Transmission Fluid Pressure?
New England
Simple question which I assume is fairly straightforward industry-wide.
What is the pressure of transmission fluid as it is pumped through the radiator? I assume there are variations among makes and transmissions but fairly similar on the whole.
Not alot, if you do a fluid exchange it isn't coming out at a significant pressure unless you were to block the hose, which wouldn't happen (the radiator flows unrestricted back to the drain pan).
Actually, though, many trannys vary the pressure going through the tranny via the solenoid pack. So I guess the pressure could be higher in operation, but still next to nothing.
I made that assumption too until I thought about how transmissions work and realized that free flow into the pan is unlikely and often impossible.
We'd like to cool the transmission fluid after it has worked. It isn't possible to collect worked fluid under pressure as it squirts out of random bearing surfaces. It just falls into the pan. Engine oil couldn't be cooled this way either.
We could also cool the fluid as it exits the pump. Not possible since the pressure can rise to over 250 psi and the fluid couldn't be held in with low pressure hose. Thin wall radiators would be stressed excessively and any leak or free flow into the pan would result in instant loss of oil pressure. Good design mandates that the area subject to 250 psi be as confined as possible, and certainly not in the rickety lines and radiator. Some transmissions have a high pressure test port and the cooler line is not it.
If the fluid free flowed into the pan, flare connections and high pressure hose would not be needed, just like they are not needed for the power steering return which does free flow into the tank. Manufacturers use flare connections and high pressure line for factory cooler lines though low pressure hose with standard clamps also works, often seen in repairs and aftermarket coolers.
It should be obvious that these problems apply to all automatic transmission manufacturers. Manufacturer coolers equipped with low pressure lines might indicate that the oil flows freely in the pan.
Though I don't know how, GM transmission lines do not free flow into the pan and maintain a steady psi about 35. I've blown into the drain line just to check.
Conjecture:
The cooler line oil must come from the high pressure system. It must be pressure regulated to allow the rest of the system to maintain pressure as a metered amount of oil flows through the cooler. The drain into the pan must be flow regulated through an orifice or it might be used to supply a low pressure system.
not much back pressure... output pressure from the pump(s) is not the same as return line pressure.
Don't know whether transmission uses full flow of bypass systems for coolers.
Return line pressure does not need to be regulated. being free flowing back into the pan is the {"regulator") because it does not allow pressure to build.
so most or all transmissions use bypass cooling?
edit: nvm you were talking about pressure.
you guys are gonna make me hook up a gauge to my return line arn't you?
lol
The reason I ask is because of the current thread about coolant in someones transmission fluid. My guess would have been that transmission fluid is at a higher pressure than the coolant (which is probably under 20 psi in most applications).
I don't know if there's consistency across brands in that regard or not. I know Mopars generally routed the fluid to the cooler and then to the lubrication points throughout the gear train and bearings, so the pressure through the cooler is on the order of 30-40 PSI. If there are automatics that return cooled fluid directly to the pan instead, the pressure would be significantly lower.
So in this case, the fluid pressure is generally higher than the cooling system, but its not a fail-safe. The instant you turn the engine off the trans fluid pressure drops to zero, but the cooling system pressure can continue to rise. The one time I had a trans cooler fail, things went both ways. There was brown mud in the radiator from oil pumping into the cooling system when the engine was running, and there was brown mud in the transmission pan from coolant getting pushed into the cooler when the engine shut off. Oh, and a quirk of chemistry is that transmission fluid makes the silicates precipitate out of old-style coolants. So it really IS brown mud... sandy mud.
I agree with the 50lb+/-. Mine was 30lb @ idle semi cold (but not stone cold). It's got limits.
While you would normally reason that you would see ATF in the coolant instead of the other way around, when you shut down the engine, the line pressure is gone immediately, the coolant pressure is not.
I think you and 440Magnum nailed it with this.
+1.5
I know we've discussed this before, but I'm still not clear on the whole PSIG in the ATF cooler circuit thing. I realize the cooler inlet hose could develop some tremendous pressure given the proper restriction, but the cooler return lines on the transmissions I've flushed or messed with over the years is a no pressure line that just returns to the sump? So basically, any pressure you'd see in that circuit during normal operations would be due to dP/restriction in the system, correct?
Joel
Most pressure numbers stated in the other posts are close to correct. The pressure varies with pump RPM and fluid temp. Mods can be done to the valve body to increase flow through the cooling circuit. That brings me to the next point. The return oil from the cooler is a major part of pressurized LUBE CIRCUIT for the entire automatic trans. No cooler flow means no pressurized lube to the rotating components. The oil does not simply return to the pan. This is also the reason that there are factory bypasses in the cooler circuit. Reason being in the event of extreme cold weather the oil is reluctant to flow fast enough through the cooler to get back to the trans to lube the rotating parts. This can and has caused lack of lube failures leading to a low mileage rebuild. Chrysler had this problem with their front wheel drive cars and vans in the early '90s. Bypass valve kits where installed into the cooler lines in the cold weather states to resolve this issue in the field. The newer tranny's had the by pass valve designed internally.
Originally Posted By: MacGyver
The return oil from the cooler is a major part of pressurized LUBE CIRCUIT for the entire automatic trans...... The oil does not simply return to the pan.
Understood. So the return oil DOES do some traveling before it trickles down into the sump. I guess that answers my question then in regards to where the pressure comes from in that system. Thank you Sir.
Joel
Originally Posted By: userfriendly
So... would adding an in-line filter to the cooling lines be a good idea or not?
For what purpose? To stop coolant contamination, in case of failure of the coolr; or to prolong transmission lifespan by catching very small particulates? I'd think a filter couldn't help with the former, but many would argue the latter.
it's not under much pressure, but transmissions vary. In mine, for instance, the cooler loop is a branch off another feed. if I recall, it basically leaves the torque converter and goes on to perform general lubrication. A branch is pulled off of that and diverted to the cooler loop. if the temp is under 160F or so, a bypass valve opens which allows the fluid to skip the cooler. In my trans, I believe the spent fluid from the cooler returns to the sump. I've read 4-6 psi.
-m
For the sake of all that is holy, when a thread has been dead over seven years, leave it alone!
Open a new one with an intelligent premise and question if you feel the need. Many forums auto-block this kind of thread necrophilia; maybe this forum should adopt it (hint).
