Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
26 registered members (BlakeB, Billbert, ArrestMeRedZ, CleverUserName, Astro14, ctechbob, 1 invisible), 731 guests, and 41 spiders.
Topics290,867
Posts4,851,572
Members66,044
Most Online3,590
Jan 24th, 2017
Trnny Filter Setup #4455595
07/10/17 07:22 PM
07/10/17 07:22 PM
State
Rockrz Offline OP
Rockrz  Offline OP
State
I'm planning on installing an inline filter and was thinking about going with the Derale Remote Filter Mount Kit...
But, I'm unclear on which Derale part number to get to be able to use these two filters:
Baldwin B252 Heavy Duty Spin-On Transmission Filter
https://www.amazon.com/Baldwin-B252-Heav...ds=Baldwin+B252
WIX Filters - 51269 Heavy Duty Spin-On Hydraulic Filter
https://www.amazon.com/dp/B0014BHVRO/_encoding=UTF8?coliid=I3VZ5Q2W3NT509&colid=GDEPGCX59WSP
Re: Trnny Filter Setup [Re: Rockrz] #4455602
07/10/17 07:32 PM
07/10/17 07:32 PM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
I bought a filter housing off the shelf at pepboys made by trans dapt over the weekend, under $30 fits 3/4-16
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Trnny Filter Setup [Re: Rockrz] #4455633
07/10/17 08:06 PM
07/10/17 08:06 PM
USA
ArcticDriver Offline
USA
Magnefine !
$35 shipped.
Multiple Diesel and Gasoline vehicles
Re: Trnny Filter Setup [Re: Rockrz] #4455693
07/10/17 08:52 PM
07/10/17 08:52 PM
State
Rockrz Offline OP
Rockrz  Offline OP
State
OK, thanks.
I'm really wanting a spin on filter and since the parts aren't that expensive I wouldn't be worried about price as this is something that's going to help a tranny last longer.
I suppose I could just buy one of the Derale Remote Filter Mount Kits along with these two filters and return anything that doesn't fit together.
Re: Trnny Filter Setup [Re: Rockrz] #4455705
07/10/17 09:04 PM
07/10/17 09:04 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Magnefine. The bulk of what I see in a Magnefine pulled from service is metallic paste. The spin on does not have a magnet in the middle of the fluid flow.
2015 Ford F250 w/Powerstroke
Re: Trnny Filter Setup [Re: Donald] #4455714
07/10/17 09:17 PM
07/10/17 09:17 PM
State
Rockrz Offline OP
Rockrz  Offline OP
State
But, one can easily place a very strong magnet on the bottom of the filter which I have been doing on my oil filters for years.
Any metal shavings will be trapped at the bottom of the filter.
Re: Trnny Filter Setup [Re: Rockrz] #4455731
07/10/17 09:38 PM
07/10/17 09:38 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Magnefine is way over priced for the teeny weeny filter.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Trnny Filter Setup [Re: Rockrz] #4455745
07/10/17 09:54 PM
07/10/17 09:54 PM
State
Rockrz Offline OP
Rockrz  Offline OP
State
Not to mention a spin on filter is going to provide better filtration
Re: Trnny Filter Setup [Re: Rockrz] #4455816
07/11/17 12:11 AM
07/11/17 12:11 AM
Virginia
mattwithcats Offline
Virginia
Any filter base with a 3/4-16 threads will work.
Put it in the return line, and hang a 3614 or 3600 (or equivalent) filter on...
Bazinga!
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Trnny Filter Setup [Re: mattwithcats] #4455823
07/11/17 12:24 AM
07/11/17 12:24 AM
State
Rockrz Offline OP
Rockrz  Offline OP
State
I'm leaning towards going with this...
B&M 80277 filter kit
Wix 51269 Spin-On Hydraulic Filter
Re: Trnny Filter Setup [Re: Rockrz] #4455849
07/11/17 02:29 AM
07/11/17 02:29 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Any metal shavings that will go through the filter media are likely to do just that. They wont be trapped by a single magnet until they closely approach it, which will probably take quite a few passes, though the cannister body will also be somewhat magnetised.
Might a very strong magnet in that location interfere with the operation of the bypass valve?
EDIT: Just realised this is about transmission filters, not engine, so my assumptions may not apply: ENDEDIT.
Re: Trnny Filter Setup [Re: Rockrz] #4456072
07/11/17 10:23 AM
07/11/17 10:23 AM
State
Rockrz Offline OP
Rockrz  Offline OP
State
I have a fairly large magnet on the bottom of my transmission pans and when you pull the pan you can see stuff gathering right where that magnet was so it can be cleaned out.
I learned this from guys that are in racing running high end engines and trannys
Re: Trnny Filter Setup [Re: CT8] #4456978
07/12/17 07:53 AM
07/12/17 07:53 AM
USA
USA
It offers alot of bang for that buck.
I always cut mine open at regular replacement intervals and find the magnet doing what it is designed to do--pull out ferrous metals. Mine are located in the return line from the cooler and all of this fluid must pass in close proximity to that magnet,,,much closer proximity than a magnet in a pan...IMO.
Besides, it saves me having to drop the pan as often to clean that magnet.
The Magnefine also has a traditional filter element and this captures non-ferrous contaminants. Lets face it, the typical AT filter inside the transmission is not a small micron design. The engineers do not think it is necessary so the Magnefine is already offering several times the filtration capability.
You do bring up a valid point, it is classified by the World Governing Automatic Transmission Filter Council as "teeny-weeny" grin and therefore needs to be changed out about every 15,000 miles IIRC.
plus its small design is less likely to get smashed by a rock in off-pavement applications.
Re: Trnny Filter Setup [Re: Rockrz] #4456985
07/12/17 08:01 AM
07/12/17 08:01 AM
USA
USA
An interesting point?
How much filtration is necessary?
The engineers who designed the factory AT filters in the pan apparently don't think much based on the element found in a factory filter...its often a porous foam and even considered "lifetime" in many Recommended Service Intervals.
Re: Trnny Filter Setup [Re: Rockrz] #4457114
07/12/17 10:18 AM
07/12/17 10:18 AM
State
Rockrz Offline OP
Rockrz  Offline OP
State
As much as one can get!
If they build things that last too long... they are working themselves out of a job so it stands to reason why they wouldn't use high quality media and why they don't want tranny filters to be serviced
That way they get to sell parts down the line or a whole new vehicle. Manufacturers have to keep selling stuff or they go out of business like any business.
