Hello everyone, I was reading a post in this forum where someone was asking if the metallic based detergents that are present in HDEO are bad for engines that burn a lot of oil.
Originally Posted By: A_Harman
Metallic-based detergents (magnesium) in motor oil can lead to more ash deposits in the combustion chambers and exhaust valves. This can be a problem if the engine has a problem with oil consumption down the valve guides or past the rings. More ash deposits in a gasoline engine means more possibility of detonation or preignition. If your gas engines do not have problems with oil consumption, this should not be an issue.
I have a 284k miles 01 Corolla (with an 7afe not an 1zzfe) that burns 1 qt of oil every 1k miles. Will the increased metallic detergents in HDEO be bad for my "oil burner" engine? Should I worry?
Thanks
Thanks
