1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
126 registered members (avi1777, 2015_PSD, 2009Edge, Altima2, aquariuscsm, Alfred_B, 9 invisible), 2,237 guests, and 63 spiders.
Topics286,399
Posts4,907,593
Members67,614
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
10 ply tires #4455576
07/10/17 06:55 PM
07/10/17 06:55 PM
ALBERTA
Aspen Offline OP
Aspen  Offline OP
ALBERTA
Should i put 10 ply tires on my dodge halfton or stick with p rated ? Is a 10ply going to screw up front end parts faster?
Any advice is much appreciated gents
Re: 10 ply tires [Re: Aspen] #4455579
07/10/17 06:59 PM
07/10/17 06:59 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
It doesn't raise the capacity of what the truck can handle, I'd just use what it came with.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: 10 ply tires [Re: Aspen] #4455581
07/10/17 07:02 PM
07/10/17 07:02 PM
ohio
xtell Offline
xtell  Offline
ohio
10 ply ratings are not used much anymore. 10 ply = an E rated tire. If you are not going to use the truck for heavy loads, a P rated tire would be fine.
Re: 10 ply tires [Re: Aspen] #4455584
07/10/17 07:06 PM
07/10/17 07:06 PM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
I have e load tires on my 96 1500, a friend of mine warned me ahead of time,however I am the king of over kill my truck rides like [censored] and beats my brains out. I can come up with several reasons why I put them on but I wouldn't do it again
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: 10 ply tires [Re: NStuart] #4455590
07/10/17 07:15 PM
07/10/17 07:15 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
I bet they lasted longer though.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: 10 ply tires [Re: Aspen] #4455591
07/10/17 07:16 PM
07/10/17 07:16 PM
Houston, Texas
Houston, Texas
You should have LT for "light truck" P rated tires are for passenger cars.
Re: 10 ply tires [Re: Aspen] #4455593
07/10/17 07:18 PM
07/10/17 07:18 PM
BC, Canada
userfriendly Offline
BC, Canada
All I buy are E-rated tires, preferably with 3-ply sidewalls. And don't give me the rough ride song 'n dance.
People sleep on passenger trains, that on welded rail, are as smooth as glass.
Red sky with the BC fires Aspen?
Re: 10 ply tires [Re: Aspen] #4455603
07/10/17 07:32 PM
07/10/17 07:32 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
A real truck may need LT tires, but even with them, in the sizes they call for P tires are often sufficient to carry the rated load capacity and since these P tires achieve their rated load capacity at much lower inflation pressures, they ride better.
No reason to put LT tires on a half ton truck, unless you want a hard ride to go along with them.
I have a ton van. It's on P tires rather than the original LTs. They have sufficient load capacity at 40 psi to carry what LT tires would at 80 psi.
Guess which tire would ride better, especially without a load in the back?
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: 10 ply tires [Re: Aspen] #4455608
07/10/17 07:39 PM
07/10/17 07:39 PM
Utah
CKN Offline
CKN  Offline
Utah
What the truck came with from the factory meets all requirements of the truck. This includes payload and towing. If/when you tow I find filling the OEM tires near maximum inflation prevents sidewall squirm.
If you absolutely want to ruin your ride quality put 8 or 10 ply tires on.
Re: 10 ply tires [Re: motor_oil_madman] #4455609
07/10/17 07:40 PM
07/10/17 07:40 PM
Utah
CKN Offline
CKN  Offline
Utah
Not for a half-ton.
Re: 10 ply tires [Re: userfriendly] #4455612
07/10/17 07:41 PM
07/10/17 07:41 PM
Utah
CKN Offline
CKN  Offline
Utah
But they do ride rougher-even if you don't want to hear it.....
Re: 10 ply tires [Re: Aspen] #4455621
07/10/17 07:56 PM
07/10/17 07:56 PM
Wisconsin
WiskyBadger Offline
WiskyBadger  Offline
Wisconsin
I had e rated tires on a half ton. They lasted a long time, but it did ride rougher and were louder.
11 Silverado 60k Rotella Gas Truck and Carquest filter
11 Traverse 118k Super Tech FS HM and Carquest filter
78 Chevy C10 Stepside
Re: 10 ply tires [Re: CKN] #4455623
07/10/17 07:56 PM
07/10/17 07:56 PM
USA
ArcticDriver Offline
USA
Now there is a song I can dance to.
Not only what he said above but your Load Range "E" tires are going to have a shorter mileage warranty from the manufacturer.
And the "E" should cost you about 25% more.
The only advantage that I can see to a "E" rated tire on a 1/2 ton is if you are driving alot of mountain trails strewn with sharp jagged rocks.
"Sidewall Squirm" ???
Sounds pretty gross.
Multiple Diesel and Gasoline vehicles
Re: 10 ply tires [Re: Aspen] #4455626
07/10/17 08:01 PM
07/10/17 08:01 PM
BC, Canada
BC, Canada
How about 285/45/22s with an inch of sidewall that come stock on 1500s (goes with the 0W20)? Would they be smoother than say..35/12.50/16s on a gravel road and 20W50?
Re: 10 ply tires [Re: Aspen] #4455632
07/10/17 08:06 PM
07/10/17 08:06 PM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
I have E rated tires on my F250 which carries heavy loads on bad roads. The downside is that they seem to have higher rolling resistance and hurt fuel mileage a little bit. Can't quantify it though. Don't see any good reason to run them on a half ton. As I recall I had P rated tires on my Toyota pickup and the load rating was higher than the equivalent LT tires.
Page 1 of 3 1 2 3
