Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
42 registered members (2015_PSD, bcossa2001, biggusblockus, Brad_C, Bailes1992, askani79705, 4 invisible), 791 guests, and 38 spiders.
Topics290,699
Posts4,848,487
Members66,021
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
First oil change #4456025
07/11/17 09:36 AM
07/11/17 09:36 AM
CT
Icantelia Offline OP
CT
I have a 2016 Civic EX Turbo with only 500 miles and the maintenance minder says that my oil level is at 10% and it is 12 months old. I have read that this car has a special factory fill for the 600 mile breaking period. (Maybe I read that incorrectly, or the information was wrong.)
Is that true about the special oil? Should I get the oil changed now because it has been 12 months or wait for the 600 miles or longer? Why does the A service say "without oil filter"?
"If a Maintenance Minder indicator does not appear more than 12 months after the display is reset, change the engine oil every year.
NOTE: Inspect idle speed every 160,000 miles (256,000 km).
Adjust the valves during services A, B, 1, 2, or 3 if they are noisy.
Symbol / Maintenance Main Items
A. Replace engine oil
- Engine oil capacity without oil filter
1.5 L engine models: 3.2 L (3.4 US qt)
2.0 L engine models: 4.0 L (4.2 US qt)
B. Replace engine oil and oil filter
- Engine oil capacity with oil filter
1.5 L engine models: 3.5 L (3.7 US qt)
2.0 L engine models: 4.2 L (4.4 US qt)"
Re: First oil change [Re: Icantelia] #4456034
07/11/17 09:45 AM
07/11/17 09:45 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Regardless of the owner's manual, I'd change it. Good rule of thumb is 12 months if it's used pretty much daily but not enough miles to exceed the interval. Considering it's your first change and it's got that much age on it I'd certainly change the oil and filter.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
Re: First oil change [Re: Alex_V] #4456058
07/11/17 10:08 AM
07/11/17 10:08 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
OP said, "...my oil level is at 10%..." OMG! Fried engine from within.
Re: First oil change [Re: Icantelia] #4456060
07/11/17 10:10 AM
07/11/17 10:10 AM
Austin, Texas
Brons2 Offline
Brons2  Offline
Austin, Texas
10% and the maintenance minder hasn't gone off? When does it go off? 5%?
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
Re: First oil change [Re: Brons2] #4456067
07/11/17 10:19 AM
07/11/17 10:19 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
It shows up at 15%. I am assuming OP wrote that wrong and the oil life is still at 90%.
The oil should also be changed at 1 year.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: First oil change [Re: Icantelia] #4456073
07/11/17 10:24 AM
07/11/17 10:24 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Clean oil is happy oil.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
Re: First oil change [Re: Icantelia] #4456126
07/11/17 11:19 AM
07/11/17 11:19 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Leave it. Total waste to dump. Likely the best oil that engine will see. I would though consult with dealer about warranty FIRSTLY though.
The oil chemistry will preserve the oil through next year - regardless of rules of thumb - a rule of law which applies to the size of the switch you are allowed to cane your spouse with - not oil.
Lightly used oil = less engine wear than NEW oil.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: First oil change [Re: Icantelia] #4456127
07/11/17 11:20 AM
07/11/17 11:20 AM
CT
CT
Oil level is fine and clean. Yes the MM went on at 15%, but I really don't drive it too often - obviously.
Can anyone confirm what I read about a "special factory fill" for the break-in period?
Re: First oil change [Re: Icantelia] #4456145
07/11/17 11:31 AM
07/11/17 11:31 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Only 500 miles on the clock and the MM is saying it's down to 10%? How is that even possible?
Re: First oil change [Re: Bottom_Feeder] #4456151
07/11/17 11:34 AM
07/11/17 11:34 AM
NC
Matagonka Offline
Matagonka  Offline
NC
It probably takes time into account as well.
Re: First oil change [Re: ARCOgraphite] #4456155
07/11/17 11:37 AM
07/11/17 11:37 AM
Ontario, Canada
Ontario, Canada
We say to do it at the one year mark, so does the owners manual.
Mighty Mouse Tech
Re: First oil change [Re: Matagonka] #4456158
07/11/17 11:38 AM
07/11/17 11:38 AM
Ontario, Canada
Ontario, Canada
Would be the first Honda/Acura that does that. Have never seen one that does.
OP, are you sure you are not just looking at the trip meter and not the actual mileage?
Mighty Mouse Tech
Re: First oil change [Re: mightymousetech] #4456177
07/11/17 12:02 PM
07/11/17 12:02 PM
Ohio
hallstevenson Offline
Ohio
He also stated "the MM went on at 15%" so it sounds like he's understanding / reading it correctly. It definitely sounds like the MM has a "clock" counter factored in too.
Re: First oil change [Re: mightymousetech] #4456184
07/11/17 12:07 PM
07/11/17 12:07 PM
Ohio
Ohio
Not so funny misunderstanding of the MM that I found while Googling oil change intervals related to newer Civics:
Quote:
A buddy of mine works at a Honda dealership and someone brought in a car overflowing with oil. See, the owner thought the "oil life" was "oil level" and ended up pouring multiple quarts of excess oil into the car. Not surprisingly the oil life meter didn't change throughout the process.
Re: First oil change [Re: Icantelia] #4456193
07/11/17 12:15 PM
07/11/17 12:15 PM
CT
CT
Yes I am reading it correctly. I really don't drive much, so that is why the car is 1 year old with 500 miles. I just thought it was strange that the MM was telling me the oil was at 15% at the one year mark. I have checked it and it is full and clean. A few weeks ago, the MM said it was 10%. I have checked it and again the oil on the stick is full and clean. That is why I am questioning it.
Why does Honda say to only replace engine oil and not the filter with an "A" service? All of my previous Honda's were always oil and filter.
Page 1 of 3 1 2 3
