Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knockers
by user52165. 09/21/18 03:41 PM
Opinion needed....
by Duffyjr. 09/21/18 02:56 PM
2017 nissan sentra
by jahwarrior1423. 09/21/18 02:47 PM
I Need A Safe Space- lol
by Zee09. 09/21/18 02:29 PM
Liqui Moly
by dawgn86. 09/21/18 02:10 PM
Valve issues
by kawie_guy. 09/21/18 01:54 PM
2018 Elantra SE
by wolf_06. 09/21/18 01:36 PM
Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
Pizza dough too crusty
by zorobabel. 09/21/18 11:26 AM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
100 registered members (A310, ABomb369, 928, 53' Stude, Ablebody, 10 invisible), 1,672 guests, and 38 spiders.
Topics290,785
Posts4,850,249
Members66,036
Most Online3,590
Jan 24th, 2017
Thoughts on which oil to use? Turbo Inline5 Gas #4451233
07/06/17 12:06 PM
07/06/17 12:06 PM
BC, Canada
amargill19 Offline OP
BC, Canada
Hello, long time forum creeper here, first time posting. Sorry for the lengthy post here.
I recently bought a new (to me) 1998 Volvo S70 T5 (high pressure 2.3L inline5 cyl turbo) in January with 129,000km (80,000 miles). Seemed to be pretty neglected in terms of maintenance. When I brought it home I discovered the oil was last changed 2 years ago with dino, but only driven about 2000km, having a stockpile of Castrol GTX 10w30, and Castrol GTX HM 10w30 at home I changed the oil immediately. Car needed a lot of work - clogged PCV/flametrap system, timing belt never done, leaking oil cooler lines, and much more.. these were all dealt with within the first week of my ownership. 2500km after the PCV systems was replaced I blew a rear cam seal (caught it immediately and fixed it day of).
So, now she doesn't leak any oil (consumes a bit like all of these older T5 engines, and also has an oily smell after I run it and shut it off like most turbo cars), I'm now at 143,000km (89k miles) having changed the oil every 2500-3000km (less than2k miles) with hopes to clear up a lot of the sludgy and varnish buildup. Oil comes out dark and dirty even at these short OCIs. I always use a quality Mann filter each change. I also usually dump about 300ml of fresh oil with the drain plug/filter removed until it drips out clean. I know there's lots of AutoRX hype and other flush type products to help clean the engine, but I've never liked the idea of additives.
After using all but the last jug of regular GTX I'm now on my second change with the HM GTX. Oil capacity is about 6.1 quarts, I fill exactly 5.7 - 5.8 Liters - so I've been adding the .7 or .8L with the last jug of regular GTX to the 5 liters of HM GTX. My goal is to continue with the quick interval changes until I "feel" confident enough to switch to a good quality synthetic oil.
So, I have 1 more jug of high mileage GTX.. should I jump to synthetic or run more high mileage oil until the engine is cleaner? I recently bought 6 liters of of Castrol Edge Syntec 10w30 with titanium. I've always had good results with Castrol in the past with similar engines, but am I no means a die hard castrol fan.
Mobile1 HM? Do they offer this in Canada in a 10w40, or 0w40?
Penzoil Platinum Ultra for it's cleaning abilities?
a 0w40 synthetic?
thoughts on a blend? Seems easy to do given the odd oil capacity.
any other thoughts or suggestions would be appreciated
- I live in a mild climate area (Vancouver, British Columbia), seldom gets below 14 degrees F, or warmer than 86 F.
- Half of the time I drive like I stole it, half of the time I'm in [censored] traffic.
- I drive about 50-70 miles per day
much appreciated
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: amargill19] #4451242
07/06/17 12:12 PM
07/06/17 12:12 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
pennzoil euro 0w40
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: amargill19] #4451249
07/06/17 12:22 PM
07/06/17 12:22 PM
Virginia Beach
Astro14 Online content
Astro14  Online Content
Virginia Beach
Did you replace everything in the flame trap circuit?
If so, then any decent euro spec oil will do. Depends what you can get in BC at a reasonable price. I have used Mobil 1 0W40, Castrol 0W40, Pennzoil Euro 5W30, and 0W40 in my Volvo White Block engines that are basically the same as yours.
UOA shows them working well. But in my wife's mix of driving, even the Euro spec oils were down to 1.5 TBN after 7,500 miles, so I wouldn't press this engine, and the oil you select, into long drain intervals.
It won't hurt to run synthetic, and if you keep the interval down, I don't think conventional hurts either.
I think you'll help the engine live a lot longer if you run it easy for the last mile. Let the turbo cool.
Both the Volvos in my signature are driven by "non-car" people, and both have the original turbos. The T5 has over 190K and the XC about 223K. Good oil, factory OCI, let the turbo cool down on each drive. That's what I recommend...
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: amargill19] #4451251
07/06/17 12:25 PM
07/06/17 12:25 PM
Austin, Texas
Brons2 Offline
Brons2  Offline
Austin, Texas
You say you replaced a cam seal, if so you've have the valve cover off to do it. How clean did it look? If it was pretty clean you've probably run enough short OCI cleans. M1 HM 10w30 is A3 rated, if you ever go to the US you can buy a few jugs at wallymart in Bellingham, it's 18 miles from the border.
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: Astro14] #4451275
07/06/17 12:51 PM
07/06/17 12:51 PM
BC, Canada
BC, Canada
Thanks for the replies..
Brons2 - to replace the rear cam seals you don't have to remove the cam cover, so I have no idea what it looks like under there aside from the varnish I see under the oil cap.
Astro14 - yes all of the tubing/breather box, etc was replaced. There was lots of nasty sludgy oil in the old parts, and when I had the turbo intake/PTC pipe off for cam seal replacement there was lots of sludgy build up in there. That part will be replaced with a Snabb intake pipe and I'm thinking of setting up a catch can so the oil vapours from the breather box don't get routed back to the intake. I ALWAYS drive easy the last couple miles and have it idle until the EFAN kicks off. Car is never in boost until the water and oil temp is at normal operating temp.
The original manual suggested 5w30 or 10w30 - do you think there might be an issue running 0w40? I almost feel nervous going to that kind of oil. Beneficial to run 10w30 synth before switching to 0w40 synth and carefully observe oil consumption? Oil goes down about half quart or so after 3000km on the dino oil.
Also, I freaked out just before my last oil change which was the first time using the High Mileage GTX. The engine oil was getting dirty and had a slight red colour to it, not like I've seen before with the regular GTX. I panicked thinking the radiator internal trans cooler and oil cooler mixed as both fluids looked similar. I don't think that's possible though without coolant getting in the mix. Both engine oil and ATF was just dirty and so I gave the trans a 14 litre ATF flush with the OEM Volvo Dex3 (4 speed trans, not the problematic 5 spd). No visibile red colour with the engine oil right now but I'm only 1100km into it.
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: amargill19] #4451310
07/06/17 01:21 PM
07/06/17 01:21 PM
BC, Canada
BC, Canada
I totally posted this in the wrong forum section blush
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: amargill19] #4451329
07/06/17 01:42 PM
07/06/17 01:42 PM
Pennsylvania
bugeye Offline
bugeye  Offline
Pennsylvania
In our 2004 XC70, 5 cylinder turbo, purchased at 91,000 miles, I have used Mobil 1, Pennzoil Platinum and Quaker State Ultimate Durability (all called synthetic in US). 5w-30, 5w-40 and 0w-40. Purchased oil on sale and rebate. Grate at oil fill was initially coated with black deposits. Changed oil and filter at 3500 to 4500 miles. Took about 20,000 miles to clean the grate to shiny like new. I now change the oil at ~ 5000 miles with synthetic. No use of additives.
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: amargill19] #4451730
07/06/17 08:51 PM
07/06/17 08:51 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
That's OK, a lot of gas guys use diesel engine oils to help clean stuff. I add a full can of BG109 at each change and run them out to 4,000 miles now, even if they are looking dark, to help clean stuff on internally dirty engines. BG109 is pretty benign, but does get the job done over time.
If it were me, I'd prolly do that (run the BG109) and I'd run Rotella T6 5W-40 for 3,000 mile changes until you think it has gotten clean enough ... I'd also run an oversized filter if you can make one fit smile
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: amargill19] #4451956
07/07/17 03:10 AM
07/07/17 03:10 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
My 850 T5 leaks 5W-30 out the rear main. I run almost anything in it, and will probably go for 10W-50 next change. I only do about 5,000km a year, so it gets yearly oil changes.
1987 BMW R65 - Penrite V Twin 20/50
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: Silk] #4452270
07/07/17 11:53 AM
07/07/17 11:53 AM
BC, Canada
BC, Canada
How many kilometers on your T5? rear main seals will go on these cars with the PCV/flametrap system neglect and extended OCIs.
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: amargill19] #4452753
07/07/17 08:53 PM
07/07/17 08:53 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
It's done 214,000km, and is an end of life $500 car, in my hands they get a few more years before getting dumped. I've gone with the 5/8 heater hose in the PCV, because it was there and I had nothing better at the time...maybe I'll use something better, maybe not, but whatever I use won't cost me anything. I've run a couple of HDEO's through it, a 15W-40 and a 5W-40, it now has a mix of what was in my shed, next time it will be Penrite HPR10, but that's next year, so who knows what I'll settle on.
The rear main is not an easy job, I work on a hoist all day, so being able to do the job is not the issue, it's just that I'm not going to go that far. It gets dumped if the rear main gets worse. It putters around town doing 20km on the weekends, and every month or so a trip to a city, sometimes more often, sometimes less. I've sunk 3 times the purchase price into it now, but it's still a lot of car for the money. Power, handling, load space...ticks all the boxes for me.
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: amargill19] #4453935
07/09/17 12:11 AM
07/09/17 12:11 AM
BC, Canada
BC, Canada
Nice, yeah they can be pretty nice bang for the buck vehicles. I took my first car, a 240, to over 400,000 with the original engine/trans with the head never off.
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: amargill19] #4453946
07/09/17 01:00 AM
07/09/17 01:00 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
On my walk around the lake this morning, a woman walking a couple of husky's asked if I was the owner of the red Volvo. I told her I was, and she said ''her husband just loves that car.'' They have a late model V60 or something, but he really likes the 850 and V70. So looks like they still have a bit of a following. I used to look after a couple of Volvo body transfer vehicles, so knew they had a good load space.
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: amargill19] #4456375
07/11/17 02:52 PM
07/11/17 02:52 PM
BC, Canada
BC, Canada
Thanks for the input,
I've decided to visit Walmart America and pick up a bunch of 5w30 highmileage Castrol Syntec, Mobile1 highmileage 5w30, or Penzoil Ultra high mileage 5w30 - whatever's on sale (I can't seem to find high mileage synthetics here). I think this vehicle may benefit from the high mileage additives, from there I'll give the 0w40 a try for a few changes if all goes well.
Still have a couple of oil changes worth of 10w30 for the summer, but I basically change oil almost every month with the dino stuff.
Re: Thoughts on which oil to use? Turbo Inline5 Gas [Re: amargill19] #4456406
07/11/17 03:27 PM
07/11/17 03:27 PM
NC
Vladiator Offline
Vladiator  Offline
NC
The red tint in oil had nothing to do with ATF. It is a benefit to have fresh fluid in the tranny though. The red tint in the oil is the chemical reaction to sludge and varnish inside the engine. No biggie there. Keep doing what you are doing. With HM synthetics you could go 5000 kms between oil changes, until oil that drains out starts to have a gold tint to it, instead of the red ATF-like tint. After that point 7000-8000 kms would be the perfect OCI length. Just my two cents...
2000 Lexus GS300-361k
1999 Lexus GS400-213k
2006 Toyota Camry-187k
2006 Toyota Highlander Hybrid-125k
2009 Scion xB-120k
2013 VW Tiguan-120k
2009 Toyota Tacoma-60k
