Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
127 registered members (benjy, Altima2, Benzadmiral, Bailes1992, aquariuscsm, Alfred_B, 8 invisible), 2,239 guests, and 62 spiders.
Topics286,397
Posts4,907,578
Members67,614
Most Online2,967
Mar 10th, 2019
Valve stem cracks on a tire? #4456014
07/11/17 09:21 AM
07/11/17 09:21 AM
MURICA
maverickfhs Offline OP
MURICA
Both valve stems on my motorcycle if I bend them from side to side are showing cracks in them. Something similar to this thread: http://www.rubiconownersforum.com/forums...alve-stems.html
Are they dangerous? Also, can they be replaced while tire is still on the rim and vehicle?
Thanks for the help.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Valve stem cracks on a tire? [Re: maverickfhs] #4456033
07/11/17 09:44 AM
07/11/17 09:44 AM
Coastal South Carolina
edwardh1 Offline
edwardh1  Offline
on a motorcycle/////
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Valve stem cracks on a tire? [Re: maverickfhs] #4456051
07/11/17 10:04 AM
07/11/17 10:04 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
I'd replace them if they are cracking.
I noticed that the ones on the F-350 were getting a bit old. Last wednesday, I took the spare tire and jack out before i left for work and at the stoplight infront of the office, the valve stem blew out. Had to pay $20 for something I can do myself!
But to replace them , you do have to break down the tire at least enough to get a new valvestem in.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Valve stem cracks on a tire? [Re: maverickfhs] #4456056
07/11/17 10:06 AM
07/11/17 10:06 AM
MURICA
MURICA
Yea, I am definitely going to replace them sooner than later!
Think, I'll try to see of I can do it while wheel is on the motorcycle. If not, might have to remove for breaking the bead.
Re: Valve stem cracks on a tire? [Re: maverickfhs] #4456094
07/11/17 10:42 AM
07/11/17 10:42 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
You have to pop the bead. Can not be done from the outside.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Valve stem cracks on a tire? [Re: maverickfhs] #4456259
07/11/17 12:59 PM
07/11/17 12:59 PM
northern NY
Driz Online content
Driz  Online Content
northern NY
On a motorcycle anything wheel related is dangerous. Treat it like an airplane, if you find it fix it..
Re: Valve stem cracks on a tire? [Re: maverickfhs] #4456309
07/11/17 01:44 PM
07/11/17 01:44 PM
Wisconsin
Black_Thunder Offline
Wisconsin
its always good practice to replace the stems anytime a tire is dismounted.
car tires are a bit easier to deal with as it is possible to change the stem without dismounting it
bike tires are more difficult unfortunately and usually need to be dismounted from the rim to replace the stem.
I'd buy Callahan autoparts if I could.
Re: Valve stem cracks on a tire? [Re: Black_Thunder] #4456313
07/11/17 01:46 PM
07/11/17 01:46 PM
MURICA
MURICA
Thanks for your valuable input. Question, is the valve stem same as used in a car or different?
Re: Valve stem cracks on a tire? [Re: maverickfhs] #4456478
07/11/17 04:55 PM
07/11/17 04:55 PM
ME
eljefino Offline
eljefino  Offline
ME
1st off if you have wire wheels you have an inner tube.
My Virago had a bolt-through metal valve stem that was quite rugged.
Re: Valve stem cracks on a tire? [Re: eljefino] #4456481
07/11/17 04:58 PM
07/11/17 04:58 PM
MURICA
MURICA
Mine are definitely tubeless and not wired ones.
Re: Valve stem cracks on a tire? [Re: maverickfhs] #4456987
07/12/17 08:02 AM
07/12/17 08:02 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
Get those replaced NOW!! I've had a couple valves fail and it is just like getting an instantaneous flat. You don't want that to happen at speed on a motorcycle!
Yes, the valves are the same as for passenger cars.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Valve stem cracks on a tire? [Re: CapriRacer] #4456990
07/12/17 08:05 AM
07/12/17 08:05 AM
MURICA
MURICA
Thanks very much, are removal and installation of valve stem pretty straight forward? I know would have to remove the wheel, break the bead after removing the stem core.
Re: Valve stem cracks on a tire? [Re: CapriRacer] #4457031
07/12/17 08:52 AM
07/12/17 08:52 AM
MURICA
MURICA
So something like this would work?
http://www.ebay.com/itm/4-pieces-TR413-Wheel-Tire-Valve-Stems-Short-Black-Rubber-BMW-E90-F30-F10-F1-/331488137188?hash=item4d2e3b8fe4:g:H2oAAOSwEetWBEhH&vxp=mtr
Re: Valve stem cracks on a tire? [Re: maverickfhs] #4457592
07/12/17 07:33 PM
07/12/17 07:33 PM
ME
eljefino Offline
eljefino  Offline
ME
yup or you can get them at walmart/ napa.
Re: Valve stem cracks on a tire? [Re: maverickfhs] #4457940
07/13/17 07:50 AM
07/13/17 07:50 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
Unless you are planning to do them yourself, have the tire shop supply them. That way if there is something weird, they'll be in a position of responsibility.
CapriRacer
