Food photography trickery
by nthach. 12/13/18 11:29 AM
oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Poles19, HinaMach, Horsehaulin, JLew, bmrk1100
66666 Registered Users
88 registered members (atikovi, aba4430, Bailes1992, AZjeff, aquariuscsm, 28oz, 15 invisible), 1,835 guests, and 41 spiders.
Topics295,019
Posts4,926,184
Members66,666
Most Online2,553
Oct 27th, 2018
Oil for Racing and Spirited Driving Apps? #4453308
07/08/17 10:21 AM
07/08/17 10:21 AM
San Diego, CA
gryffinwings Offline OP
San Diego, CA
At the moment, my level of oil experience isn't very broad, especially in the realm of racing and spirited driving, I would like to keep this to oils that are easy to obtain. Currently the oils I'm familiar with at the moment for some momentary full throttle fun with my little CRX Si is with Valvoline Max Life 10w40 and Mobil 1 10w30. My car is speced for 10w40 weight, but from what I understand, the engine isn't very picky on what oil to use. When I used Valvoline Maxlife for a bit, I honestly didn't get much life from it, my car burned oil, it didn't feel like the engine was very responsive either. So I switched over to Mobil 1 High Mileage 10w30, smoked has stopped as far as I can tell after a little running and the engine feels much more responsive. So for now Mobil 1 High Mileage 10w30, it seems pretty good, Mobil 1 list the HTHS as 3.5, so for oils that I will use later, that will be the base line. Also oil consumption is much reduced with this oil.
So for those of you that race or do spirited driving in the mountains or canyons, please share your experiences and knowledge. I expect that I will see more than a few 40 weights probably 0w40 and 5w40. Which is most likely the what I will use as the CST specs are sort of similar to Mobil 1 high mileage 10w30 from what I have seen with Mobil 1 FS 0w40 and Motul 8100 X-cess 5w40.
1987 Honda CRX Si
2015 BMW 320i
2016 Toyota Tundra
Re: Oil for Racing and Spirited Driving Apps? [Re: gryffinwings] #4453354
07/08/17 10:59 AM
07/08/17 10:59 AM
USA
plaguef Offline
plaguef  Offline
USA
Your CRX is spec'd for 10W-40? What?
For spirited driving.. use full synthetic. The Mobil 1 should be fine.
Re: Oil for Racing and Spirited Driving Apps? [Re: gryffinwings] #4453422
07/08/17 12:03 PM
07/08/17 12:03 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
M1 is thinner with the same HTHS, reduced consumption... I'm willing to bet you will return to it if you try anything different for one reason or another.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 103K Napa 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 35k PP MIX, NG7047
Re: Oil for Racing and Spirited Driving Apps? [Re: plaguef] #4453432
07/08/17 12:17 PM
07/08/17 12:17 PM
San Diego, CA
San Diego, CA
Yeah, my CRX Si is spec'd for 10w40 when not going below 32 degrees Fahrenheit or 0 degrees Celsius. Anyways I'm curious to know what others are using and their experiences for what specific oil they use.
1987 Honda CRX Si
2015 BMW 320i
2016 Toyota Tundra
Re: Oil for Racing and Spirited Driving Apps? [Re: Dyusik] #4453439
07/08/17 12:27 PM
07/08/17 12:27 PM
San Diego, CA
San Diego, CA
Yeah it's bizarre, I went from the thicker oil to a thinner oil and I get less consumption even at higher RPM, with Valvoline Maxlife 10w40, I was getting a decent amount of smoke at start up, but I'm not getting that with the Mobil 1 High Mileage 10w30, I wonder if the Valvoline Maxlife 10w40 is more volatile.
Anyways the only reason I would change is because I'd be changing to a higher performance engine DOHC 1.6 liter engine D16A1 which will be built fresh. What I might do for oil is use Mobil 1 FS 0w40, similar cSt specs to High Mileage 10w30 and better HTHS at 3.8. Anyways I won't know how the oil works until I do the build and run the oil. I've started to use cSt as a basis for comparing oil weights, since oil weights seem to have a range that they sit in.
1987 Honda CRX Si
2015 BMW 320i
2016 Toyota Tundra
Re: Oil for Racing and Spirited Driving Apps? [Re: gryffinwings] #4453846
07/08/17 08:58 PM
07/08/17 08:58 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
You're going to have a hard time finding a better oil for spirited driving. The M1 HM is a thick 30 that will take lots of heat and has a good additive package. Plus it's available at Walmart. You don't need a 40 weight unless you are running extended high rpm, like on a track. Pair it with a Fram ultra and drive.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Oil for Racing and Spirited Driving Apps? [Re: gryffinwings] #4453968
07/09/17 12:56 AM
07/09/17 12:56 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Redline is the best oil for engines that are used hard and get hot for extended periods.
Cable ties should hold it
Re: Oil for Racing and Spirited Driving Apps? [Re: gryffinwings] #4453971
07/09/17 01:03 AM
07/09/17 01:03 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Honestly for an 87 CRX any synthetic 40 weight will do the trick. Plenty of 5 qt full synthetic options at Walmart for under $25. 0W-40 M1!has been used by professional racing teams with good success.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: Oil for Racing and Spirited Driving Apps? [Re: 1JZ_E46] #4454242
07/09/17 11:35 AM
07/09/17 11:35 AM
San Diego, CA
San Diego, CA
Yeah, I've had good luck with it so far with my current engine, but when I change to a the new rebuilt engine that I plan on, I'll like change to Mobil 1 FS 0w40, I don't like the idea of run high mileage oil in a fresh engine, just my opinion. Also if I plan to use Fram Ultras, I will have to switch over to remote reservoir setup so I can use a more common filter as the only Fram I can get is the TG3531 Tough Gaurd, and those are hard to get locally, Mostly all I can get are Wix for a decent price, either way I don't see this as a bad idea as this would make it easier to change filters and give me better options for filters.
I've been seeing a lot of Mobil 1 FS 0w40 users lately, I didn't know it was being used by professional racing teams! I heard the formulation was recently changed last year or something, so I'm looking for more VOA and UOA while I wait to do the engine build and install into my CRX Si.
1987 Honda CRX Si
2015 BMW 320i
2016 Toyota Tundra
Re: Oil for Racing and Spirited Driving Apps? [Re: gryffinwings] #4454269
07/09/17 12:18 PM
07/09/17 12:18 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
My opinion is you should stick with the M1 10w30 HM for your current engine.
The FS 0w40 would be nearly indistinguishable from it, because the HTHS dropped from 3.8 to 3.6 when they created the FS version.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Oil for Racing and Spirited Driving Apps? [Re: gryffinwings] #4454270
07/09/17 12:18 PM
07/09/17 12:18 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
I also haven't seen any race teams use the new FS formula, but it's nearly as good as the old formula (same according to Mobil) so it would be a fine choice. Another option is 0W-40 Castrol. Seems to withstand breaking down better than the new M1. Any of the 40-weight "euro" oils (LL-01, A40, 229.5) would be good options.
Re: Oil for Racing and Spirited Driving Apps? [Re: A_Harman] #4454338
07/09/17 01:37 PM
07/09/17 01:37 PM
San Diego, CA
San Diego, CA
I could swear I was reading 3.8 on the Mobil 1 website a couple of days ago.
1987 Honda CRX Si
2015 BMW 320i
2016 Toyota Tundra
Re: Oil for Racing and Spirited Driving Apps? [Re: 1JZ_E46] #4454341
07/09/17 01:38 PM
07/09/17 01:38 PM
San Diego, CA
San Diego, CA
Which Castro 0w40 oil are you talking about?
1987 Honda CRX Si
2015 BMW 320i
2016 Toyota Tundra
Re: Oil for Racing and Spirited Driving Apps? [Re: gryffinwings] #4454343
07/09/17 01:42 PM
07/09/17 01:42 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Castrol EDGE 0W-40 - A3/B4, LL-01, Porsche A40, MB 229.5, VW 502 00. Comes in a 5 qt jug at Walmart for $22-24
Re: Oil for Racing and Spirited Driving Apps? [Re: 1JZ_E46] #4454483
07/09/17 04:25 PM
07/09/17 04:25 PM
San Diego, CA
San Diego, CA
Are you talking about the Castrol EDGE with TITANIUM FST. It's the only one I am seeing on the Castrol Oil website for 0w40. Seems like a good one to use.
1987 Honda CRX Si
2015 BMW 320i
2016 Toyota Tundra
