PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
127 registered members (01rangerxl, 2015_PSD, 2K2AcuraTL, 14 invisible), 2,015 guests, and 61 spiders.
Topics286,162
Posts4,903,342
Members67,569
Most Online2,967
Mar 10th, 2019
ZF 4HP24 Transmission Fluid Audi/Land Rover #4450424
07/05/17 01:25 PM
07/05/17 01:25 PM
NL, Canada
A3D2 Offline OP
A3D2  Offline OP
NL, Canada
I have quantity of Genuine Volkswagen G 052 162 A2 Automatic Transmission Fluid. I would like to use it in my 2000 Land Rover Discovery. The ATF I just mentioned is suitable for use in 1992-1994 Audi V8 Quattros, which have a ZF 4HP24A automatic transmission. My Discovery has a ZF 4HP24. I think the "A" simply distinguishes it as an Audi version of the same transmission.
My Discovery calls for Dexron III and I have been using Mobil 1 full synthetic for the past number of years. I would really like to be able to use the VW stuff but I'm scared! I wonder what it is/who makes it?
2000 Landrover Discovery Series II (Rotella T6 5W-40)
2010 Audi A3 Quattro 2.0 TSFI (Castrol Edge SPT 5W-40)
Re: ZF 4HP24 Transmission Fluid Audi/Land Rover [Re: A3D2] #4450433
07/05/17 01:31 PM
07/05/17 01:31 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
The VW stuff will most likely be fine.
HOWEVER, Dex III is too cheap to mess around with other stuff. Post the VW stuff for sale and use Dex III.
"Zed's dead baby, Zed's dead."
Re: ZF 4HP24 Transmission Fluid Audi/Land Rover [Re: rooflessVW] #4450454
07/05/17 02:02 PM
07/05/17 02:02 PM
NL, Canada
A3D2 Offline OP
A3D2  Offline OP
NL, Canada
I'm hoping that the G 052 162 A2 Automatic Transmission Fluid is really Pentosin ATF 1. I'd like to know more about it (the Genuine VW Product). I agree with you about the Dex III being cheap, but I'd really, really like to use the VW stuff if I can. I need more info.
Re: ZF 4HP24 Transmission Fluid Audi/Land Rover [Re: A3D2] #4450487
07/05/17 02:38 PM
07/05/17 02:38 PM
San Francisco, CA
Flying_A Offline
Flying_A  Offline
San Francisco, CA
I too used the M1 ATF as well as a more standard DexIII in my 2003 Disco...
The VAG group sources a lot of Pentosin for the in-service OEM fluids sold over the parts counter, so it is quite possible it is a Pentosin product. I'd imagine you can source the ZF branded Lifeguard 5 fluid (I wouldn't be surprised if it is the same oil that is in the OEM bottle) that would be suitable for your application as well but like the OEM product, it will be pricey.
There are also a ton of aftermarket brands out there that cover that OEM part # as well- it will even be listed on their technical data sheets. As you mentioned, the Pentosin ATF 1 being one of them. Like the OP said, I would use a better value aftermarket alternative and be done with it. A Dex III specific product included.
2008 Maserati Gran Turismo: Motul 300V Trophy 0W40
2017 Audi A3 etron: Motul X-clean FE 5W30/300V Sprint 0W15
Re: ZF 4HP24 Transmission Fluid Audi/Land Rover [Re: Flying_A] #4450502
07/05/17 02:53 PM
07/05/17 02:53 PM
NL, Canada
A3D2 Offline OP
A3D2  Offline OP
NL, Canada
Tech support at ZF sent me this document and said that the 4HP22/24 use the same fluid regardless of the vehicle manufacturer.
https://www.zf.com/global/media/en_zf/lubricantslists/TE-ML_11.pdf
So I guess I shuld be safe to use the VW stuff.
I wonder what is the difference between group 11A and B in the document? Who makes the VW Stuff?
Re: ZF 4HP24 Transmission Fluid Audi/Land Rover [Re: A3D2] #4450519
07/05/17 03:09 PM
07/05/17 03:09 PM
San Francisco, CA
Flying_A Offline
Flying_A  Offline
San Francisco, CA
[url=https://www.zf.com/globa [img:gal:44486595d46d58cd19]https://bobistheoilguy.com/forums/attachments/usergals/2017/07/full-44486-9567-capture.png
I think you're overthinking this... ZF themselves said IN WRITING a Dex III is ok for use:
And also listing these alternatives:
ZF also stated the VW stuff was fine since it falls under the ZF-11 category along with the aftermarket alternatives.
Re: ZF 4HP24 Transmission Fluid Audi/Land Rover [Re: Flying_A] #4450535
07/05/17 03:22 PM
07/05/17 03:22 PM
NL, Canada
A3D2 Offline OP
A3D2  Offline OP
NL, Canada
I know I'm overthinking it!
Re: ZF 4HP24 Transmission Fluid Audi/Land Rover [Re: A3D2] #4451529
07/06/17 05:01 PM
07/06/17 05:01 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
You certainly are the 4hp22 is a very stout transmission. It thrives on dino dex-merc. Pamper yours with anything. Mostly you want to keep it full. grin2
Thick oil is better grin2
Re: ZF 4HP24 Transmission Fluid Audi/Land Rover [Re: A3D2] #4451593
07/06/17 06:11 PM
07/06/17 06:11 PM
USA
slacktide_bitog Offline
USA
Maxlife ATF smile
Re: ZF 4HP24 Transmission Fluid Audi/Land Rover [Re: A3D2] #4452094
07/07/17 08:11 AM
07/07/17 08:11 AM
Canada
seanf Offline
seanf  Offline
Canada
the G052162a2 is the same fluid my 5hp19 takes in my Audi. Reading into it it looks like its really just a syn based dex3 based fluid which would be more than adequate in your Land Rover.
Re: ZF 4HP24 Transmission Fluid Audi/Land Rover [Re: seanf] #4455376
07/10/17 03:07 PM
07/10/17 03:07 PM
NL, Canada
A3D2 Offline OP
A3D2  Offline OP
NL, Canada
I've been using Mobil 1 for about 4 years now and like the idea of using a synthetic product. When I made the initial switch to M1 I swear the thing started to shift more smoothly. Perhaps it was just the change that did it and any product would have made an improvement. According to the manual the system capacity is 19L, but I only get around 8L when I drain it. I try to remove and replace 8L per year. The VW stuff will be going in next.
