Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
Door Hinges
by Scrum67
06/23/18 11:59 AM
PBS, TV channels in different countries
by onetwoothreee
06/23/18 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
90 registered (2015_PSD, 928, 71Chevyguy, 1JZ_E46, 14Accent, 9 invisible), 1542 Guests and 45 Spiders online.
65303 Members
67 Forums
285863 Topics
#4451446 - 07/06/17 03:23 PM Sliding glass doors...
OneEyeJack Offline
Loc: S California
Is the upgraded glass and argon gas worth the expense?
#4451458 - 07/06/17 03:38 PM Re: Sliding glass doors... [Re: OneEyeJack]
knerml Offline
Loc: NE Ohio
Here, there is no choice.
If the door has direct exposure to the heat of the sun, then yes.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W20 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T GDI Castrol Edge 5W40 & OEM/Mann W811/80 Filter
#4451478 - 07/06/17 04:04 PM Re: Sliding glass doors... [Re: OneEyeJack]
Cujet Offline
Loc: Jupiter, Florida
Low E glass does reduce solar heating. It is quite pleasant to be behind Low E windows in bright sunlight.
However, sliding glass doors take a beating. So argon filled, double pane glass sliding doors run a higher risk of eventually losing it's seal and fogging up.
Edited by Cujet (07/06/17 04:05 PM)
#4451480 - 07/06/17 04:06 PM Re: Sliding glass doors... [Re: OneEyeJack]
Linctex Offline
Loc: Waco, TX
Check your codes - even if CA doesn't require it, your municipality might.
You may need a builder's/remodeler permit from the inspection department at your city. If you are in an evil, evil, evil, "HOA" (many Texas homes are) you need a permit from them as well before modifying ANY exterior parts of your home.
#4451483 - 07/06/17 04:08 PM Re: Sliding glass doors... [Re: OneEyeJack]
Cujet Offline
Another interesting option is to use a single pane version of hurricane resistant glass in sliding doors. It will never fog up. We do that here in Florida to avoid having to install hurricane panels. Due to it's thickness, it insulates fairly well, and it's tough as nails. Criminals can't break through it easily.
#4451512 - 07/06/17 04:35 PM Re: Sliding glass doors... [Re: Linctex]
Vuflanovsky Offline
Loc: California
A permit from an HOA?? I'm assuming you mean permission / OK / approval. If not, that sounds like something Barney Fife would be running.
#4451521 - 07/06/17 04:49 PM Re: Sliding glass doors... [Re: OneEyeJack]
irekm Offline
Loc: vancouver
Noise or heat that you worry about, Windows or doors?
Check if your frames would accommodate triple glazed sealed unit
#4451633 - 07/06/17 06:49 PM Re: Sliding glass doors... [Re: Vuflanovsky]
Linctex Offline
Loc: Waco, TX
Call it what you want.... it's still a lost freedom.
My ex-in-laws live in an HOA. (we're still friends)
EVERY SINGLE FEATURE of the home that's visible from the exterior (front, sides AND back) requires permission from them if there is ANY CHANGE (even replacing like with identical like)
A signed permission form must be received and present during work.
if that doesn't meet the definition of a "permit"... then what does?
Oh, and the dues are $135 a month! ($1,620 a year)... that's insane
#4452373 - 07/07/17 01:58 PM Re: Sliding glass doors... [Re: OneEyeJack]
OneEyeJack Offline
Loc: S California
I could not live is a home governed by an HOA. A friend at work left on an emergency basis to take care of his mother. I picked him up at the airport when he returned several weeks later and drove him home. He discovered that the timer on his lawn sprinklers failed to work. This was August in Southern California and his lawn evidently started turning brown. The HOA hired their landscaper to fix the sprinklers, green up the lawn and trim everything including removing several plants. They had an emergency phone number but never called. His lawn greened up like crazy but was dead a month later. He got the bill and a fine for all this and later fined again because he hired his own landscaper to redo everything but without written permission. His neighbors went out of their way to compliment him on his new landscaping. Problem, it was not approved and he was forced to tear it all out and start over with an approved plan. He got a plan approved and redid it all. The new landscaping pass muster but he was fined again because his landscaper was not on their approved list. His next move you ask? He put out a "for sale" sign and you guessed it. Fined again. He finally sold the place and moved out toward the sticks like the rest of us "normal"(lol) people.
#4452380 - 07/07/17 02:11 PM Re: Sliding glass doors... [Re: OneEyeJack]
SatinSilver Offline
Loc: OH
^Two sides to every story. Somewhere in the middle is the truth. Yes some places have rules about no for sale signs in the yard. Your friend should have read the bylaws/rules and obeyed them if he didn't want to be fined. The whole landscaping thing sounds like a soap opera.
#4452396 - 07/07/17 02:39 PM Re: Sliding glass doors... [Re: SatinSilver]
pandus13 Offline
Loc: Chicago,IL,USA
I was fined/in violation because one crack in a garage door window: it was visible only from 2-3 feet away....
Care to join the geriatric HOA committee? (I have all the respect for persons and old people that still keep active after retirement; not when spending their time to make others miserable).
You do know there have been reports of HOA boards inventing laws out of thin air even against existing laws, don't you?
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
#4452444 - 07/07/17 03:36 PM Re: Sliding glass doors... [Re: OneEyeJack]
dlundblad Offline
Loc: Indiana
I read this over lunch, but didn't have an opportunity to reply.
Since this is a car forum, lets compare it to cars.. I vote the more luxury an item has, the less reliable it is. It's safe to assume a base model car would have less things going wrong over it's life than it's fully loaded big brother.
x2 on sliding doors taking a beating. Her 'rents have one that is used as the main door.. ouch!
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
