Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
06/22/18 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fram SureGrip coating
by mobilaltima
06/21/18 08:24 PM
Manual transmissioned electric car
by mjoekingz28
06/21/18 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
06/21/18 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
06/21/18 06:02 PM
Traveller nlgi 2
by Spitter
06/21/18 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
06/21/18 05:08 PM
Any nano reefers here?
by RichardS
06/21/18 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
06/21/18 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
06/21/18 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
06/21/18 04:31 PM
help me choose...
by chaindrive
06/21/18 04:07 PM
France F1 Grand Prix
by DeepFriar
06/21/18 03:16 PM
Valvoline High Mileage with maxlife tech semi-syn
by bradtech
06/21/18 03:16 PM
ZEK, Dudewayne, kmdz, harborbirds, frascati
65292 Registered Users
21 registered (Char Baby, dishdude, 14ecocruze, Billbert, Black_Thunder, 4 invisible), 357 Guests and 33 Spiders online.
65292 Members
67 Forums
285751 Topics
Page 1 of 2 1 2 >
#4452558 - 07/07/17 05:55 PM Coiling up Coaxial Cable
Merkava_4 Offline
Loc: Clovis, CA
I got an extra 6 feet of Comcast cable coming through the wall. How tight can I coil the cable up without damaging it? Right now it wants to be coiled up at a relaxed 16 inch diameter, but I'm wondering if I can coil it up tighter without breaking it. The cable is super stiff compared to Ethernet cable.
#4452560 - 07/07/17 06:01 PM Re: Coiling up Coaxial Cable [Re: Merkava_4]
Linctex Offline
Loc: Waco, TX
Try feeding back into the wall first.
#4452561 - 07/07/17 06:02 PM Re: Coiling up Coaxial Cable [Re: Merkava_4]
bioburner Offline
Loc: Minnesota
I have several pieces around the house that are coiled to about 6 inches. The stuff is shielded and that bulks it up and makes it stiffer
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4452565 - 07/07/17 06:05 PM Re: Coiling up Coaxial Cable [Re: Linctex]
Merkava_4 Offline
Loc: Clovis, CA
Linctex - that can't be done because the hole where the cable comes through the wall is filled in with silicone sealant.
Bioburner - 6 inches would be plenty tight enough. Even 10 inches would look better than it is now.
#4452573 - 07/07/17 06:09 PM Re: Coiling up Coaxial Cable [Re: Merkava_4]
eljefino Offline
Loc: ME
Don't coil it too much tighter than the 16 in dia. You can get screwy results by snapping that center conductor. EG kinda sorta still working intermittently.
The fix is to cut the wire off where you want it and splice a new F connector on. You might even be able to flirt with comcast into doing it for you.
#4452580 - 07/07/17 06:16 PM Re: Coiling up Coaxial Cable [Re: eljefino]
Merkava_4 Offline
Loc: Clovis, CA
Eljefino - that would probably be the best way if I could make up my mind where I want the modem to sit.
#4452584 - 07/07/17 06:29 PM Re: Coiling up Coaxial Cable [Re: Merkava_4]
eljefino Offline
Loc: ME
I put my modem in my basement and use Cat-5 to get it to my 2nd wifi hot spot as well as my blu-ray player so it doesn't overload the wifi. Clean. approved
#4452590 - 07/07/17 06:40 PM Re: Coiling up Coaxial Cable [Re: Merkava_4]
Superflop Offline
Loc: Seattle
Im going to guess it is rg6 coax which has a min bend radius somewhere around 10x the cable diameter.. or like 3 inches. If the jacket is wrinkling you are going to small
Edited by Superflop (07/07/17 06:40 PM)
2002 saab 9-5 2.3t wagon
2014 dodge grand caravan
#4452652 - 07/07/17 07:23 PM Re: Coiling up Coaxial Cable [Re: Merkava_4]
Johnny2Bad Offline
Loc: Saskatchewan, Canada
When you coil Coax, you break the integrity of the shield if it's copper alone (no additional mylar shield) and knowing how the average Cable Co operates, they are almost certainly using the cheapest bulk cable they can find, which means probably copper braid only.
Most Coax cable, if you can find the spec, will have a minimum bend radius limitation. Again, the chances of you finding the spec for what your Cable Co uses is slim to none, but 6" is a pretty common number.
Also note that when you coil any cable you create an inductive element, and inductance can lead to instability in some cases. Coiling a power cable can trip breakers, for example, where if you instead lay the cable out in a straight line to take up the slack it may run your power tool all day.
In the end, it's best to cut it to the desired length and add a connector.
You don't have to do that yourself ... it's the installer's fault and it's the installer's problem to fix. Create a ticket. If they give you grief about the reason, hang up, and make something up and call again. The installer will fix it in five minutes when he gets to you.
On the other hand, maybe you do want to do it yourself ...
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
#4453632 - 07/08/17 05:40 PM Re: Coiling up Coaxial Cable [Re: Merkava_4]
sleddriver Offline
Loc: Central Texas
I'm guessing what you have is RG-6 (maybe QS) with a solid center conductor. It is indeed much stiffer than Ethernet.
The more relaxed, the better. Coiling also induces inductance but with such a large dia., it won't matter much.
1998 Volvo V70 T5 226,808 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
#4453824 - 07/08/17 09:34 PM Re: Coiling up Coaxial Cable [Re: Merkava_4]
dishdude Online   content
Loc: Phoenix
Drip loops are allowed to be 3" in diameter or larger, so it can be coiled pretty tight without damage.
2018 Challenger SRT
#4453907 - 07/08/17 11:16 PM Re: Coiling up Coaxial Cable [Re: Merkava_4]
CKN Offline
Loc: Utah
They do that so if you re-arrange the room you have plenty of cord to do so. It's standard operating procedure.
#4453943 - 07/09/17 12:56 AM Re: Coiling up Coaxial Cable [Re: CKN]
Merkava_4 Offline
Loc: Clovis, CA
I got it coiled up in an 8-inch loop now. I'm not going any smaller than that.
I also noticed they used 16 gage coaxial instead of the 18 gage homeowner grade.
#4454009 - 07/09/17 05:43 AM Re: Coiling up Coaxial Cable [Re: Merkava_4]
Lubener Offline
Loc: N.Ohio
Your fine. Coaxial cable is more rugged than you think.
Edited by Lubener (07/09/17 05:44 AM)
The "thinking" man's friend.
#4454208 - 07/09/17 11:19 AM Re: Coiling up Coaxial Cable [Re: Merkava_4]
SHOZ Offline
Loc: Illinois
Cut it to fit and add a new plug end.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Page 1 of 2 1 2 >
