New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
30 registered members (BlakeB, Ablebody, Bjornviken, BusyLittleShop, 4 invisible), 890 guests, and 41 spiders.
Topics290,744
Posts4,849,439
Members66,033
Most Online3,590
Jan 24th, 2017
Can gravity-fed HVLP sprayer spay latex paint? #4451186
07/06/17 11:10 AM
07/06/17 11:10 AM
USA
DrRoughneck Offline OP
USA
Do I need to dilute latex paint to spray it from a gravity-fed sprayer like this one: https://www.harborfreight.com/20-oz-high-volume-low-pressure-gravity-feed-spray-gun-47016.html
If dilution is needed, what solvent is best? Does it affect the latex paint's strength?
Re: Can gravity-fed HVLP sprayer spay latex paint? [Re: DrRoughneck] #4451209
07/06/17 11:38 AM
07/06/17 11:38 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Odds are you'll have to thin the product, it depends on the paint brand and the finish. Latex flat will have to be thinned more than a semi gloss in most brands. You can thin with water or Floetrol. In most cases if you don't over thin the product the paint film is not impacted much. If you cut it too much you'll have problems. If you're working with whites Floetrol can alter the color [slightly], especially if it is exposed to a lot of UV rays.
God Bless Our Troops
Re: Can gravity-fed HVLP sprayer spay latex paint? [Re: DrRoughneck] #4451211
07/06/17 11:41 AM
07/06/17 11:41 AM
wi
dave123 Offline
dave123  Offline
wi
What tip size you got that's the first question
Re: Can gravity-fed HVLP sprayer spay latex paint? [Re: DrRoughneck] #4451229
07/06/17 11:58 AM
07/06/17 11:58 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
It can but you need a minimum of a 1.8 tip preferably a 2.0-2.5. Look for a cheap primer gun they have larger size tips. A cheap one like this will work fine.
http://www.ebay.com/itm/New-2-0-HVLP-Gra...e-/382144973796
Re: Can gravity-fed HVLP sprayer spay latex paint? [Re: DrRoughneck] #4451346
07/06/17 01:51 PM
07/06/17 01:51 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
looks like you will probably have to thin most latex even with a 2.0 tip.
Is it a larger project?
something like
https://www.harborfreight.com/airless-paint-sprayer-kit-60600.html
might work better.. although the cleanup time on those is a total killjoy.
Re: Can gravity-fed HVLP sprayer spay latex paint? [Re: DrRoughneck] #4451398
07/06/17 02:38 PM
07/06/17 02:38 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I've used a cheap chinese suction gun (non gravity) with latex (thinned with water).
The key was tons of air flow - it can't go on "super-wet".
It needs to dry a little bit between the gun and the work.
Re: Can gravity-fed HVLP sprayer spay latex paint? [Re: Rand] #4451624
07/06/17 06:38 PM
07/06/17 06:38 PM
Trav Offline
Trav  Offline
something like
Lots of cheap 2.5 tip primer lumps here. 2.5 will positively do latex it can spray liquid type body fillers.
https://www.ebay.com/sch/?_nkw=2.5%20primer%20gun
