Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
41 registered members (Ablebody, Bjornviken, andyd, 7 invisible), 931 guests, and 36 spiders.
Topics290,743
Posts4,849,431
Members66,033
Most Online3,590
Jan 24th, 2017
Pull a vacuum on brake fluid? #4451226
07/06/17 11:56 AM
07/06/17 11:56 AM
CA
CharlieBauer Offline OP
CA
I recently did a brake fluid flush and feel the pedal could be a little firmer.
I had previously heard about the Phoenix Systems reverse brake bleeder and was wondering if I could use my brake bleeding adapter cap together with my Mityvac to achieve something similar and pull any remaining air out of the system.
Here is a link where somebody used the reverse brake bleeder to get air out that apparently wasn't bleeding out after multiple regular brake bleeding attempts.
http://forums.pelicanparts.com/porsche-9...lts-beware.html
Thoughts? Seeing I've done the brake fluid change, can I achieve something simiilar just by pulling a vacuum?
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Pull a vacuum on brake fluid? [Re: CharlieBauer] #4451297
07/06/17 01:11 PM
07/06/17 01:11 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I have a small hand held vacuum brake bleeder. You have to first back the bleeders out and put some liquid sealant on the threads or they suck air in past the threads. I've found speed bleeders to do the same.
Also I usually start the engine so I have vacuum assist on the brakes when doing the rear as they are usually somehow restricted compared to the front.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Pull a vacuum on brake fluid? [Re: CharlieBauer] #4451312
07/06/17 01:23 PM
07/06/17 01:23 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
My method is to put the vacuum bleeder on the caliper, then slowly pump the brakes 10 times. I then remove the vacuum bleeder and let it gravity bleed for a couple seconds to let out any air that made it past the threads of the bleeder. Always results in a nice firm brake pedal.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Pull a vacuum on brake fluid? [Re: CharlieBauer] #4451484
07/06/17 04:08 PM
07/06/17 04:08 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
Theoretically, vacuum bleeding is a superior way to draw air out of the lines. Any air grows in volume and is more easily swept away by the process.
In practice, air is drawn past the bleeder screw threads and mucks up the procedure.
Re: Pull a vacuum on brake fluid? [Re: CharlieBauer] #4451497
07/06/17 04:18 PM
07/06/17 04:18 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
If you disassemble the master cylinder, you would see that too much vacuum will pull air past the lip on the piston seal - so don't go crazy on it.
Re: Pull a vacuum on brake fluid? [Re: Linctex] #4451523
07/06/17 04:50 PM
07/06/17 04:50 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
I'm not surprised by this observation. That is why I push the pedal by hand with an airlock at the bleeder. I seal the bleeder threads with some grease. Some time in the process I do a gravity bleed as well. My pedal feels great and I'm smug as all get out because I haven't spent a cent on a tool I don't need. grin2
Thick oil is better grin2
Re: Pull a vacuum on brake fluid? [Re: CharlieBauer] #4452140
07/07/17 09:27 AM
07/07/17 09:27 AM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I've wondered about pulling a vacuum in the fluid reservoir to pull out bubbles, but I'd be afraid to suck extra air in from the bleeders.
I don't know how well it would work on a car, but I've seen motocyclists use a large syringe to inject the brake fluid from the bleeder up to the reservoir, appears to be the same idea as the Phoenix system.
I might have to try something like this next time I do a brake flush, I feel my Element's brakes aren't quite as firm as I think they should be.
Re: Pull a vacuum on brake fluid? [Re: EdwardC] #4452158
07/07/17 09:44 AM
07/07/17 09:44 AM
Taiwan
Ducked Online content
Ducked  Online Content
Taiwan
Works very well on my car, though I've been told somewhere on here that it's wicked and wrong and flying in the face of established good practice.
I think the concerns are that you might squirt some dirt into the master cylinder, or that you might evert seals in the master cylinder. I remove a bit of fluid from the caliper/brake cylinder first to minimise the first issue.
Re: Pull a vacuum on brake fluid? [Re: CharlieBauer] #4453470
07/08/17 02:14 PM
07/08/17 02:14 PM
NH
supton Offline
supton  Offline
NH
I figure, I kinda need the vacuum pump, so as to empty the MC when changing brake fluid. I could steal the turkey baster but the wife gets mad when I return it, no matter how well I clean it. Thus I just live with air bubbles when pulling fluid through the bleeders. In practice it doesn't seem to do anything bad.
I've replaced a few calipers and used the pump, and it seems to work fine for getting the system working. I know gravity would work too but the pump is faster.
2011 Toyota Camry, base, 2.5L/6MT, 163k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 144k, ours
1999 Toyota Camry LE, 2.2L/4AT, 190k, his
Re: Pull a vacuum on brake fluid? [Re: mightymousetech] #4453534
07/08/17 03:15 PM
07/08/17 03:15 PM
Ontario Canada
Canadastang Offline
Canadastang  Offline
Ontario Canada
+1 I always vacuum and then finish off with gravity. Makes for a very nice firm pedal every single time.
Re: Pull a vacuum on brake fluid? [Re: CharlieBauer] #4453567
07/08/17 04:07 PM
07/08/17 04:07 PM
USA
slacktide_bitog Offline
USA
speed bleeders are awesome smile
Re: Pull a vacuum on brake fluid? [Re: supton] #4453727
07/08/17 07:33 PM
07/08/17 07:33 PM
Taiwan
Taiwan
Syringe does that too.
