PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
123 registered members (2015_PSD, 01rangerxl, 2009Edge, 14 invisible), 2,023 guests, and 61 spiders.
Topics286,160
Posts4,903,335
Members67,569
Most Online2,967
Mar 10th, 2019
2014 RAV4 transmission fluid change #4453631
07/08/17 05:39 PM
07/08/17 05:39 PM
VT
TC280rem Offline OP
TC280rem  Offline OP
VT
Just picked up a new to us RAV4.Has 46,xxx miles on it and I was thinking of doing a trans fluid change as preventative maintenance .Upon doing a little research,it appears as these trans are a sealed unit and "lifetime" fluid.has anyone successfully serviced one of these without going and having them hooked up to the "machine".
I know it takes the Toyota ws fluid but max lifeatf is compatible and have used that in our 12 corolla.
Also plan on changing out the rear diff and transfer to royal purple 75w-90.
Thanks in advance
2015 Corrola LE, 1.8l,CVT Trans ,Slate Metallic
2012 Corolla LE 1.8l w/4sp auto
2014 RAV4 XLE AWD 2.5l 6 sp auto
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453637
07/08/17 05:44 PM
07/08/17 05:44 PM
Waco, Tx.
Syntheticuser Offline
Waco, Tx.
I'd do all fluids bumper to bumper. This way you have a baseline.
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453639
07/08/17 05:49 PM
07/08/17 05:49 PM
VT
TC280rem Offline OP
TC280rem  Offline OP
VT
Planning to do everything except oil/filter as that was just done at the dealership...then I'll run Royal Purple w/K+N filter.
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453662
07/08/17 06:19 PM
07/08/17 06:19 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Off topic One of my friends has a 14 Rav with a 4 cyl . What a solid car I enjoy driving it. Clean oil is good oil.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453705
07/08/17 07:09 PM
07/08/17 07:09 PM
snow and sun
oliveoil Offline
oliveoil  Offline
snow and sun
Drive it and be happy. I'm guessing the tranny will be fine. Check back in 200k.
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453728
07/08/17 07:33 PM
07/08/17 07:33 PM
USA
slacktide_bitog Offline
USA
I thought the new "sealed" Toyota transmissions still had a drain plug and fill hole. In that case, you can do the fluid change with no problems smile
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453774
07/08/17 08:31 PM
07/08/17 08:31 PM
New York Queens
Ram02 Offline
Ram02  Offline
New York Queens
Lifetime fluid it should be good to the 100k mark.
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453793
07/08/17 08:56 PM
07/08/17 08:56 PM
Waco, Tx.
Waco, Tx.
Lifetime fluid is good until the trans fails period. I've seen some so called lifetime fluids shot at 60k miles. They call them lifetime fluids so it is one less thing on the maintenance list for the typical owner.
Ram, some members will be here shortly to educate you on the subject. I'm not qualified to go in depth.
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453794
07/08/17 08:57 PM
07/08/17 08:57 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Change out the front transaxle gear fluid if applicable. The transaxle leaks on my rav4.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: 2014 RAV4 transmission fluid change [Re: slacktide_bitog] #4453808
07/08/17 09:18 PM
07/08/17 09:18 PM
VT
TC280rem Offline OP
TC280rem  Offline OP
VT
Yes from what I'm seeing you can drop the pan and change filter then refill.probably end up going that route then drain and refill a few times to get 100% new fluid
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453811
07/08/17 09:21 PM
07/08/17 09:21 PM
VT
TC280rem Offline OP
TC280rem  Offline OP
VT
Even though it's supposed to be "lifetime" fluid I'd like to all I can to prolong the life of the tranny and have it last for a long time with no worries
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453827
07/08/17 09:39 PM
07/08/17 09:39 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
My Rav is still basically on the FF. It clunks and makes some noises when down shifting. I'll be lucky to get 400k miles out of it.
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453895
07/08/17 10:59 PM
07/08/17 10:59 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Upgrade to a higher viscosity grade or two is the most 'effortless and assured' way of achieving same.
No, the trans won't blow up AND it could run cooler, IMHO.
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453919
07/08/17 11:43 PM
07/08/17 11:43 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
My IS seems to chew up ATF in less than 40k, start to get jerky and just "not right." Next exachge i do I'm definitely avoiding WS.
Lifetime fill means till the tranny blows up from not being serviced.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: 2014 RAV4 transmission fluid change [Re: TC280rem] #4453934
07/09/17 12:08 AM
07/09/17 12:08 AM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
It seems changing fluid in a Gen4 RAV can be as simple or hard as you want to make it. Officially the proper level is found at a certain fluid temp and there's no dipstick.
Might find some useful info at rav4world.com
http://www.rav4world.com/forums/80-rav4-4-fourth-generation-2013-models/
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
