Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
3.5EB Gen II: Oil & Interval
by Gene K. 09/19/18 06:09 PM
Are there any cable techs here?
by Reddy45. 09/19/18 06:02 PM
VIRGIN ST2 STP FILTER CUT OPEN
by 53' Stude. 09/19/18 05:08 PM
Chrysler HOAT at 9 years...
by burla. 09/19/18 04:34 PM
Septic Tank pumping question
by wormwood1978. 09/19/18 03:46 PM
A5/B5 or A3/B3
by ka9mnx. 09/19/18 03:27 PM
LingLong
by sloinker. 09/19/18 02:42 PM
2018 Grand Caravan review
by tiger862. 09/19/18 02:39 PM
Diagnosing gas furnace
by Oro_O. 09/19/18 01:16 PM
Let's talk dipsticks and oil capacity
by csandste. 09/19/18 12:32 PM
Here's my fram filter at least 18 thousand miles
by Ablebody. 09/19/18 11:31 AM
How much is my truck worth?
by wallyuwl. 09/19/18 09:56 AM
Looking for Spray Detailer Advice
by knerml. 09/19/18 09:51 AM
LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:26 AM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
109 registered members (53' Stude, 07hemi, 92saturnsl2, 2013ecof150, 2004tdigls, 14 invisible), 1,726 guests, and 40 spiders.
Topics290,679
Posts4,848,269
Members66,021
Most Online3,590
Jan 24th, 2017
HM oil? 75K? #4453714
07/08/17 07:18 PM
07/08/17 07:18 PM
USA
dbias Offline OP
dbias  Offline OP
USA
I see a lot of ads for High Mileage oil and most have 75K on the label. Ive honestly never used the stuff but have had several vehicles go to 200K. Current vehicles over 100k are my Ford Transit Connect at 118K and a VW Jetta at 110K. Neither vehicle uses a drop of oil on a 10K OCI. When would one get any benefit of High Mileage oil?
2011 VW JETTA Castrol Edge 0W-40
2012 FORD TRANSIT CONNECT Castrol Edge 5W-20
2016 HONDA CIVIC COUPE Castrol Edge 0W-20
2017 AUDI A4 Ravenol SSL 0W-40
Re: HM oil? 75K? [Re: dbias] #4453725
07/08/17 07:31 PM
07/08/17 07:31 PM
NC
Vladiator Offline
Vladiator  Offline
NC
If your engine is burning oil - HM seems to reduce or eliminate it, most of the time. If your engine seals are leaking and you are feeling lazy to replace those - HM oils sometimes do a great job of conditioning those seals just enough to stop the leak for many miles to come. And also HM oils (synthetics) are a little more viscous that their regular versions. Due to that I definitely see a benefit of using it in a harsh environment, like Death Valley or Phoenix. Valvoline specifically says that their HM synthetics (MaxLife) are suitable for use in old and brand new engines. I see HM oils as regular oils on steroids, and use them accordingly to that.
2000 Lexus GS300-361k
1999 Lexus GS400-213k
2006 Toyota Camry-187k
2006 Toyota Highlander Hybrid-125k
2009 Scion xB-120k
2013 VW Tiguan-120k
2009 Toyota Tacoma-60k
Re: HM oil? 75K? [Re: dbias] #4453726
07/08/17 07:32 PM
07/08/17 07:32 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
If you haven't got any leaks, HM oil is a waste. However they are solid oils and can be used from a low mileage.
Thick vs Thin test: 15k / 43k miles complete
Re: HM oil? 75K? [Re: dbias] #4453740
07/08/17 07:49 PM
07/08/17 07:49 PM
Waco, Tx.
Syntheticuser Offline
Waco, Tx.
My car is nearing 300k miles and I'm not using a HM oil. No need to. It doesn't weep, or drip oil. The oil stays on the full mark through the entire interval on 5,000 miles, but I have run it to 8,500 miles on two occasions and still full.
Re: HM oil? 75K? [Re: Syntheticuser] #4453750
07/08/17 08:10 PM
07/08/17 08:10 PM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
What do you drive ?
Re: HM oil? 75K? [Re: Vladiator] #4453752
07/08/17 08:12 PM
07/08/17 08:12 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
Regular oils on steroids?
Probably a good analogy, although maybe not as valid as it once was, with oils like Maxlife SB now being energy conserving and having quite tame add packs with no moly.
A good HM oil may have a stronger add pack than its non-HM brethren, like the old QS Defy and may be both thicker and have higher detergency, like M1 HM.
We have many posters come here and wonder why their engines do just fine without HM oils.
The answer is usually that they're already using an HM oil like Red Line or that given good engine design and good maintenance they aren't yet at the point where an HM oil would be helpful.
I've run engines out to around 200K without using HM oils but I've also had some that benefited from these oils at 100K or so.
YMMV
17 Forester 12K MSS 0W-20
12 Accord LX 92K PP 5W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: HM oil? 75K? [Re: dbias] #4453768
07/08/17 08:27 PM
07/08/17 08:27 PM
Waco, Tx.
Waco, Tx.
A Zetec powered Focus as my DD. I have a diesel Ford Powerstroke also that pulls trailers.
Re: HM oil? 75K? [Re: dbias] #4453782
07/08/17 08:38 PM
07/08/17 08:38 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
High mileage oils have additives that cause seals to swell to hopefully fix seal leaks. I would avoid it unless you have a rear main seal leaking. Fix any other seals that are leaking.
2015 Ford F250 w/Powerstroke
Re: HM oil? 75K? [Re: dbias] #4453863
07/08/17 10:24 PM
07/08/17 10:24 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
I bought some synpower Max life on amazon to add to an order to ship quick. Ive never used it before but I will try it next change. I only have one car under 75k miles.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: HM oil? 75K? [Re: dbias] #4453962
07/09/17 01:39 AM
07/09/17 01:39 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
HM oil is a band aid for people who can't be bothered to fix their leaking/burning issues.
Cable ties should hold it
Re: HM oil? 75K? [Re: Olas] #4453966
07/09/17 01:47 AM
07/09/17 01:47 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Well that is a pretentious thing to say. Most high mileage cars with leaking burning issues aren't worth it to fix. If an oil can patch the problem and keep it on the road, what's the big deal? Not all cars are as easy and cheap to do internal engine work on as an 82 VW.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: HM oil? 75K? [Re: 1JZ_E46] #4453994
07/09/17 04:10 AM
07/09/17 04:10 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
I'm not comparing anything to the Rocco, only commenting that oil burning in any measurable quantity shows a weakness in the rings, or the stem seals. Similarly, leaks only occur when gaskets fail.
Repairing the problem is always the correct option, irrespective of the vehicle age or market value.
Re: HM oil? 75K? [Re: Olas] #4454045
07/09/17 07:27 AM
07/09/17 07:27 AM
NC
Vladiator Offline
Vladiator  Offline
NC
An example comes to mind... There was a gentleman who got tired of oil consumprion in his Acura TSX with k24 engine. He had the engine rebuilt with quality parts, and the shop doing the work had a big name in business with Honda engines. Well, a few thousand dollars later he had a rebuilt engine that went from consuming 1qt/1k miles before the rebuild, to 1qt/3k miles. So rebuild does not always eliminate oil consumption, for one reason or another... I heard quite a few similar stories over the years.
2009 Scion xB-120k
2013 VW Tiguan-120k
Re: HM oil? 75K? [Re: Olas] #4454147
07/09/17 09:53 AM
07/09/17 09:53 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Well of course repairing the problem is the best option, irrespective of money. But like I said, for many cars it's not worth it. Fixing consumption (1qt every 2,000 miles) on my X5 would be north of $5k... I pad $16k for the car. No way! I'll continue to use Liqui-Moly motor oil saver (ester based seal condition).
