2019 Subaru Crosstrek FB20D - Oil choices
by cluster5. 03/26/19 09:31 PM
.05 Cent haynes manual
by Jman26063. 03/26/19 09:02 PM
Pennzoil Canada Rebate
by Snagglefoot. 03/26/19 09:01 PM
Burned out blinker
by Chris142. 03/26/19 09:00 PM
Best Moly add for timing chain health?
by RichR. 03/26/19 08:53 PM
Kenmore dishwasher quit.
by Trotter. 03/26/19 08:49 PM
Urethane with integrated clear coat cure time?
by FixItDad28. 03/26/19 08:39 PM
Chevron rykon premium mv alternative?
by Framer. 03/26/19 08:12 PM
Got a bunch of new old stock oil and filters...
by dogememe. 03/26/19 07:04 PM
Right turn signal blinking super fast
by das_peikko. 03/26/19 06:55 PM
Another fun car to work on.
by Chris142. 03/26/19 06:48 PM
Equivalent LED T8/T12 tubes?
by y_p_w. 03/26/19 06:37 PM
Do you use chemicals on your lawn?
by ZZman. 03/26/19 05:21 PM
Baked Cabbage Steaks
by StevieC. 03/26/19 02:57 PM
Best Store Bought BBQ Sauce?
by Redright9. 03/26/19 02:26 PM
Hankook tire rebate
by FordBroncoVWJeta. 03/26/19 01:14 PM
Framer, Joe_Gibbs, PerryPerrister, brak132, mike001100
67635 Registered Users
94 registered members (4WD, 555, advocate, 2010Civic, 2002 Maxima SE, 928, 9 invisible), 1,890 guests, and 93 spiders.
Topics286,475
Posts4,909,129
Members67,635
Most Online2,967
Mar 10th, 2019
'16 Colorado v6 - RP 5w30 - 5102 miles #4452635
07/07/17 07:06 PM
07/07/17 07:06 PM
NY
c5z06 Offline OP
c5z06  Offline OP
NY
2016 Colorado v6
Royal Purple 5w30
5,102 miles on oil
6,907 miles on motor
Re: '16 Colorado v6 - RP 5w30 - 5102 miles [Re: c5z06] #4452657
07/07/17 07:27 PM
07/07/17 07:27 PM
MN
oil_film_movies Offline
MN
Still breaking in! Too much iron.
Viscosity (both 1st FF oil and your RP) dropped quite a bit, but nothing hazardous.
Suggest getting a Dimple or GoldPlug magnetic drain plug and installing a Royal Purple or Fram Ultra oil filter to get smaller stuff (0.3 solubles might drop).
Re: '16 Colorado v6 - RP 5w30 - 5102 miles [Re: oil_film_movies] #4452660
07/07/17 07:35 PM
07/07/17 07:35 PM
NY
c5z06 Offline OP
c5z06  Offline OP
NY
Thanks for the feedback. When I bought the 12 qts of RP I also purchased two K&N filters. After this next round I'll switch to the Fram Ultra, running that on my other cars. As for drain plug, I just installed a Fumoto drain valve, bc I am lazy (also I moved and haven't purchased my lift yet).
Re: '16 Colorado v6 - RP 5w30 - 5102 miles [Re: c5z06] #4452674
07/07/17 07:52 PM
07/07/17 07:52 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Oil sheared over 20%. From 10.4 to 8.0. I may consider something else after you've used up your stash of RP.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: '16 Colorado v6 - RP 5w30 - 5102 miles [Re: 1JZ_E46] #4452703
07/07/17 08:07 PM
07/07/17 08:07 PM
NY
c5z06 Offline OP
c5z06  Offline OP
NY
I am new to UOA, the shearing would show in the results of "cSt Viscosity @ 100*C" ? Where does 10.4 come from? A VOA?
Also I see "SUS Viscosity @ 210*F" looks out of range as well.
Re: '16 Colorado v6 - RP 5w30 - 5102 miles [Re: c5z06] #4452714
07/07/17 08:15 PM
07/07/17 08:15 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Correct. 10.4 is what it is new (from RP's website) and it came out at 8.0. This means the oil broke down and became thinner (can also happen due to fuel dilution, which you don't have). Usually oils shear a bit and then start to thicken as they oxidize and accumulate soot.
Re: '16 Colorado v6 - RP 5w30 - 5102 miles [Re: c5z06] #4452737
07/07/17 08:36 PM
07/07/17 08:36 PM
New York Queens
Ram02 Offline
Ram02  Offline
New York Queens
Save your money and stick with PP or pennzoil gold can't go wrong
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: '16 Colorado v6 - RP 5w30 - 5102 miles [Re: c5z06] #4452878
07/07/17 10:32 PM
07/07/17 10:32 PM
MN
MN
Is it true oils shear more in newer engines??? If the micro-surface topology is shedding iron, the machining marks getting polished down, etc., it does seem thats a mechanically stressful environment.
Re: '16 Colorado v6 - RP 5w30 - 5102 miles [Re: c5z06] #4526355
09/26/17 03:53 AM
09/26/17 03:53 AM
Virginia, usa
Shata Offline
Shata  Offline
Virginia, usa
Your engine is still way to new to really nit pick and look into this report to deeply. At 9k miles on my last report the engine was still breaking in with slight lead and Ok/ish copper ppm. Its good to start trend early on but honestly I dont think we will see stuff level off trend wise till around 30k.
16 Silverado 2500 LML 20k Miles
Rotella 5w-40 T6
ST 75w-90 GL5 Diff.
ST Full Syn Dexron VI ATF
Fram Ultra XG9100, AC Delco Fuel
CAT Coolant, K&N Air, K&N Cabin
Filter Mags: Fuel, Allison, LML
