08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
BITOG using excessive CPU power?
by Kibitoshin
06/18/18 05:10 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Orion62, Revd, blinky1041, mostdecent, T1TN
65261 Registered Users
72 registered (andyd, BAJA_05, Artem, 2009Edge, badtlc, AandPDan, 7 invisible), 1426 Guests and 38 Spiders online.
65261 Members
67 Forums
285507 Topics
Page 1 of 3 1 2 3 >
#4454169 - 07/09/17 10:25 AM 6500 watt portable generators:
Oil_Flunky Offline
Loc: Michigan
How do the cheaper models like Generac hold up with occasional once a year use for power failures, if maintained in the anal BITOG fashion?
Oil, you need it. Oil snobbery, you don't need it.
#4454177 - 07/09/17 10:41 AM Re: 6500 watt portable generators: [Re: Oil_Flunky]
Linctex Offline
Loc: Waco, TX
The oil will last ten years with "occasional emergency" use, I know this to be a fact from experience.
The fuel system needs the most attention. Use E-0 gas if you can find it, and always use Sta-Bil or Pri-G in the fuel if it's going to be stored for long periods of time.
#4454179 - 07/09/17 10:42 AM Re: 6500 watt portable generators: [Re: Oil_Flunky]
Linctex Offline
Loc: Waco, TX
Of all the "old" generators I have (20+ years old), only the Briggs engined ones are still alive. The ones with Honda engines are absolutely OUTSTANDING.
#4454186 - 07/09/17 10:48 AM Re: 6500 watt portable generators: [Re: Linctex]
pkunk Offline
Loc: NM, USA
Don't forget to shut the fuel off and run the carb dry also.
2008 Mini Cooper Clubman (toad)
2000 Mercedes ML320
1994 Dodge 2500 Cummins
1999 Ford F53 V10 Coachman Motorhome 34ft
#4454199 - 07/09/17 11:05 AM Re: 6500 watt portable generators: [Re: Oil_Flunky]
Donald Offline
Loc: Upstate NY
Most should be fine for 10 yrs. Test them 2x year and I always used stabilized E0. I have since gone to propane.
Before buying figure out the critical circuits and the peak and running load. A clamp-on ammeter will help.
And plan a way to use it to power the critical circuits without back feeding.
2015 Ford F250 w/Powerstroke
#4454215 - 07/09/17 11:30 AM Re: 6500 watt portable generators: [Re: Donald]
Oil_Flunky Offline
Loc: Michigan
*I'm an electrician.
Thanks though, you don't want to toast a lineman or your home wiring for people reading this.
Edited by Oil_Flunky (07/09/17 11:31 AM)
#4454216 - 07/09/17 11:30 AM Re: 6500 watt portable generators: [Re: Oil_Flunky]
UncleDave Offline
Loc: Ca.
It will be fine for that kind of use.
If you've taken care of your fuel and fuel system appropriately as was posted earlier.
Note: It will be noisy, thirsty power outage however this unit roars at a fixed constant RPM and swigs fuel like a drunken sailor.
You can get an idea of the relative quality of any given unit by looking the valve lash inspection interval it carries.
Yahamhas, Hondas, and Subarus typically have the longest intervals. - no surprise.
Typically its a 3X spread between the cheapie and the good ones.
UD
Edited by UncleDave (07/09/17 11:33 AM)
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
#4454281 - 07/09/17 01:35 PM Re: 6500 watt portable generators: [Re: Oil_Flunky]
Donald Offline
Loc: Upstate NY
Also depending upon the neighborhood you want 1/2" chain and a quality padlock along with a Rottweiler. And a CO detector.
If the place where you live is known as a "hood" then up it to 3/4" chain and two Rottweilers.
#4454318 - 07/09/17 02:18 PM Re: 6500 watt portable generators: [Re: Oil_Flunky]
NO2 Offline
Loc: Michigan
You should have an electrician install a manual transfer switch. Alternately have a power plug to your furnace, instead of having it hard wired. You can run extension cords for the remainder of your devices. Also make sure that the generator has voltage regulation if your don't want to burn out your motors and refrigerator compressors.
#4454328 - 07/09/17 02:27 PM Re: 6500 watt portable generators: [Re: Oil_Flunky]
Astro_Guy Offline
Loc: Pennsylvania
You should be more than fine with that unit, but if you don't mind me asking, why so large? Electric water heat perhaps? Hoping to start a window air conditioner?
I use a Champion 3500 watt unit to power all of my essential circuits, but then I have gas on the stove and hot water heater. Both of those items are still on essential circuits, because both rely upon electric ingnitors. My gas furnace is also considered an essential circuit, and I have run the heat with a power outage. I've also run the dishwasher with heated dry cycle during a power outage.
The outlet in the bathroom where the Misses plugs in her hair dryer is also considered an essential circuit. Some of you will get that; the rest of you probably aren't married!
Edited by Astro_Guy (07/09/17 02:27 PM)
'01 Volvo V70XC, 224k, 0w40 M1
'16 Accord, 10k, soon to be 0w20 M1 EP
#4454392 - 07/09/17 03:34 PM Re: 6500 watt portable generators: [Re: Oil_Flunky]
Linctex Offline
Loc: Waco, TX
If you have a wife and several kids, 6500 watts provides for a lot of comfort and amenities.
3500 watts is still very usable, if you "manage your loads" and are very good about shedding a large load before bringing on another one
#4454444 - 07/09/17 04:26 PM Re: 6500 watt portable generators: [Re: Oil_Flunky]
eljefino Offline
Loc: ME
I have a 2500 watt/3250 surge "chonda" that's been around since a month after Hurricane Irene. (Sold my old B&S clunker during the hype.)
The little rubber fuel hose is starting to decompose. No other problems. 11 month old E10 gas with a bunch of sta bil, still starts right up.
I wiggle the little fuel line off the carb to drain the tank and put fresh fuel in occasionally. The chinese rubber doesn't like doing this all that much.
I have a 4-position transfer switch that wires in after the main breaker box, for the essential loads. This way I didn't have to have the PoCo pull the meter for a full-house switch.
IMO 6500 watts is overkill and will guzzle gas, which is another hassle. Aside from the hassle it's 8-10x as expensive to make your own than to buy.
#4454584 - 07/09/17 07:01 PM Re: 6500 watt portable generators: [Re: Oil_Flunky]
Johnny2Bad Offline
Loc: Saskatchewan, Canada
I'm not so sure about the "gas guzzling". Sure, small generators are fuel conserving, but generators only use fuel based on load. No load, little fuel consumption; full load ... well, if you sized it right, you probably need the capacity.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
#4454597 - 07/09/17 07:13 PM Re: 6500 watt portable generators: [Re: Oil_Flunky]
andyd Online   content
Loc: Marshfield , MA
Yah, I have a 35 yr old Coleman 5KW with a Tecumseh hm100 10 hp. If I can get it started, it has recoil, and keep it running. It will manage everything essential. The unit has less than 80 hrs on it. I have to fish or cut bait with it. Fix or replace.
Thick oil is better grin2
#4454618 - 07/09/17 07:38 PM Re: 6500 watt portable generators: [Re: Johnny2Bad]
eljefino Offline
Loc: ME
volumetric efficiency and all that... ideally one would be at 60-80% of max load with your typical gas engine. The "crude" ones run at 3600 RPM to make 60 cycle power so you have the drag of the fan and whatnot.
Kill-a-Watt meters are telling, particularly about duty cycles of refrigerators. My fridge does way more than turn on and off-- it has a sub-200 watt consumption mode that I'm not sure how it works.
Page 1 of 3 1 2 3 >
