Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
2017 Hyundai Tucson burning oil (Help!)
by carviewsonic. 09/23/18 11:09 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
83 registered members (77GrandPrix, BigCahuna, aikwae, 3Aone, Al, 55hambone, 8 invisible), 1,733 guests, and 37 spiders.
Topics290,900
Posts4,852,127
Members66,047
Most Online3,590
Jan 24th, 2017
2011 Dodge Durango? #4452227
07/07/17 10:54 AM
07/07/17 10:54 AM
Nebraska
Mathew_Boss Offline OP
Nebraska
I need to change transmission oil, transfer case oil, and diff oil on my new to me 2011 Dodge Durango. Its 5.7l AWD Citadel variant. Trying to pick a brand. I'm leaning toward Valvoline going to use Full Syn in everything. Currently about to cross 109,000 miles by the end of the weekend and I don't know the history on it other than they replaced water pump and thermostat as well as fixing an exhaust leak (Both bolts on Cylinder 8 were broken).
125k Mile 11 Dodge Durango 5.7L Hemi PP HM or QSUD 5w20 or 0w20 w/Purolator Boss or Wix XP
40k Mile 2015 Dodge Charger 3.6L Pentastar Pennzoil Platinum or QSUD 0/5W20, or 5W30
Re: 2011 Dodge Durango? [Re: Mathew_Boss] #4452243
07/07/17 11:06 AM
07/07/17 11:06 AM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
So, I see Dodge continues to have exhaust bolt issues.
You don't list if it's 4WD or AWD, but the transmission and probably the transfer case use ATF+4. Genuine ATF+4 is licensed by Chrysler and it's all the same, whether it's marked "synthetic" or not. Buy something from this list:
http://www.centerforqa.com/chrysler-brands/
Re: 2011 Dodge Durango? [Re: HangFire] #4452246
07/07/17 11:09 AM
07/07/17 11:09 AM
Nebraska
Nebraska
Sorry it says AWD but it also has a selector switch that says 4wd Auto or Low.
Re: 2011 Dodge Durango? [Re: Mathew_Boss] #4454875
07/10/17 01:17 AM
07/10/17 01:17 AM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
Your transmission undoubtably takes ATF+4. I recommend sticking with a licensed ATF+4 and not some multi-vehicle ATF that claims its suitable for ATF+4 applications.
Transfer case depends on the model. If it's a Borg Warner B44-44 like my 2012 Ram 4WD, it takes a special fluid from Mopar. Only Amsoil offers an aftermarket fluid advertised for the BW44-44 TC.
Best to check the build sheet, window sticker, VIN, or crawl under and see which model TC is installed on your vehicle.
Check your OM but its likely your front differential is spec'd for 75W-90 and your rear differential is likely spec'd for 75W-140. Since your TC has a 4WD Auto option your rear differential probably isn't a limited slip variety but again a check of documents that are vehicle specific to your vehicle would be best.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: 2011 Dodge Durango? [Re: Mathew_Boss] #4455465
07/10/17 04:54 PM
07/10/17 04:54 PM
USA
slacktide_bitog Offline
USA
All licensed ATF+4 on Chrysler's approval list is the same since they require a specific group III base stock and a specific Lubrizol add pack. Walmart's ST ATF+4 is licensed and thus OK to use smile
However, if you're willing to spend the money, Redline C+ is the best fluid to use where ATF+4 is called for. Although it isn't licensed due to Chrysler's childish, overly strict criteria, it is still the best to use. Red Line C+ uses the same add pack that is required for licensed ATF+4, but uses a group V ester base stock (which is why it isn't licensed)
