Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
144 registered members (4WD, 92saturnsl2, 77GrandPrix, 01rangerxl, 1foxracing, 2015_PSD, 11 invisible), 2,053 guests, and 52 spiders.
Topics286,086
Posts4,902,285
Members67,560
Most Online2,967
Mar 10th, 2019
Is this a good Hose Clamp (Camridge Resources/NAPA #4452527
07/07/17 05:15 PM
07/07/17 05:15 PM
Seattle-ish, WA
Oro_O Offline OP
Oro_O  Offline OP
Seattle-ish, WA
I have a leaking upper radiator hose. The hose was new 50k ago when I did the timing belt. The Mubea spring clamp wouldn't snug the new hose and I used a typical cheap hose clamp from a parts box of them I had. Fast forward 3 years and now it's weeping. I re-tightened it very snug (hose bulging into slots, but really only on one side), but it still weeps a drop or two overnight.
Is this "constant torque" clamp a solution:
Napa/Cambridge Resources hose clamp
Or a good all-around tension clamp of some type? I have a NAPA nearby and it's a lot easier than hunting down another Mubea/spring clamp.
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: Oro_O] #4452535
07/07/17 05:20 PM
07/07/17 05:20 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I know it says CT clamp but the picture isn't one. So hopefully the picture is just wrong. Being NAPA the part should be decent and I'd go with it. Just inspect prior to purchase to see what it actually is.
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: Oro_O] #4452540
07/07/17 05:24 PM
07/07/17 05:24 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You can get those clamps from McMaster-Carr
I think you'll find the spring will be COMPLETELY bottomed out by the time you get it tight enough, though.
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: SatinSilver] #4452541
07/07/17 05:24 PM
07/07/17 05:24 PM
Seattle-ish, WA
Oro_O Offline OP
Oro_O  Offline OP
Seattle-ish, WA
OK, that's what I couldn't figure out. I can't see how the pictured part would provide "constant torque," but have read that is a good option.
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: Oro_O] #4452544
07/07/17 05:29 PM
07/07/17 05:29 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Looks like a worm clamp. Which need to be routinely tightened. So I'd keep looking for a true CT clamp. Hopefully just the picture is wrong.
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: Oro_O] #4452610
07/07/17 06:51 PM
07/07/17 06:51 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
That is a good constant tension clamp, its called a belleville spring folks.
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: Oro_O] #4452614
07/07/17 06:53 PM
07/07/17 06:53 PM
midwest
JamesBond Online content
JamesBond  Online Content
midwest
I would look into a new hose hose too. If it was leaking at single digit winter temps I might try a new clamp but since its summer you might need both a hose and clamp.
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: Oro_O] #4452681
07/07/17 07:56 PM
07/07/17 07:56 PM
NJ
Leo99 Online content
Leo99  Online Content
NJ
I bought some fancy made in the USA hose clamps off Amazon. Garbage. No better than the cheap clamps you can get at Walmart. I'd use the OEM spring type if I knew the exact size to buy.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: Leo99] #4452749
07/07/17 08:49 PM
07/07/17 08:49 PM
Central Maryland
HangFire Online content
HangFire  Online Content
Central Maryland
It would be really nice if you could tell us what brand and/or vendor that was.
I've had good luck with Breeze Constant Torque clamps. I happened to get them off of Amazon, which means almost nothing.
Various musings: http://hangfire.net
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: HangFire] #4452761
07/07/17 08:57 PM
07/07/17 08:57 PM
NJ
NJ
Breeze Power Seal stainless steel hose clamps. Maybe "garbage" is too strong a word but I didn't think they were anything special. Maybe my expectations were too high.
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: Oro_O] #4452803
07/07/17 09:22 PM
07/07/17 09:22 PM
Toronto, Canada
George7941 Offline
George7941  Offline
Toronto, Canada
I would use a Gates shrink clamp, available at RockAuto. They are very good at preventing cold leaks. I have never had a hose clamped down with a shrink clamp ever leak.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: Oro_O] #4453055
07/08/17 06:14 AM
07/08/17 06:14 AM
Trav Offline
Trav  Offline
As someone posted change the hose, get that Napa clamp and order some Hylomar M (google for best price ebay usually) put a thin bead around the hose necks and push the hose on with the clamp. The Hylomar will act as a short acting lube then firm up. You will never have a leak and unlike RTV it does not make removal difficult, the hose comes right off.
This is a very common issue especially with plastic necks, this will cure it every time. I use it on every job metal or plastic. Once you use this stuff I guarantee you will never be without a tube of it.
http://www.ebay.com/itm/Hylomar-M-Univer...738.m2548.l4275
BTW A Belleville multi washer spring as shown in the clamp you posted is strong and very long lasting, it retains tension for a long time through many cycles, some motorcycle clutches use a large single Belleville spring like this for the clutch because it exerts force uniformly over a wide area.
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: Oro_O] #4453065
07/08/17 06:42 AM
07/08/17 06:42 AM
Florida
SilverSnake Offline
SilverSnake  Offline
Florida
The picture is correct and it does provide constant torque. Here is a good explanation of how it works:
https://www.jamestowndistributors.com/userportal/show_product.do?pid=63770
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
Re: Is this a good Hose Clamp (Camridge Resources/NAPA [Re: Oro_O] #4453359
07/08/17 12:03 PM
07/08/17 12:03 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
Old mechanic's trick is to use Permatex #2 inside the hose, then clamp it w/new clamp. Only problem from this is that you'll have to cut the hose off when it's time to replace it. I too would consider a new hose. It's already 3 years old.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
