Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
Cadillac CT5 Revealed
by E365. 03/18/19 01:36 AM
Scored free 0w-20 semi synthetic
by pdxglocker9mm. 03/18/19 01:13 AM
TomRx, Ozdave, Rod1701, Arbitrader, Djdecember
67545 Registered Users
103 registered members (ABerns, 65convertible, addyguy, 928, 10 invisible), 2,283 guests, and 61 spiders.
Topics286,013
Posts4,900,717
Members67,545
Most Online2,967
Mar 10th, 2019
Page 1 of 6 1 2 6
Accord oil specs,US vs Australia #4453282
07/08/17 10:55 AM
07/08/17 10:55 AM
Dallas,Tx USA
aquariuscsm Online content OP
aquariuscsm  Online Content OP
Dallas,Tx USA
Honda in the US has always recommended 20wt oil since 2000. It went from 5W20 to 0W20. My owner's manual lists 0W20 and no other options. Curiosity got the best of me and I decided to see if that was a worldwide recommendation. Shell Australia's lube match recommends Shell Helix Ultra 5W40 for my car. I know this gets beat to death a million times over,but is a 20wt the best oil protection wise for the Honda 2.4? Or is it fuel economy-driven only? I'd thought about meeting it in the middle with a 5W30. Who here uses a 30wt in their Honda 2.4? Here's a copy and paste from Shell Australia Lube Match:
http://www.shell.com.au/motorists/oils-l...zJmNmd5M2EyT04=
Shell Helix Ultra 5W-40
is recommended for your HONDA
Search again
All Lubricants
Accord 2.4i (K24Z3) (Accord Euro) (P) (2008-2015)
Application Recommendation Capacity (ltr) Data Sheets
Engine (P) Helix Ultra 5W-40 4.2
Manual Transmission Refer Owners Manual (a)
Automatic Transmission Spirax S5 ATF X (b)
Coolant Refer to dealer 5.6 AT=5.5
Brake Fluid DOT 4
Clutch Fluid DOT 4
Power Steering Refer Owners Manual 1.1
General Notes
Lubricant / Capacity Notes
a. Use Refer Owners Manual.
b. Fill transmission with specified amount. Start engine. Run engine to normal operating temperature. Switch OFF engine. Within 60-90 seconds check ATF level and top up if necessary. Reset transmission oil change indicator. If replacement of ATF was not due, transmission oil change indicator can only be reset using diagnostic equipment.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453289
07/08/17 11:01 AM
07/08/17 11:01 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
People run thin, people run thick. No ones Honda engine blows up. I conclude it just doesn't matter what viscosity you use. Might as well get the slight gas mileage increase.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453343
07/08/17 11:50 AM
07/08/17 11:50 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I think it's driven by CAFE standards more than anything else.
I have never noticed a significant fuel economy change with engine oil viscosity.
Re: Accord oil specs,US vs Australia [Re: Linctex] #4453372
07/08/17 12:18 PM
07/08/17 12:18 PM
Dallas,Tx USA
Dallas,Tx USA
That's always been my thought as well,especially with all these car companies pushing the limits with thinner and thinner oil specs every year. I think I read here that full sized GM trucks are now spec'd for 0W20? I couldn't imagine an oil that thin in a full sized V8 tuck.
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453386
07/08/17 12:27 PM
07/08/17 12:27 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Australia is upside down compared to the U.S. as well as the water spins the opposite direction when going down the drain hence the difference in viscosity requirements.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453423
07/08/17 01:03 PM
07/08/17 01:03 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
My Ford modular V8 and Ecoboost powered trucks always get significantly better UOA results on 10W-30 vs the required 5W-20. Strangely, I don't have any "cam phaser" issues either....
My oldest F150 just topped 355K miles. M1, 10W-30, 5K OCI's. Still has the crosshatch in the cylinders.
So, while I can't say that the slightly higher viscosity is better for your situation, it is for mine. In fact, the local Ford dealer was using higher viscosity to eliminate warranty problems with the cam phasers and timing chains.
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453441
07/08/17 01:35 PM
07/08/17 01:35 PM
San Antonio, TX
E150GT Online content
E150GT  Online Content
San Antonio, TX
I don't have a honda but I do have a car spec'd for 0w20 and I have had good UOA's showing that it is being protected adequately. Having said that, I switched to 5w30 last oil change to see about limiting consumption in my car and have noticed no difference in fuel economy or power. I have yet to get a UOA on it as I will wait until after next change to flush out the old 0w20.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453505
07/08/17 02:49 PM
07/08/17 02:49 PM
Balearic Islands , Spain
FordCapriDriver Offline
In the US, CAFE Requirements prompted the move to SAE 20, and soon SAE 16 engine oils.
In the rest of the world we don't have CAFE, so manufacturers still spec 5W-30 or 5W-40 oils.
You don't have to use a 0W-20 in your Honda, but you will probably do no harm by using it either.
Unless it has some complex variable valve timing system ( i'm completely unfamiliar with the engine in question ) you can use 30 or 40 grade oils no problem.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453616
07/08/17 05:19 PM
07/08/17 05:19 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
Euro Hondas recommend an A5/B5 oil so basically a 30 GRADE.
Mazda is silmilar. If you own a SkyActiv engine in the US or Canada, 0w-20 is the only recommendation. Mazda genuine is recommended for best fuel economy. Castrol is the only brand mentioned. All markets outside the US and Canada use 5w-30 with 5-w20 being acceptable.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453693
07/08/17 06:52 PM
07/08/17 06:52 PM
Dallas,Tx USA
Dallas,Tx USA
Here's the pdf for the Shell Helix Ultra 5W40:
http://tdc.ge/wp-content/uploads/2014/03/HELIX_ULTRA_5W-40.pdf
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453699
07/08/17 07:04 PM
07/08/17 07:04 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
The US spec for CAFE regs and that last 0.1% of fuel economy that nobody seems to notice in the real world.
Australia always spec as if your daily commute is something like a scene from a Mad Max movie. It's not that a 40 grade protects more in regular gentle applications, it's that a 40 grade has a greater reserve for an extreme situation. Such as towing a overloaded horse float up hill at WOT with a major bush fire licking your tail.
Most engines run fine on most oils, select based on application and climate. I suspect a nice 5W30 Dexos or a 10W30 synthetic will work well for you.
Yes we don't hear of cars blowing up on 0W20, but most don't notice any significant economy gains either from what I have read here. The thing I seem to read about more from my American friends on BITOG, but I don't hear from my Australian friends, is all these oil consumption issues with what I consider to be fairly young vehicles. Like all those Toyota oil burners you have, same cars here, but I don't know any that burn oil, we do run them on 10W40 semi-synthetic from day one.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453731
07/08/17 07:38 PM
07/08/17 07:38 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
No.
Or is it fuel economy-driven only mostly?
Yes.
It is proven that if oil temps climb that the oil will thin. It stands to reason that in some conditions, oil temperatures will rise above 100C and thin out of specification.
I maintain that for a city car, low speeds, frequent starts and stops that 0w20 is probably adequate and saves fuel. Take the same vehicle across the mountains in 40C weather with a heavy load, and a 20 weight may not be providing the best protection.
Thick vs Thin test: 15k / 43k miles complete
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453753
07/08/17 08:12 PM
07/08/17 08:12 PM
Dallas,Tx USA
Dallas,Tx USA
It would be really interesting to see the fluids recommendations page from the Australian owner's manual.
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453779
07/08/17 08:35 PM
07/08/17 08:35 PM
Buffalo, NY
Nickdfresh Offline
Nickdfresh  Offline
Buffalo, NY
Those GM trucks take around eight qts. of oil, complete nonissue...
Re: Accord oil specs,US vs Australia [Re: aquariuscsm] #4453783
07/08/17 08:38 PM
07/08/17 08:38 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
My Accord has the F23 engine (predecessor to the K24). The 98-02 Accords used this engine but starting from 01, Honda switched from 5w30 to 5w20. Same engine, nothing changed, but thinner oil spec'd. CAFE pressure obviously had something to do with this.
That being said, I've got 200k+ running mainly 5w20 (used 5w30 here and there) and the car runs like a top.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Page 1 of 6 1 2 6
