Originally Posted By: Ducked
No hole, no foul, I'd have thought.
What problem were you anticipating?
Microscopic degradation of the filter media.
IF it had microscopic degradation of the filter media, you wouldn't be able to see it without...a microscope.
The chances of anyone on here (a) spilling petrol on one of these filters and (b) checking it out with a microscope seem vanishingly small.
For microscopic degradation of the filter media to be relevant, it has to make holes in the media that are too small to see, but bigger than the holes that are already there.
This seems to require a petrol-soluable "foam" filter media supported by a very fine petrol-insoluable matrix. This seems an unlikely construction for the filter.
A quick look at the website gives no meaningful information on how the thing is constructed, and is even ambiguous as to whether the media is synthetic or cotton.
I suppose if it was cotton bound with a synthetic coating (a reasonable best guess) then the media would be insoluable and the binding might be soluable, so undetectable microscopic damage would be a possibility.
There doesn't seem to be any way to estimate how probable this is though.
The gas spill came from a hose connected to the fuel rail. Some gas dripped from a hose while taking it off (filter is under the front fender behind the headlight). We race the car and drain the tank before putting in race gas. It's easy to spill small amounts
