Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
43 registered members (bbhero, Ag76, ArrestMeRedZ, Agnosto, Brad_C, Bailes1992, 6 invisible), 947 guests, and 57 spiders.
Topics286,170
Posts4,903,516
Members67,572
Most Online2,967
Mar 10th, 2019
FL400S - My First C&P #4455622
07/10/17 07:56 PM
07/10/17 07:56 PM
NE Ohio
Ifixyawata Offline OP
NE Ohio
I ran this filter for about 9300 miles with Mobil 1 AFE 0w-30 in the Focus in my sig:
After a few seconds of cutting with a HF version of a Dremel, the cutting wheel looked like this:
I switched to a 4.5" angle grinder with a cut-off wheel (rookie move, I know) As a result, any metal shavings in the following pictures (probably) came from the cutter:
2004 Mercury Mountaineer 4.6 M1 High Mileage 10w-40 (Summer)
2001 Ford Focus 2.0 Zetec Pennzoil Euro L 5w-30
Re: FL400S - My First C&P [Re: Ifixyawata] #4455628
07/10/17 08:03 PM
07/10/17 08:03 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Looks good. What filter replaced this?
Re: FL400S - My First C&P [Re: Ifixyawata] #4455640
07/10/17 08:13 PM
07/10/17 08:13 PM
NE Ohio
NE Ohio
Replaced with a Bosch Distance Plus D3422, Walmart Clearance. I have 4 (3 now) so I'm not sure if I will run it to 5k or 10k.
Re: FL400S - My First C&P [Re: Ifixyawata] #4455676
07/10/17 08:38 PM
07/10/17 08:38 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
Man I tried to find those clearance D3422's at Walmart and can't.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: FL400S - My First C&P [Re: Ifixyawata] #4455680
07/10/17 08:41 PM
07/10/17 08:41 PM
NE Ohio
NE Ohio
I stopped buying them because I had FOUR and couldn't find more than one each for my wife's Jeep and my Mountaineer. Also, my WM won't drop them below $3 each. Still cheaper than MC but I want my $1 filters!
Re: FL400S - My First C&P [Re: E150GT] #4455684
07/10/17 08:46 PM
07/10/17 08:46 PM
Central Florida
Mr Nice Offline
Mr Nice  Offline
Central Florida
I still see them on the clearance shelf for $1.50 at the Walmarts in my area.
Re: FL400S - My First C&P [Re: Ifixyawata] #4455721
07/10/17 09:22 PM
07/10/17 09:22 PM
PA
copcarguy Offline
copcarguy  Offline
PA
They're still $3 here in NE PA, running one now on my '97 Tracer wagon.
Re: FL400S - My First C&P [Re: Ifixyawata] #4455737
07/10/17 09:43 PM
07/10/17 09:43 PM
Nowthen, MN
KD0AXS Offline
KD0AXS  Offline
Nowthen, MN
Not a rookie move as far as I'm concerned. Angle grinder is what I always use to cut open filters. Works great. I cut way down right along the crimp, and just barely cut through the can. Sometimes have to use a screwdriver to pop the end off after I cut all the way around. This will avoid getting metal shavings inside and also avoid cutting into any of the internals.
Re: FL400S - My First C&P [Re: Ifixyawata] #4455797
07/10/17 11:13 PM
07/10/17 11:13 PM
KS
FordBroncoVWJeta Online content
FordBroncoVWJeta  Online Content
KS
Cheapest filter I have ever bought
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2001 Pontiac Sunfire 2.2
Re: FL400S - My First C&P [Re: Ifixyawata] #4455881
07/11/17 05:20 AM
07/11/17 05:20 AM
New York
pbm Offline
pbm  Offline
New York
That MC looks good.
I picked up several Bosch DP 3422's, some at $1.50 but most at $3.00.
I plan on running them 2 OCIs in my Focus....they should be good for 15K?
'Journalism is Dead'
Re: FL400S - My First C&P [Re: Ifixyawata] #4455940
07/11/17 07:29 AM
07/11/17 07:29 AM
PA
copcarguy Offline
copcarguy  Offline
PA
WOW .25!!! Nice!
The best filter deal I've ever come across were six Mobil M1-209's for $1 each at WalMart a few years ago...
Re: FL400S - My First C&P [Re: Ifixyawata] #4456074
07/11/17 10:25 AM
07/11/17 10:25 AM
in the shop
sw99 Offline
sw99  Offline
in the shop
Thats one of the better looking MC filters I have seen. Thanks for the C&P.
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2019 Ford F250 6.7L CCSB
Re: FL400S - My First C&P [Re: sw99] #4456357
07/11/17 02:21 PM
07/11/17 02:21 PM
Ontario Canada
Canadastang Offline
Canadastang  Offline
Ontario Canada
Thanks for the c&p.
In the future, if you need to cut open a purolator or MC filter, take a good pair of tin snips and cut the crimp at the bottom of the can off. Works like a charm and makes a nice clean cut. Just takes a little but of muscle.
This won't work with [censored] tin snips, but a nice set of wiss aviation tin snips work great.
For some reason the MC's and purolator cans are just a tad bit thinner that snips go right through them.
Re: FL400S - My First C&P [Re: Canadastang] #4456545
07/11/17 06:41 PM
07/11/17 06:41 PM
NE Ohio
NE Ohio
Originally Posted By: Canadastang
Thanks for the c&p.
I will do this the next time I have a Motorcraft to remove. Both cars currently have D+
It might be a while, I bought another D+ from WM. Found one that still had stock near where I work, sadly it was still $3 but I think that's decent for a 10k filter.
