Review: CVJ Remanufactured CV Axles
by The Critic
Today at 03:40 AM
Towing without 85w140?
by OilFilters
Today at 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
Yesterday at 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
Yesterday at 11:13 PM
Darn dogs
by AZjeff
Yesterday at 10:21 PM
New GC?
by Bullwinkle007
Yesterday at 10:04 PM
The guy with the plexiglass head on you tube
by andyd
Yesterday at 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
Yesterday at 09:10 PM
SAE 90 v 85/140
by Knuckle078
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
Yesterday at 08:45 PM
what happened to merk
by ernied
Yesterday at 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
Yesterday at 07:41 PM
Decent MP3 player
by Ed_T
Yesterday at 07:08 PM
Letgo
by Donald
Yesterday at 06:52 PM
Tire buying advice
by supton
Yesterday at 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
Yesterday at 06:21 PM
No older cars in New York State?
by Oldtom
Yesterday at 06:19 PM
2009 Taurus strut mount noise
by terry274
Yesterday at 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
Yesterday at 03:36 PM
2003 Honda power steering problem
by hogpops
Yesterday at 03:29 PM
lozpxs, danthemanx07, FunktasticLucky, Knuckle078, penncove
65317 Registered Users
35 registered (2015_PSD, Bailes1992, bmod305, billt460, Astro_Guy, bbhero, 1 invisible), 808 Guests and 37 Spiders online.
65317 Members
67 Forums
285954 Topics
Page 1 of 3 1 2 3 >
#4451673 - 07/06/17 07:47 PM Subaru STi race engine, RP XPR 5W/30, 3hrs
Scargo Offline
Loc: S. CT, USA
Subaru 2.5L (EJ25) Dual AVCS, 4-cyl Turbo, race motor, track use, 7,500 RPM, 430 WHP, BW EFR turbo.
OIL TYPE & GRADE: Royal Purple XPR 5W/30
HR on Oil: 3 Hours
Total HR on engine: 6 hours
I am using 32 ounces of TORCO per 5 gallons of premium 93 octane, the maximum amount of Torco octane booster additive, in my
fuel.
The other thing I did, which may be inappropriate, is I drained the oil cold and collected my sample after a quart or so ran out. Could that cause volatiles (fuel) to be missed?
I have no hint of impending doom. No excessive blowby for a race engine.
Engine is conservatively tuned so A/F ratios are fairly fat.
Oil pressure is good. 60-80 PSI. Nine quart capacity. I use K&N HP 3001 filters. Race engine bearing clearances of 1.5 on mains. ACL racing bearings.
Any thoughts on the high lead number? Should I continue to use the oil (for more hours)?
ALUMINUM 6
CHROMIUM 3
IRON 24
COPPER 4
LEAD 125
TIN 1
MOLYBDENUM 104
NICKEL 0
SILVER 42
TITANIUM 0
POTASSIUM 2
BORON 41
SILICON 10
SODIUM 7
CALCIUM 2496
MAGNESIUM 11
PHOSPHORUS 980
ZINC 1527
BARIUM 0
SUS Viscosity @ 210F 56.2
cSt Viscosity @ 100C 9.13
Flashpoint in F 360
Fuel % TR
Antifreeze % 0
Water % 0
Insolubles % .1
Try this jalapeno son... It ain't hot!
17 BMW 440iX
17 Ford 150 XLT Sport
07 STi DD. 375 AWD HP
08 STi track car. 467 AWD HP (6:1 P/WR)
818R FFR racer
#4451682 - 07/06/17 07:59 PM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: Scargo]
bigjl Offline
Loc: London, England
Tuned WRX's and STis tend to be run on thicker oil in the UK.
5w40 is now pretty much the usual oil, usually Shell Helix Full Synth.
Some specialists used to use even thicker oil, 5w50 if memory serves.
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
#4451687 - 07/06/17 08:07 PM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: Scargo]
dgunay Offline
Loc: Toronto
xw30 is too thin for the EJ25 engine, especially if it is driven hard. That would be the reason for high lead number.
You should use at least 40 weight in that car, even some Subie drivers in the middle east use 10w60.
I'd change it with Rotella T6 5w40 and take sample again, and see if lead gets lower.
By the way, what do you mean by "fat" A/F ratio? Do you mean is it rich or lean? If it is lean, detonation might be the reason for high lead number.
2009 Acura CSX (K20Z2 Auto)
PUP 5w30 / M1-110 / Maxlife ATF
Koni STR.T Struts / Tein S-Tech Springs / 20mm OEM RSB
Cooper Zeon RS3-A / Continental WinterContact SI
#4451709 - 07/06/17 08:30 PM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: Scargo]
PeterPolyol Offline
Loc: toronto
+1
Ditch the fuel-economy grade
#4451867 - 07/06/17 11:02 PM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: Scargo]
DdDd Offline
Loc: NY
Lotsa lead!!!
#4451877 - 07/06/17 11:14 PM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: Scargo]
Rand Offline
Loc: NE,Ohio
What are your oil temps? Pretty sure you need something thicker in there. 5w40 or 5w50 come to mind.
2017 Jeep Cherokee Trailhawk V6
#4452163 - 07/07/17 09:48 AM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: Scargo]
Trav Offline
Loc: MA, Mittelfranken.de
Subaru in Europe recommends this when racing even stock engines.
https://www.amazon.com/Castrol-Synthetic...trol+edge+10w60
#4452287 - 07/07/17 12:18 PM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: Scargo]
1JZ_E46 Offline
Loc: Oregon
Maybe XPR uses lead as an additive!? No idea. That's a lot though. I would certainly run something thicker. Somewhere in the 14-17 cSt range for KV100.
2007 BMW X5 4.8i, 105K: Castrol EDGE 0W-40, Mann
2012 Mini Cooper, 45K: Castrol EDGE 0W-30, Mann
#4452297 - 07/07/17 12:36 PM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: 1JZ_E46]
MolaKule Offline
Loc: Iowegia - USA
thumbsup
They are using TETRAETHYL LEAD, (C2H5)4Pb as the antiknock compound and of course to raise the octane level.
#4453475 - 07/08/17 02:17 PM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: Scargo]
subzerospeed Offline
Loc: Canada
ya lotsa lead. i would run ATLEAST a 40 weight in your ej, ESPECIALLY considering its use.
99' B4 RSK
Motul 5.40 & K&N HP-1004
BF SportComp 2
Escort IX
Only braking for Ka
#4455975 - 07/11/17 08:23 AM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: MolaKule]
Scargo Offline
Loc: S. CT, USA
thumbsup
Is there any way of quantifying how much could get into the oil? How it could affect the numbers? Blackstone wondered if it was the Torco. A quart per five gallons...
Also, I've run Royal Purple XPR before without the high lead numbers, but also with only 12 fluid ounces of Torco.
When I say "fat" I do mean rich. At boost I am at 11:1.
My oil temps are great. Often below 200 and never over 210. My engine has never run hot. I also have a big racing radiator.
I will add that I thought I could run a lower viscosity oil because of my unique oil system. I don't know how much you can compare it to stock and Subaru recommendations. I've done the obligatory radiusing, enlarging and matching of galleys that many race engine builders do. I am running a 12mm ported pump with deep back. This gives me lots of volume. I run an external, adjustable oil pressure relief valve. I started out with over 150 PSI! I dialed it down to 85 PSI. It seldom sees below 70 PSI on the track. It has dropped some and I have raised it back and I went with 10-40 RP when I took the tested oil out. Of course, I am concerned that I may have some bearing wear issues. The engine was dyno'd at 470 WHP and 391 FPT, but I have yet to race it at that max power level.
17 BMW 440iX
818R FFR racer
#4456075 - 07/11/17 10:25 AM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: Scargo]
1JZ_E46 Offline
Loc: Oregon
You're reasoning seems sound for running a thinner weight, especially given your low oil temps. Only another UOA will be able to tell you if you have a bearing issue. Maybe do a quick flush dino oil and then re-fill with your RP of choice (although I'd recommend Redline 30 or 40 weight racing), turn the boost down a bit, run without the octane booster, and re-analyze. If the lead is still high, you may have a bearing issue.
#4458114 - 07/13/17 10:44 AM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: 1JZ_E46]
Scargo Offline
Loc: S. CT, USA
I appreciate the comments. However, like i said, I have just put in 10-40 and will try that on my next track days which will give me three plus hours on the engine. I'll then have it analyzed and it will have the same run time on it as the first sample.
It's not so easy for me to change my boost settings and mess with other factors. The engine was dyno'd for three performance levels; all using the same Torco enhanced fuel or 105 octane (so I could use 105-110 racing fuel if I needed to). I cannot modify the maps. Yes, the 385 WHP setting could run on pump gas but it's not as much fun as 430... (and it was tuned on 105 octane). I could possibly reduce the Torco, but not eliminate it, for 430 if I keep a close eye on my EGT readings. I guess I don't see much point in doing anything different until I see how the more viscous oil does.
I am skeptical as to making an oil brand change when Royal Purple has served me well with two previous Subaru race engines. No bearing failures and no extreme wear. One bottom-end could have easily kept going had I not burned a valve from lash being too tight. I generally ran 10-40 in it when ambient temps warmed up.
I may well have bearing wear issues but I don't suspect the oil is at fault. Another Subaru racing buddy put an ungodly number of track hours on one engine using RP and he didn't have the enhancements I have had.
One thing I have learned, as I have built subsequent Subaru race engines, is that the cases and journals can move around and must be always be measured and machined in an "as run" assembled condition, meaning torque plates to simulate heads being in place, etc. Otherwise, you just luck out if it lasts in a high power, high RPM environment. I didn't do everything on this engine to the "Nth degree" when I set up the bearings. I hope it doesn't come back and bite me in the [censored].
17 BMW 440iX
818R FFR racer
#4459207 - 07/14/17 11:55 AM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: Scargo]
mightymousetech Offline
Loc: Ontario, Canada
Originally Posted By: Scargo
]My oil temps are great. Often below 200 and never over 210. My engine has never run hot. I also have a big racing radiator.
Hmm, maybe you are overcooling your oil? Tape off the oil cooler? Are you running a thermostat?
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4460395 - 07/15/17 07:14 PM Re: Subaru STi race engine, RP XPR 5W/30, 3hrs [Re: Scargo]
SubLGT Offline
Loc: Idaho
If bearings were going bad, would also expect to see high numbers for tin. Silver is high, from turbo bearing perhaps.
Consider contacting this company: http://www.dysonanalysis.com/about-us
Edited by SubLGT (07/15/17 07:20 PM)
Page 1 of 3 1 2 3 >
