F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
94 registered members (Ablebody, AnthonyF, ARCOgraphite, andyd, 2015_PSD, AndyB, 6 invisible), 1,446 guests, and 39 spiders.
Topics290,750
Posts4,849,606
Members66,034
Most Online3,590
Jan 24th, 2017
Poly motor mount.... good or bad idea? #4451281
07/06/17 01:00 PM
07/06/17 01:00 PM
Virginia
Hemispheres Offline OP
Virginia
I've managed to crack my stock liquid filled motor mount by repeatedly launching at 2.5k rpms and all around driving like an idiot.
I couldn't help it, I raced one person in my Buick and shortly thereafter I had random people pulling up next to me on the interstate/highways wanting to race. Balls to the wall or none at all. laugh
Anywho, A few months back I found a puddle of fluid under the car whilst dropping some metal off at the local scrapyard. Figured it was my power steering pump/hose. Going back about a month I noticed a clunk when shifting from P to R, and after hearing the clunk giving it gas results in a feeling of "shudder". Combine that with the fact that the car can't decide when it wants to shift under partial/half throttle and I have all the classic symptoms of a bad motor mount.
This is double the cost, but also geared towards performance and durability, I'm just wondering if the excess vibration would be worth it.
https://zzperformance.com/3800/poly-engine-mount.html
2009 Buick LaCrosse (3800 Series III) - 137,000 miles.
PZ Plat HM/Mobil 1 HM
Bosch/Purolator/Mobil filters
Re: Poly motor mount.... good or bad idea? [Re: Hemispheres] #4451282
07/06/17 01:01 PM
07/06/17 01:01 PM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
Cool. If you're "driving like an idiot" as you say, it won't be long before you break something else.
laugh
1994 BMW 530i, 228K
1996 Honda Accord, 263K
1999 Toyota Sienna, 400K
2000 Toyota ECHO, 271K
Re: Poly motor mount.... good or bad idea? [Re: Hemispheres] #4451289
07/06/17 01:05 PM
07/06/17 01:05 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I use some sort of restrainer for engine movement. On my FWD V8 Taurus it was a chain from the front exhaust manifold to the subframe. On my RWD Gen Coupe it is a piece of cable attached to the head and anchored at the drivers side strut tower.
Never had to change a motor mount.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Poly motor mount.... good or bad idea? [Re: Hemispheres] #4451300
07/06/17 01:15 PM
07/06/17 01:15 PM
Michigan
MrHorspwer Offline
MrHorspwer  Offline
Michigan
Yes, poly mounts (engine and trans) are a worthwhile upgrade in a W-body if you're making more power than stock or find yourself chewing up OE mounts.
Re: Poly motor mount.... good or bad idea? [Re: Hemispheres] #4451321
07/06/17 01:31 PM
07/06/17 01:31 PM
PA
MarcS Offline
MarcS  Offline
PA
I used to have a Regal GS that I sold before redoing the lower motor and trans mounts. I think i have a set of solid rubber ones for a GTP in my garage. I got those because they don't leak like the liquid filled mounts and don't make the engine vibrations as bad as poly. If you want them, shoot me a PM and I'll look for them. I'd also recommend flipping your upper motor mounts. free mod that reduces a lot of the movement.
Re: Poly motor mount.... good or bad idea? [Re: Hemispheres] #4451352
07/06/17 01:57 PM
07/06/17 01:57 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
I have a "soft" poly torque mount in the Focus. In my car there are two upper mounts on each side of the motor/trans and lower torque mount that keeps the engine from twisting. By just restricting the twist motion its pretty much stopped wheelhop, and under light throttle there is nearly zero extra NVH. If you DD your car you might want to try the torque mount first.
07 Focus ZXW, 5spd manual, 210km M1 5W30
18 Outback 2.5 CVT 10km 0W20 "bulk subaru" whatever that is
Re: Poly motor mount.... good or bad idea? [Re: MarcS] #4451375
07/06/17 02:17 PM
07/06/17 02:17 PM
Virginia
Virginia
I've already flipped the rubber bushings on the dogbone mounts, first thing I did before actually spending money on performance parts. If I decide to the solid route I'll shoot you a PM, I'm just liking the idea of little to no engine movement the poly's offer.
Re: Poly motor mount.... good or bad idea? [Re: Hemispheres] #4451380
07/06/17 02:20 PM
07/06/17 02:20 PM
snowblind in TX
punisher Offline
punisher  Offline
snowblind in TX
Is using a simple piece of chain between block and frame/subframe too ghetto now?
Re: Poly motor mount.... good or bad idea? [Re: punisher] #4451382
07/06/17 02:23 PM
07/06/17 02:23 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I had to use shiny imported 316 SS chain to keep the naysayers quiet.......
Re: Poly motor mount.... good or bad idea? [Re: Hemispheres] #4451384
07/06/17 02:25 PM
07/06/17 02:25 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I have both the engine and trans mount in ply in a GTP 3800, it also liked to tear engine mounts apart. They work well but they do vibrate noticeably but so does my engine with no balance shaft (double roller chain installed) so how much is just from the mounts I don't know.
Re: Poly motor mount.... good or bad idea? [Re: punisher] #4451387
07/06/17 02:29 PM
07/06/17 02:29 PM
Virginia
Virginia
It isn't a matter of ghetto to me, it's a matter of doing it right. I don't feel comfortable with a chain putting all that extra strain on my exhaust studs and I rather like the finish of my tubular exhaust manifolds.
Re: Poly motor mount.... good or bad idea? [Re: Hemispheres] #4451410
07/06/17 02:47 PM
07/06/17 02:47 PM
Colorado
AntsinmyEyes Offline
Colorado
Have poly motor mounts on my rx7. I notice aome minor vibrations at lower rpms but they go away as you go through the rpm range. Also i can do burnouts now without my car hopping around. Been pretty sweet id say
1987 mazda rx7
2004 mazda rx8
1995 miata
2005 dodge ram
Re: Poly motor mount.... good or bad idea? [Re: Hemispheres] #4451438
07/06/17 03:16 PM
07/06/17 03:16 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
Back in the day I used steel solid mounts on my 454 Chevy vette and no chains needed. Yes it transmitted its beastly musical vibrations to the frame but that was part of the fun. I would not hesitaTE ON THE pOLYS
Re: Poly motor mount.... good or bad idea? [Re: Hemispheres] #4451454
07/06/17 03:35 PM
07/06/17 03:35 PM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
I like this. Never heard this before.
I'm going to use this if you don't mind
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Re: Poly motor mount.... good or bad idea? [Re: Lolvoguy] #4451574
07/06/17 05:52 PM
07/06/17 05:52 PM
Michigan
jkasch Offline
jkasch  Offline
Michigan
If you're not being facetious (maybe it isn't common in Canada), it's an aviator term for having all the ball-topped controls all the way forward for maximum speed. For years, I thought it referred to male anatomy. duh Doesn't make much sense in that regard.
