Heavy oil=hotter temp?
marlton, new jersey, usa
Hi all-decided to see what all the heavy oil hype was about and tried it in my 1997 Dodge B2500 van which is a Roadtrek motorhome conversion with a 5.2 (318) engine. Mileage is about 140K and I have always run 10/30W as per specs. I use a Scanguage II to monitor performance. Decided to use 10/40 for the summer months thinking it would offer a little more protection. Usual operating temperatures are around 198 degrees which climbs when pulling mountain grades. Oil pressure is noticeably higher (3/4 on the analog gauge instead of the usual 1/2 way) and temps seem to be consistently higher. Today when pulling a long 6 mile grade up the mountain, the temp rose to 215-218 instead of the usual 204-206. Does the heavier oil (Valvoline MaxLife 10/40) really make that much of a difference???
Yes, oil temp will be a little higher with thicker oil, and 10-40 will not offer better wear.
Found this figure in lubetech article.
Seems like after 30 wt there is very little to gain.
Be interesting to see how the 10w40 does when the weather cools down a bit. Imagine its hot all over.
Yes.There is a difference.
Maxlife 10W40 is 13.94 cSt at 103*C; and
Maxlife 10W30 is 12.00 cSt at 95*C, despite being 8*C cooler.
One vote goes to lower operating temperature..... but at reduced oil film thickness ?
Oh no, 10*C higher temperature in 10W40 would half the oil life of 10W30!!!...... according to experts.
Then OCI 10W40 at 10k and compare against 10W30 OCI at 20k UOA ...... or
OCI 10W40 at 15k against 10W30 at 25k ...... and compare.
Do you need extra thick oil film thickness from 10W40, albeit at higher operating temperatures ?? .........
that's another topic for debate..
Btw,it would be interesting for OP to demonstrate if xW20 operates cooler than 10W30?
Concur with you, in gasoline engine applications ONLY.......
probably not .. in differential gear or hydraulic applications..... vis-a-vis thick vs thin oil comparisons.
Edit: Add info.
This is what I'd like to see.
I went from 5w30 fuel economy oil hths 3 to 5w40 and the engine heated up faster and ran hotter than on the 30 and ran sluggish too. Ditched the oil in a week and went back to 5w30.
Yes a higher viscosity oil will raise oil temps a bit, no real point in putting in a 10W-40 in the summer really.
Anyway even at 218F you are still in "the safe zone" but i would recomend you either run a 10W-30 or 5W-40 full synthetic oil.
Depends entirely on the engine in question. Some new cars spec 50
Shannow posted excerpts from a study showing the power losses due to oil thickness for a street and a racing engine, a thicker oil will naturally result in a greater loss than a thinner oil under the same operating conditions and the result is hotter oil. I noticed this in my own car when I switched from M1 5W30 (HTHS=3.1) to M1 5W30 ESP (HTHS=3.58) and was alarmed enough to post here asking what was going on...it totally makes sense when you think about it, though.
Shannow also mentioned that the increased temperature will not result in the thicker oil having a lower film thickness than the thinner oil under the same circumstances, there would be no point in using the thicker oil if that weren't the case.
