Re-using building materials esp nails
by andyd
06/18/18 08:57 AM
Central A/C [censored] out
by TOMJ
06/18/18 08:43 AM
08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
93 registered (4WD, Artem, Astro14, Backwoods41695, badtlc, AndyB, 7 invisible), 1525 Guests and 35 Spiders online.
65262 Members
67 Forums
285515 Topics
#4450970 - 07/06/17 05:02 AM Directions for using Vinylex and can use on tires?
MoneyJohn Offline
Loc: Southern NY
Hello folks,
Someone recommended me Vinylex spray by Lexol a couple of years ago, bought it but never used it. I found it in my hoarding room yesterday and planning to use it now.
My question is, should you clean the surface with a damp towel or something before application or it can clean as well as protect? The directions are not very clear (to me). It does mention, apply in a circular motion for maximum cleaning and protection.
And, if one can apply on tires too. My less-than-2-years old tires (< 10,000 miles) are turning brown on the sides, not too sure if its result of the tire shine that they apply at a carwash place, but want to get rid of it, if possible. Don't mind getting tire dressing specifically but if I can use Vinylex that would be awesome.
Thanks in advance.
2015 Subaru Forester 2.5i Premium w/ EyeSight
2006 Nissan Sentra 1.8S Special Edition
#4451061 - 07/06/17 08:11 AM Re: Directions for using Vinylex and can use on tires? [Re: MoneyJohn]
sasilverbullet Offline
Loc: San Antonio, Texas
I've been using Lexol Vinylex since 2005. Great product, doesn't build up or yellow and actually protects against UV.
Just wash tire with your normal car wash soap of choice. I apply it using a "bug sponge". The vinylex will clean the tire and remove any residue. Just wipe it on and leave it. Looks good for a week.
You can also use it on any black trim.
14 Honda Civic 4dr EX-L-M1 0W-20 & WIX XP
14 Honda Accord 4dr EX-L 4cyl-M1 0W-20 & WIX XP
02 Chevy 5.7L van-GTX HM 10W-40 & WIX filter
#4451101 - 07/06/17 08:57 AM Re: Directions for using Vinylex and can use on tires? [Re: sasilverbullet]
MoneyJohn Offline
Loc: Southern NY
Thank you @sasilverbullet.
How about the interior? Wipe down with a wet towel? My main goal is interior. Its rather dusty, not dirty.
#4451125 - 07/06/17 09:30 AM Re: Directions for using Vinylex and can use on tires? [Re: MoneyJohn]
You can use Vinylex on most interior surfaces. First just try wiping it down with a damp towel. If that doesn't clean it enough you can use a light application of Vinylex. Put it on, let it sit for about 10 mins then wipe it with a clean, dry towel. You don't want to use to much on the interior because as the sun bakes it, you will see a little "fogging" on the inside of the windshield.
Personally I don't use Vinlyex any more on the interior of my cars. The sun is too intense here in south Texas.
A very light coat and you should be okay.
#4451294 - 07/06/17 01:08 PM Re: Directions for using Vinylex and can use on tires? [Re: MoneyJohn]
sleddriver Offline
Loc: Central Texas
That brown is due to the UV barrier in the rubber mix I've heard. Interesting that.
Vinylex is a fine product, smells a lot better than it used to. I cut a piece of foam block an inch or two thick off of a larger surplus piece and use it. When it wears out, I toss and cut another.
1998 Volvo V70 T5 226,808 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
