4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
66 registered members (97prizm, ad_infinitum, 4WD, 2010Civic, 5 invisible), 1,377 guests, and 65 spiders.
Topics286,042
Posts4,901,393
Members67,551
Most Online2,967
Mar 10th, 2019
RockAuto UltraFast Toyota copy used oil filter cut #4456085
07/11/17 10:34 AM
07/11/17 10:34 AM
Jacksonville, FL
FlyNavyP3 Offline OP
Jacksonville, FL
Hey guys as promised here are the pics of the Toyota copy filter I previously posted the virgin cut pics of. This filter was in use for 5515 miles with PYB SAE 30 in my 2004 Lexus ES330. No drama here looks good. ADBV was a little stiff but still pliable. ADBV action after removing the filter wasn't great as it leaked oil when turned over. No startup issues noted in use. It was good enough for me to spin on another one to run for another 5k.
A UOA with particle count to compare with the previously run Fram Ultra is forthcoming.
Luke
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: FlyNavyP3] #4456124
07/11/17 11:19 AM
07/11/17 11:19 AM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Filter element looks great. Thanks for sharing.
too many cars and oil combinations to list in 150 characters or less
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: FlyNavyP3] #4456139
07/11/17 11:28 AM
07/11/17 11:28 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
We never did determine the COO for these in that other thread.
We don't see the louvered center tubes in China made filters that I know of.
I still find it interesting these have the "P" style gasket, you just don't see that often.
Looks good overall, and interested to see the particle count.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: FlyNavyP3] #4456201
07/11/17 12:25 PM
07/11/17 12:25 PM
MD
AirgunSavant Offline
MD
Looks clean-thanks
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: FlyNavyP3] #4456318
07/11/17 01:52 PM
07/11/17 01:52 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Looks good and did you put VWB SAE 30 or PYB SAE 30?
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: 53' Stude] #4456667
07/11/17 08:15 PM
07/11/17 08:15 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
His post says PYB.
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: 53' Stude] #4456766
07/11/17 09:34 PM
07/11/17 09:34 PM
Jacksonville, FL
Jacksonville, FL
Refilled with Valvoline SynPower 20w50 from end of the year clearance sales. Moving into the hottest part of the summer here so I figured why not. Will run it another 5k and refill with something else from the stash.
Luke
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: FlyNavyP3] #4457722
07/12/17 09:27 PM
07/12/17 09:27 PM
in the shop
sw99 Offline
sw99  Offline
in the shop
Looks like it did a fine job. I would use those all day long. Thanks.
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2019 Ford F250 6.7L CCSB
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: sw99] #4460976
07/16/17 02:14 PM
07/16/17 02:14 PM
Jacksonville, FL
Jacksonville, FL
We will see what the UOA and particle count shows. Either way it worked and didn't tear in the 5,500 miles it was on the car with SAE 30 oil in use. So in other words better than some Purolator filters...
Luke
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: FlyNavyP3] #4461022
07/16/17 03:19 PM
07/16/17 03:19 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
LOL! You're correct as I have reservations on using my Bosch Distance +
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: 53' Stude] #4461040
07/16/17 03:53 PM
07/16/17 03:53 PM
blupupher Offline
blupupher  Offline
That is the only Puro made filter I don't have a problem using (I have 4-5 in my filter stash).
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: FlyNavyP3] #4465284
07/20/17 06:19 PM
07/20/17 06:19 PM
Jacksonville, FL
Jacksonville, FL
So, my UOA came back on this filter run complete with particle count...
The results were, well, surprising.
It was run for a shorter distance but it was a conventional oil, and the PC is cleaner than with PUP and a Fram Ultra... see below for yourself.
UOA with particle count compared to Fram Ultra filter
Luke
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: FlyNavyP3] #4465364
07/20/17 07:20 PM
07/20/17 07:20 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
It's too easy to get caught up in marketing that anything synthetic is automatically best. A cellulose media has nature's randomness, synthetic with all the same size fibers not so much randomness. The only thing that counts is what is in the oil pan at change time. The parts of a cellulose filter that are very dense and fine can and do act like tiny bypass filters. I think a synthetic blend may be the best of both worlds. IMHO USA
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: FlyNavyP3] #4470167
07/25/17 03:42 PM
07/25/17 03:42 PM
Los Angeles, California
Gokhan Online content
Gokhan  Online Content
Thank you for the update, Sir!
The RockAuto Chinese Toyota-knock-off counterfeit oil filter looks OK and performed OK according to the particle count.
However, after visiting your previous UOA, Fram Ultra particle counts look dismal. They are somewhat in the unacceptable range for an engine oil filter. What went wrong with the Fram Ultra? Did it clog and run in the bypass mode? Did Blackstone make a mistake in the particle counts? You certainly had no wear metals at all though. How do we explain the BITOG-darling mighty Fram Ultra performing so miserably? Unfortunately I can't find any other Fram Ultra particle counts on the Internet. If these numbers are real, Fram Ultra is a very poor-quality oil filter in real-life applications. Let's hope not.
How do you sample your oil by the way? Dipstick? Midstream oil drain?
https://www.blackstone-labs.com/particle-count-test.php
1985 Toyota Corolla LE, 4A-LC engine, ~ 273,000 M
Mobil 1 Extended Performance 0W-20 SN PLUS (PAO-based)
Fram Ultra XG3600 filter (full synthetic), 90430-12031 drain gasket (rubber on aluminum)
Re: RockAuto UltraFast Toyota copy used oil filter cut [Re: Gokhan] #4470186
07/25/17 04:05 PM
07/25/17 04:05 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
One data point ... I'd call it a fluke, or something went wrong with the filter and/or PC process until proven otherwise. There was also someone else who posted particle count data for a Fram TG (almost as efficient as the Ultra) used on a motorcycle with shared transmission/clutch, and the PC after 5K miles was cleaner than the new oil in the bottle. Link HERE
According to Blackstone's ISO Code "cleanliness scale" for engine lubes (your link), those are both "dirty". Probably need a full blown 2 micron bypass filtering setup to get well into the "clean" realm or better.
