WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
19 registered members (BISCUT, chance, Blkstanger, AnthemBassMan, Atesz792, 928, 1 invisible), 687 guests, and 34 spiders.
Topics290,810
Posts4,850,747
Members66,036
Most Online3,590
Jan 24th, 2017
Motion Lights #4451195
07/06/17 11:22 AM
07/06/17 11:22 AM
pennsylvania
GGorman04 Offline OP
pennsylvania
I was going to post in the electronics section but was not sure. I have two sets of spot lights outside. We would like to convert to motion. The two items needed are a motion sensing socket and a dawn to dusk light control.
The one I looked at over at Home Depot has horrible reviews.
Does anyone have any experience with this item?
Thanks in advance
Re: Motion Lights [Re: GGorman04] #4451207
07/06/17 11:36 AM
07/06/17 11:36 AM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I've used one of those, not sure if it's the same one at Home Depot, but it worked for a little while, then just stopped after a couple months. Not sure why.
I ended up replacing the entire fixture with an LED model. Obviously, that cost way more, but it had additional features I liked. One feature I really liked was that it has a low brightness level that was always on at night, then as it senses motion, it goes to full brightness. It used much less power as well, at least compared to incandescent.
Sorry, probably didn't help too much!
Re: Motion Lights [Re: GGorman04] #4451212
07/06/17 11:41 AM
07/06/17 11:41 AM
pennsylvania
pennsylvania
If I had access to the unit it would be easy to switch. It is about 18 feet above ground.
My guess is that most of the pieced together units are not as effective.
Re: Motion Lights [Re: GGorman04] #4451217
07/06/17 11:48 AM
07/06/17 11:48 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
I have 3 Heath from Home Depot.
They are cheap. The motion detector is also a dusk/dawn sensor so you don't need the socket, too. The deer in my backyard set it off often. Sometimes it goes off by itself and sometimes it gets "stuck" on until the next morning when the sun comes up and the light sensor turns the lights off.
Looks like this: https://www.amazon.com/Heath-Zenith-HZ-5411-WH-Motion-Security/dp/B00002N7FP/ref=sr_1_1?s=lamps-light&ie=UTF8&qid=1499359599&sr=1-1&refinements=p_4%3AHeath%2FZenith
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
Re: Motion Lights [Re: GGorman04] #4451228
07/06/17 11:56 AM
07/06/17 11:56 AM
New England
Peter_480 Offline
Peter_480  Offline
New England
As a professional electrician, I can only recommend products that I know will last, and for me, that's RAB. They make a quality motion sensor with a great warranty. Look on ebay or amazon for the Stealth model. It's expensive but well worth the price of admission.
That being said, I've had great success with the Heath Zenith ones. In fact, I have one I put up on my garage that's still working fine after 18 years. But they are not a pro-grade product and I won't install them as a professional unless customer supplied, or someone is on a real budget.
'10 Ford E250 4.6L
'11 Ford Fusion 2.5L
Re: Motion Lights [Re: GGorman04] #4451232
07/06/17 12:03 PM
07/06/17 12:03 PM
pennsylvania
pennsylvania
Will do.
Thanks
Re: Motion Lights [Re: GGorman04] #4451264
07/06/17 12:41 PM
07/06/17 12:41 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
With LED bulbs maybe just use a timer.
I have several outdoor lights controlled by a Samsung Smart Things hub. It turns them on sunset to 11:00 pm. It knows when sunset is each day.
2015 Ford F250 w/Powerstroke
Re: Motion Lights [Re: GGorman04] #4451397
07/06/17 02:37 PM
07/06/17 02:37 PM
One Step Beyond
larryinnewyork Offline
One Step Beyond
I have no advise for Motion Detectors,
but these are GREAT.
https://www.amazon.com/Intermatic-ST01-Programmable-Appliances-Astronomic/dp/B005H3AXKM
I have one along the walkway to my front entrance door.
It comes ON at sunset (automatically adjusts each day) and
goes OUT at 11:00 PM
It seems the LED bulbs used today DO NOT attract insects like the Incadesents did years ago.
Re: Motion Lights [Re: larryinnewyork] #4451428
07/06/17 03:04 PM
07/06/17 03:04 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
This is the same oune I bough for my fron house lights over 2 years ago and still working. You put in your location and it can roughly adjust for sunrise/sunset add LED bulbs and save some real dough.
Re: Motion Lights [Re: GGorman04] #4451432
07/06/17 03:07 PM
07/06/17 03:07 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
Costco sells LED floodlights with integrated motion and light sensing for ~$40. Makes massive light and works well.
Re: Motion Lights [Re: Kawiguy454] #4451513
07/06/17 04:37 PM
07/06/17 04:37 PM
Lakeside, CA
Blkstanger Online content
Blkstanger  Online Content
Lakeside, CA
I have one of these though mine is solar powered. It works great though. Lights up my whole driveway and most of my yard.
99 Jeep WJ 4.7 190,000 Maxlife 10w30, Fram Ultra.
