jerked semi violently it seemed. A few blocks before getting home it finaly stopped...stopped on my street and pushed the car down it as 2 neighbors came out too help me. (nice of them).
It seems this happened just after i installed the napa rebuilt denso starter.......
the trasnmission fluid had no smell, it was dark out, you could see it was full, but could not determine its color. flushed it 2 years ago myslef, pulled the return line and all. The original fluid was in bad bad shape. 57,000 miles and never serviced. automatic. Ran fine till i installed the starter.
Could the starter be the culprit? Or.....is the corolla's transmission kaput?
