Detroit 51 series 2 cycle diesel
by Red91. 03/25/19 01:54 PM
Rust repair cost
by supton. 03/25/19 01:41 PM
MANNOL ATF Multivehicle
by Ether. 03/25/19 01:17 PM
Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
128 registered members (555, 1nighttrain, 4WD, 928, 69Torino, 2012AccentSE, 14 invisible), 2,249 guests, and 65 spiders.
Topics286,402
Posts4,907,677
Members67,614
Most Online2,967
Mar 10th, 2019
Metallic based detergents in HDEO bad for gas eng #4452659
07/07/17 07:32 PM
07/07/17 07:32 PM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
Hello everyone, I was reading a post in this forum where someone was asking if the metallic based detergents that are present in HDEO are bad for engines that burn a lot of oil.
Originally Posted By: A_Harman
Metallic-based detergents (magnesium) in motor oil can lead to more ash deposits in the combustion chambers and exhaust valves. This can be a problem if the engine has a problem with oil consumption down the valve guides or past the rings. More ash deposits in a gasoline engine means more possibility of detonation or preignition. If your gas engines do not have problems with oil consumption, this should not be an issue.
I have a 284k miles 01 Corolla (with an 7afe not an 1zzfe) that burns 1 qt of oil every 1k miles. Will the increased metallic detergents in HDEO be bad for my "oil burner" engine? Should I worry?
Thanks
Re: Metallic based detergents in HDEO bad for gas eng [Re: Emanuel] #4452673
07/07/17 07:51 PM
07/07/17 07:51 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
That's not really bad consumption. That is what many older Volvo's did from the factory. Yeah, it's not ideal for the CAT, but do you have SMOG tests where you operate this car?
If not, don't worry smile
And not all refiners use a lot of Mg in their blends ...
So, does this car smoke going down hill using engine braking, or more just when you start it up first thing?
Re: Metallic based detergents in HDEO bad for gas eng [Re: Emanuel] #4452704
07/07/17 08:08 PM
07/07/17 08:08 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
2 strokes burn oil all the time, I've certainly seen plenty destroyed by detonation, but it's not caused by burning oil.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Metallic based detergents in HDEO bad for gas eng [Re: Silk] #4452723
07/07/17 08:27 PM
07/07/17 08:27 PM
USA
ArcticDriver Offline
USA
No disrespect intended for a Kiwi but 2-stroke oil is designed to be burned as part of the combustion process while HDEO is not.
Any chance you know the quantity of metsllic detergents used in 2-stroke oil?
Multiple Diesel and Gasoline vehicles
Re: Metallic based detergents in HDEO bad for gas eng [Re: BrocLuno] #4452724
07/07/17 08:27 PM
07/07/17 08:27 PM
Emanuel Offline OP
Emanuel  Offline OP
For me the oil consumption doesnīt seem high neither, it doesnīt produce visible smoke in any condition. It had an overheat 10k miles ago and all the gasket and seals of the head where changed. I did a test driving it mildly hard with my dad driving behind me to see if the piston rings suffered any damage from the overheat and he didnīt saw any smoke.
Re: Metallic based detergents in HDEO bad for gas eng [Re: Emanuel] #4452802
07/07/17 09:21 PM
07/07/17 09:21 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
If someone is looking to blame things on Magnesium additives then look no further than Mobil 1 20/30 grades and Castrol Edge 0w-40. Magnesium cuts a wider swath than just HDEO's.
So now we potentially have that too much magnesium could be bad...and then too much calcium can be pad for TDI's. What's left?
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Metallic based detergents in HDEO bad for gas eng [Re: ArcticDriver] #4452826
07/07/17 09:37 PM
07/07/17 09:37 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
Not all 2 strokes use 2 stroke oils, and many people use engine oils in bikes designed for 2 stroke oil. I used SAE30 in my BSA Bantam. Not being stupid, just expanding the subject beyond the normal narrow viewpoint.
Re: Metallic based detergents in HDEO bad for gas eng [Re: Silk] #4452863
07/07/17 10:10 PM
07/07/17 10:10 PM
USA
USA
Can you provide a link to a modern 2-stroke engine owners manual which instructs using 4-cycle oil rather than 2-stroke oil?
Thanks
Re: Metallic based detergents in HDEO bad for gas eng [Re: Emanuel] #4452909
07/07/17 11:28 PM
07/07/17 11:28 PM
BrocLuno Offline
BrocLuno  Offline
Prolly not, but a Bantam is a ways back there like WW-II, unless they are selling under that label again. It was the British take on the DKW from Germany back in the day. And at the time, the owners would use nearly any oil as some is better than none ...
Re: Metallic based detergents in HDEO bad for gas eng [Re: ArcticDriver] #4452921
07/07/17 11:42 PM
07/07/17 11:42 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
Thanks
EMD engines made up to 2014 were two stroke and used "4 stroke" oil.
Re: Metallic based detergents in HDEO bad for gas eng [Re: Emanuel] #4452944
07/08/17 12:22 AM
07/08/17 12:22 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
Sorry but whoever is saying Mg detergents are bad for ash and oil consumption is talking out of his or her arse!
For starters, for a given TBN, a Mg-based detergent will ALWAYS give you a LOWER Sulphated Ash than the equivalent Ca-based detergent. It's something that formulators exploit if high ash becomes a problem.
Second, for a given level of TBN in oil, a 400 TBN Mg Sulphonate (its most common form) will always yield a LOWER Noack finished oil than 300 Ca Sulphonate. Noack, not ash content is the main determinant of evaporative oil loss.
Third, if you are running say a very high Noack oil on a car that has a propensity to burn oil via evaporative oil loss, then what gets evaporated from the oil is primarily light base oil. The relatively heavy metallic detergent stays in the sump and cannot create deposits on valves or in the combustion chamber.
Finally, modern HDDOs tend not to contain excessive amounts of metallic detergent or have particulary high TBNs, so this per se should not put you off running them on a gasoline engine. I very much doubt you will find a commercial HDDO based on Magnesium but if you could, then grab it with both hands because it is good stuff!
Changing subjects, 2-stroke oils usually have very low ash content which is why they can be burnt and not leave deposits behind.
Re: Metallic based detergents in HDEO bad for gas eng [Re: 69GTX] #4452952
07/08/17 12:45 AM
07/08/17 12:45 AM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Sodium, Valvoline!
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Metallic based detergents in HDEO bad for gas eng [Re: SonofJoe] #4452962
07/08/17 01:02 AM
07/08/17 01:02 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
The CJ-4/SM Delvac 1 ESP 5w-40 I use is (and have unfortunately little left) is magnesium based. I'm not sure about the CK-4 version. I'd love to see some VOAs of the new stuff, but I guess we have to wait.
Plain, simple Garak.
Re: Metallic based detergents in HDEO bad for gas eng [Re: ArcticDriver] #4452975
07/08/17 02:06 AM
07/08/17 02:06 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Thanks
http://projectmopedmanual.info/Manuals/Rizzato_Califfo/Rizzato%20Califfo%20owners%20manual.pdf
This in the late 70s...note that clearly in referencing not to use multigrades it was identifying 4 stroke oils...
Some recent Chinese ATV manuals also specify an SAE30, but the wording is a bit more ambiguous.
Re: Metallic based detergents in HDEO bad for gas eng [Re: SonofJoe] #4452977
07/08/17 02:08 AM
07/08/17 02:08 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Joe,
back in my Uni days, we were told that the Mg left harder, more abrasive deposits than the Ca...
