WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
22 registered members (bmod305, bbhero, chance, arthuro, Char Baby, 2013ecof150, 1 invisible), 805 guests, and 31 spiders.
Topics290,810
Posts4,850,764
Members66,036
Most Online3,590
Jan 24th, 2017
What causes alignment/cam bolts to seize? #4456370
07/11/17 02:42 PM
07/11/17 02:42 PM
Rochester, MI, US, World
Klutch9 Offline OP
Klutch9  Offline OP
I couldn't find a satisfying answer to this question on the internet, so I pose it to you... what causes those cam alignment bolts to freeze inside the bushing? I've worked on plenty of cars; old, rusty ones too, and I've never really had an issue getting big suspension bolts out. Enough PB Blaster and a long breaker bar will solve any problem.
But now I have to replace one of the rear lateral links on the Sedona, and one end is secured by a cam bolt to set the toe in/out. I've heard numerous horror stories about these bolts in particular being absolutely seized to the bushing they pass through, but I can't think of a logical reason why these would freeze more so than a regular bolt. Wouldn't the 'cammed' portion actually provide less metal-to-metal contact, making it easier to remove? Just curious. I've done some work on this van lately, and all bolts have been nearly rust-free and came out easily, even some very large ones. But the cam bolt seems quite rusty in contrast ???
'11 Fusion SE 2.5L - 79k miles - HK 0w20 syn, Wix XP filter
'08 Sedona LX LWB 3.8L - 126k miles - Havoline HM 5w20, Auto7 filter
Re: What causes alignment/cam bolts to seize? [Re: Klutch9] #4456373
07/11/17 02:49 PM
07/11/17 02:49 PM
Ontario Canada
Canadastang Offline
Canadastang  Offline
Ontario Canada
I'm thinking that it's a perfect storm of two washers allowing moisture to get trapped in the sleeve, combined with the extra 'space' around the bolt due to its shape that allows a whole pile of moisture, sand, salt, crud etc to works its way in and get stuck there.
Or maybe whomever's supplying all of these cam bolts is doing a [censored] job of treating them for corrosion resistance.
I've had the same experience too, when all the other bolts come out, the cam bolts get stuck and need a torch and some hammer persuasion.
Re: What causes alignment/cam bolts to seize? [Re: Canadastang] #4456378
07/11/17 02:54 PM
07/11/17 02:54 PM
Klutch9 Offline OP
Klutch9  Offline OP
That's a possibility. My van is from Kentucky and has only experienced 4 Michigan winters, so hopefully it won't be a bear to remove.
Re: What causes alignment/cam bolts to seize? [Re: Klutch9] #4456446
07/11/17 04:14 PM
07/11/17 04:14 PM
California
nthach Offline
nthach  Offline
California
Did the van ever get an alignment in its life? Most techs will torque things down by hand as not to disturb the cams once set, but don't rule out the fact impact tools might be used.
Re: What causes alignment/cam bolts to seize? [Re: nthach] #4456458
07/11/17 04:27 PM
07/11/17 04:27 PM
Klutch9 Offline OP
Klutch9  Offline OP
It's been been aligned once since I bought it (I think). But if the rear toe wasn't out of spec, they wouldn't have been touched.
Re: What causes alignment/cam bolts to seize? [Re: Klutch9] #4456486
07/11/17 05:07 PM
07/11/17 05:07 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Rust.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: What causes alignment/cam bolts to seize? [Re: Klutch9] #4456696
07/11/17 08:34 PM
07/11/17 08:34 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
When doing repairs, I pack these gaps with antiseize to help keep bolts from freezing in their sleeves.
Re: What causes alignment/cam bolts to seize? [Re: Kestas] #4456729
07/11/17 08:55 PM
07/11/17 08:55 PM
Klutch9 Offline OP
Klutch9  Offline OP
I'll be slathering the cammed portion with some moly grease when I put it back together.
