I recently did a brake fluid flush and feel the pedal could be a little firmer.
I had previously heard about the Phoenix Systems reverse brake bleeder and was wondering if I could use my brake bleeding adapter cap together with my Mityvac to achieve something similar and pull any remaining air out of the system.
Here is a link where somebody used the reverse brake bleeder to get air out that apparently wasn't bleeding out after multiple regular brake bleeding attempts.
http://forums.pelicanparts.com/porsche-9...lts-beware.html
Thoughts? Seeing I've done the brake fluid change, can I achieve something simiilar just by pulling a vacuum?
