Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
95 registered members (928, 3311, 69GTX, 69Torino, 2018matto, 12 invisible), 1,901 guests, and 57 spiders.
Topics286,181
Posts4,903,714
Members67,574
Most Online2,967
Mar 10th, 2019
Getting Grease/Oil Spots off Asphalt Driveway #4454521
07/09/17 06:21 PM
07/09/17 06:21 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
First of all, I have a pressure washer. Keep that in mind. I do all the oil changes on the cars in my sig. I do all the ATF and MT changes. I do all the gear oil changes. I do all the brake fluid changes. I do all the coolant changes. And yes, I have had a lot of runs and drips. One time I forgot to put the drain plug in and wasted 4 qts of Amsoil.
As a result of all the draining and filling, I have quite a few oil spots in my driveway. Some as large as 24 inches in diameter.
What is the best way to remove them? Simple Green, Purple Power,...
I can't remember but something I used whitened the asphalt and now it looks as bad as the spot it didn't remove. I need expert advice.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: Gebo] #4454552
07/09/17 06:42 PM
07/09/17 06:42 PM
Ca
totegoat Offline
totegoat  Offline
Ca
I put floor sweep on the spots and grind with my foot, then sweep it up. Works on my concrete.
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: Gebo] #4454557
07/09/17 06:44 PM
07/09/17 06:44 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I have used dawn (fresh spill) to bind it enough to be able to wash away. I spilled some DEX/MERC ST ATF recently wiped with a rag, and it washed off with plain water. I'm still dumbfounded.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: Gebo] #4454561
07/09/17 06:47 PM
07/09/17 06:47 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
These aren't fresh.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: Gebo] #4454572
07/09/17 06:52 PM
07/09/17 06:52 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
This is the best way to remove such spots:
Me: 13' VW GTI 3 door 6 speed manual
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: Gebo] #4454598
07/09/17 07:16 PM
07/09/17 07:16 PM
ME
eljefino Offline
eljefino  Offline
ME
Try gasoline. Do it at night so it'll soak in before it evaporates.
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: Gebo] #4454621
07/09/17 07:43 PM
07/09/17 07:43 PM
NC
ruhroh Offline
ruhroh  Offline
NC
Carb and brake cleaner can lighten the stain a fair bit, even old stains. Add cat litter to soak up excess fluid. Won't remove completely though.
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: skyactiv] #4454623
07/09/17 07:45 PM
07/09/17 07:45 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
That was going to be my suggestion.
No pavement looks better than a freshly dressed asphalt driveway.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: Gebo] #4454665
07/09/17 08:36 PM
07/09/17 08:36 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
Gasoline works well. Alternatively get some TSP at the home store. Scrub. You can also make an outstanding deck cleaner with the TSP. Google for various recipes. If you follow up with a quality pressure washer, you'll be very pleased.
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: Gebo] #4454687
07/09/17 09:06 PM
07/09/17 09:06 PM
Florida
Dumc87 Offline
Dumc87  Offline
Florida
I've used Muriatic acid with pretty good results. Kind of tricky to spread out evenly though
16 titanxd
15 journey
'09 Matrix - QS UD 0w20
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: Gebo] #4454728
07/09/17 09:43 PM
07/09/17 09:43 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Straight muriatic acid? Let it soak and then pressure wash?
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: skyactiv] #4454731
07/09/17 09:44 PM
07/09/17 09:44 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Would it stick to the big oil spots?
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: skyactiv] #4454800
07/09/17 10:58 PM
07/09/17 10:58 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Gee. I wonder if Airport Grade means airport parking lot grade?
too many cars and oil combinations to list in 150 characters or less
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: Gebo] #4458740
07/13/17 09:04 PM
07/13/17 09:04 PM
Florida
Dumc87 Offline
Dumc87  Offline
Florida
I've only used one type of muriatic acid, and there's directions on the bottle of how to dilute it.
I used straight acid by dropping it in moderation on the worst oil stains and then scrubbed the area immediately, then let it soak for a few minutes and rinsed it away. Made a significant difference compared to the spots that didn't have much, if any, muriatic acid.
Next round, I'll mix some up in a spray bottle and mist the entire area, then wash it away after 5-10 minutes.
16 titanxd
15 journey
Re: Getting Grease/Oil Spots off Asphalt Driveway [Re: Gebo] #4459147
07/14/17 10:27 AM
07/14/17 10:27 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Simple Green or similar is what I'd try. Mineral Spirits, turpentine, WD40 or silicone spray is good for little spot wipes, but like said, it's going to take the top coat right off. I just wipe up spots on my asphalt driveway with soapy water and a rag. I get it sealed every other year or so and touch up cracks myself.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
